Question about Ram W100/W150 1974-1993 Dodge 0-2 inch Lift 4WD Steering Stabilizer Kit
Battery drain overnight
Acts like dead battery when turning key but battery has full charge
    Problem Solver:
  • 14 Answers
Possibly starter solenoid or wiring to starter next id say check amps output of battery just cause its got twelve volts dont mean the amps are right
Posted on Mar 26, 2014
MY BATTERY DIES AND MY REMOTE START WONT WORK. I TRIED THE TRUNK AND LOCK BUTTON AND CHECKED THE SWITCH AND IT STILL WONT START.... HELP PLEASE ITS COLD OUT SIDE
Use a proper key to open the door, pop the hood and put the battery on to charge.
Remote starters are notorious for causing problems.
Jan 05, 2016 | Cars & Trucks
Left key on for few days battery dead I jumped it off and runs very rough when give it gas gauges go out and backfires
Hi Did you leave the jumper battery hooked up while it was running? It sounds like the dead battery may need to be replaced. Jump it again and leave the jumper battery hooked up and then see if it runs ok. If it does run good you will need to replace the battery. I hope this helps. Rod
Aug 14, 2015 | 2004 Suzuki VL 1500 Intruder LC
New battery keeps going dead when car shut off overnight
Sounds like a slow drain - like a dome light or short in the wiring.
If the battery stays charged when it is disconnected, you'll have to check for a power drain in the car.
Jan 16, 2014 | 1997 Honda Civic
Dead battery in saturn l300 2002
if your ground is bad or has a short the cable then acts a reverse deducter when car is off try changing the ground wire or yhe light switch
Dec 28, 2013 | 2002 Saturn L-Series
My 98 lumina has a constant power draw from somewhere. I just replace the battery and had the alt tested (it was good). I have to jump the dang thing every morning but if I drive it enough during the day...
The alternator may charge fine but could drain the battery through a bad diode,have you checked the alt for a bad diode?Disconnect the battery positive cable.Put a regular 12v test light between the battery positive post and the positive battery cable.If the test light is bright you do have a drain,if dim it is OK.A dim light may mean the drain is internal in the battery.If you do have a bright light remove a fuse ,one at a time from the fuse box until the light goes dim.Once dim you have identified the bad circuit.If removing all fuses do not dim the light,disconnect the alt charging wire at the alt,if that dims the light,then you do have a bad diode.DO NOT create a drain(bright light) when checking for the drain by turning on the key or opening a door/trunk etc.
Also,do an overnight battery check by disconnecting the battery overnight,if things are fine the next morning after the battery was disconnected then it is a drain in the vehicle,if the battery is dead even after being disconnected overnight,,then the battery is bad.
Jun 15, 2017 | Cars & Trucks
Battery reads full on the charger but mower acts like battery is dead and won't start
It may show a full charge but when you go to turn the engine over it's draining the charge and there's not enough of cranking amps to keep it turning over. I would suggest installing at least a 350 cranking amps. This will not hurt the engine but it will give more power to turn the engine over to start. A lot of cheaper batteries are only 200-275 amps but don't last long.
Sep 05, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
My mercedes sat for 10 months while I recuperated from injuries. The battery was completely dead. Remote didn't even work. We were able to jumpstart it with battery cables but it won't keep running. Dead...
You will burn out your alternator if you keep on doing this.The alternator is not a charger. If you have a dead battery you should always charge it overnight on a charger.To keep the battery fresh all that you have to do is disconnect the terminals.Yes this is normal because the car has clocks and alarms that drain power even when the key is off. If you let the battery set to long while it is drained it will not take a charge.
Jul 06, 2010 | Mercedes-Benz C230 Cars & Trucks
Car won't start. Acts like the battery is dead, however I can't jump start it.
Well if you cant jump start it thats a good sign that the battery is dead so replace it and you should be fine, and another way you can try is hook the battery up to a charger overnight and if it doesnt hold its charge then you will know if its dead or not.
Jul 04, 2009 | 1998 Oldsmobile Aurora
2004 also
Take the SUV to an autoparts store that features free charging diagnostic tests. They will determine if the alternator is putting out sufficient power to recharge your battery. There's also a very good chance your battery is dead. It's not uncommon for a battery to need replacing (especially in a truck with all the bells and whistles I'm sure the Santa Fe has) after 4-5 years. It's also important to ensure there's no corrosion around the battery posts/cables (will have a white or green powdery appearance). Corrosion would prevent the battery from accepting a full charge.
I hope this clarifies your problem. It's unlikely the alarm system is the culprit provided it's not "going off" all day long. Best of luck and please feel free to post back with any other questions.
Greg
Jun 12, 2009 | 2007 Hyundai Santa Fe Limited
When i turn key it acts like a dead battery , battery is charged
1. There is a wiring connection that is draining the battery.
2. The alternator needs to be checked.
Cheers.
May 22, 2009 | 2000 Mercury Mystique
Ram W100/W150 1974-1993 Dodge 0-2 inch Lift 4WD Steering Stabilizer Kit Logo
63 people viewed this question
Top Pro Comp Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Pro Comp Vehicle Part and Accessory Expert? Answer questions, earn points and help others
