Question about Gaggia Titanium Espresso Machine
Saeco royal digital says water tank is empty when it is not
Replace flow meter but now I cannot do anything. Screen says water tank is empty when it is not empty
My Saeco Royal coffee machine is displaying 'empty water container' and it is full - what is the problem
Is the floating magnet in the water reservoir floating ? If yes, you will have to check:
1) the micro switch which is located just beside the magnet (open the machine to check it with and ohm-meter) Check it with a small magnet that you have
2) if the micro-switch is OK with a hand-held magnet the floating magnet may be de-magnetized
3) if everything above is OK, the input on the control board is perhaps defective
Mar 23, 2012 | Saeco Royal Cappuccino Espresso Machine
The machine says ventilatore and will not do anything The fault was shown after the water container has been refilled and it run empty for water in 5 sec.
Hi
On the Royal Pro machines there is a water button that you are suppose to push to run water. Have you pushed the button? Water has to flow to clear the ventilate message.
Dec 07, 2010 | Saeco Royal Professional Espresso Machine
It keeps telling me "needs to prime" and I try to prime it and it doesn't work. No water comes out of the steam wand. I can tell that the machine is working, but I can't get anything to change on the...
Hi You have a flow meter that needs to be replaced. It has probably been plugged with a coffee chip (usual cause) when the water tank was off. If the flow meter is restricted water can't flow or flow fast enough to spin the flow meter and the machine won't work.
Sep 23, 2010 | Starbucks Saeco Italia Digital Barista...
The display on my Saeco Royal Exclusive says ventilate and the machine won't do anything, what do I do?
Hi
That means the pump needs to be primed by running water through the wand. Push the water button( the one with the drop or drops). You will hear the pump change tone when it primes and the light or message will disappear. If you have a restriction in the intake line the message will not go away. There is a flow meter inside the machine that measures water flow. If the flow meter does not spin when the pump is running, the computer thinks that the pump is not primed.
Aug 21, 2010 | Saeco Royal Professional Espresso Machine
My saeco royal has ventilate on the screen and is not working. what does this mean?
Hi That means the pump needs to be primed by running water through the wand. Push the water. You will hear the pump change tone when it primes and the light or message will disappear. If you have a restriction in the intake line the message will not go away. There is a flow meter inside the machine that measures water flow. If the flow meter does not spin when the pump is running, the computer thinks that the pump is not primed. Coffee grounds will get into the intake and restrict the flow meter. If you get a restriction in the water intake (below the water tank, on the machine) the pump may run and water comes out, but the flow meter does not create the jet of water to spin the turbine wheel to send impulses to the computer. You get the ventilate message. One thing to remember is when you are working on the water system (have the water tank off) do not fill the bean hopper and visa versa. Keep them covered when working on the other. Cross contamination will damage a machine fast
Feb 08, 2010 | Saeco Royal Professional Espresso Machine
Ventilate message, but no air in system
HI Sorry, but that sounds like a bad flow meter. The flow meter is not that hard to replace, with a little common sense, but the new flow meter should be the brass one. There are some tricks to getting the top back on, Pull forward on the bypass doser chute a little so it will center in the opening. You don't have to disconnect all the wires that go to the top. They are long enough that the top will set behind the machine carefully. Remember the tubes that go to the flow meter. You don't want to get them backwards.
Jun 14, 2009 | Saeco Royal Coffee Bar Coffee Maker,...
Saeco Coffee machine water tank empty
It is possible that the water sensor on the back panel of the machine is not operating, you will have to remove the back panel and check the sensor with an ohmsmeter.
May 18, 2009 | Saeco Royal Digital Plus Coffee...
Saeco Royal Exclusive 30153... FILL WATERTANK
Hi Marty,
Make sure the magnet in the water tank flow up when you fill the water tank with water.
Aug 07, 2008 | Saeco Royal Exclusive 30153 Espresso...
Water tank empty
the sensor is not working.. try to identify the sensor inside the tank and change it..
Dec 29, 2007 | Saeco Royal Professional Espresso Machine
Open Questions:
See all Gaggia Titanium Espresso Machine Questions
Gaggia Titanium Espresso Machine Logo
23 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
