Xerox 6204 WIDE FORMAT Communication Error Chain link = 123-314
3 Suggested Answers
  • 14 Answers
SOURCE: Xerox 6204 error 071-103
The cutter assy has a disk with hole in it to tell the circuit board how fast it is turning and where it is in respect to the home position. It may be that this disk or the sensor that looks through it has a lot of paper dust on it and not able to read correctly. It may me the the cutter itself is sticking and needs a little cleaning and oiling.
Posted on Feb 10, 2008
  • 239 Answers
SOURCE: i have an e2 error on a wide format xerox 3001
Check for a jam sensor actuator hanging up. Check for paper dust or toner particals on the sensors if you can see them.
On these types of machines they require lubrication on the fuser mat for proper lubrication to the heat roll and paper transport.
If this mat has not been serviced it might contain high amount of toner on it causing excessive drag on the heat roll. There can be unusual wihistling or bumpy noise when this occurs.
Also the in this case the heat roll might be damaged and may be replaced.
Posted on Oct 16, 2009
I have a Xerox 7142 wide format printer. It gives me this error on the machine. How do I fix error - E016 CPUErr [35]
Looks as if the series of E016 CPUErr point to a problem with the main board and may need to have a replacement, so would suggest a maintenance call out. Sorry.
Feb 26, 2015 | Xerox Office Equipment & Supplies
Xerox WorkCentre 7120 error code
Chain Description 001 Cover and Door Interlocks 002 Touch Screen / Control Panel 003, 041, 045, 123 Machine Communications 004 Drives 005 Duplex Automatic Document Feeder (DADF) 061, 062 Scanner, DADF and ROS 007 Paper Supply 008 Paper Feed 009, 089 Xerographics 010, 011 Fuser, Copy Exit 012, 013, 047, 112 Finisher 016, 124, 127 Configuration, Software, Memory, Hard Drives, Color Server, DFE 018 Network Communications 020 Fax, Software 021, 121 Foreign Interface 022 Job Timers 024, 026, 027, 033 Job Parameters 034, 035, 036, 133, 134 Fax Communication 042 Motor, Fan, Sensor 071 Tray 1 Misfeed 072 Tray 2 Misfeed 073 Tray 3 Misfeed 074 Tray 4 Misfeed 075 Tray 5 Misfeed (Bypass Tray) 077 Paper Path Jam 078 High Capacity Feeder 083, 084 Fax Jobs 091 Drum Cartridge 092, 093 ATC, ADC, Toner 094 IBT, BTR 102 Job Queue 103, 116 Software
Aug 23, 2014 | Xerox Office Equipment & Supplies
Xerox 510 wide format printer error code LL-12
PLEASE INFORM ME
MY XEROX 510 IS DESPLAY ERRORE CODE LL-12
Jul 18, 2014 | Xerox documate 510 - 600 X 1200 Workgroup...
I am getting an error message "external device error" chain link 116-311 for xerox 6204 machine
"external device error" chain link 116-311 for xerox 6204 machine how to solve the proplem
Dec 09, 2013 | Xerox Office Equipment & Supplies
Xerox Synergix A0 Scanner setup
As far as I know you need either the Xerox Accxes controller (like a dedicated PC) or a wide-format printer with the built-in Accxes controller, like the Xerox 8825 model. The 8825 has the firewire input and communicates just fine with the YWC-1.
Oct 24, 2011 | Xerox One Touch 2400 Flatbed Scanner
Xerox phaser 8560 error 110094638361
The normal format for this error should probably read 11,009.46:38361
11,009 tells us that we have a communication failure (38361 is just your page count)
Normally, for this error, you will need to purchase a part: The electronics module 133K14020 or the I/O board 960K22330, which is cheaper and easier to replace.
Whit
Item, Inc.
Feb 25, 2010 | Xerox Phaser 8560DN Printer
XEROX PHASER 6180 LASER ERROR 061-370. WHAT IS THIS?
Chain Link 061-370 An error was detected in the Laser Unit.
Initial Actions
? Cycle printer power.
? If the problem persists, follow the procedure below.
Sep 04, 2008 | Xerox Office Equipment & Supplies
354 people viewed this question
jasbo
jasbo
