Question about Ram W100/W150 1974-1993 Dodge 0-2 inch Lift 4WD Steering Stabilizer Kit
No start or power when turning key
Battery drain overnight
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 62 Answers
Do you have an aftermarket stereo? Also take it to AutoZone or PepBoys for a free battery test the amperage could be too low.
Posted on Apr 02, 2014
04 Tundra battery draining overnight
Did you let the vehicle sit for 30 min. before testing ? Modules need to time out (go to sleep - power down etc.. How are you testing ? Have a ammeter inline with battery negative cable and negative battery post . Have any doors open ( door switch closed ) Key out of ignition ? How much current ? 50 milliamps max !
Dec 19, 2016 | 2004 Chevrolet TrailBlazer
Left key on for few days battery dead I jumped it off and runs very rough when give it gas gauges go out and backfires
Hi Did you leave the jumper battery hooked up while it was running? It sounds like the dead battery may need to be replaced. Jump it again and leave the jumper battery hooked up and then see if it runs ok. If it does run good you will need to replace the battery. I hope this helps. Rod
Aug 14, 2015 | 2004 Suzuki VL 1500 Intruder LC
Battery drains and bought a new one but problem still there
Sounds like u need to check for battery draw...something is keeping power coin when car is off and draining battery...
Also may wanna check alternator for charging...
Sep 25, 2014 | 1996 Lincoln Town Car
When i turn the engine off my radio turns off and then comes back on after 20 or 30 secs and you then have to turn it off with the button on the radio. Also if you leave the car for longer that 18 hours...
It could be. A couple of ways to check: either take the negative battery off overnight or for 18 hours, and see if battery does not go flat-then you know you have a drain somewhere. Or you could remove all power to the radio overnight (by pulling radio fuses or unplugging the radio), then see if the battery has drained any.
Jan 24, 2014 | Cars & Trucks
Can a faulty theft system drain your battery?
No an anti-theft system can not drain a battery. Only two things can, with a couple of other caveats.
  1. Faulty, old battery not holding charge.
  2. Parasitic draw, something that is staying on and draining the battery. These are difficult to find. The way to do it is to connect an ammeter to the battery and pull the fuses one by one until you find the items that are shorting to earth.
Some anti-theft systems provide no power to the starter at all. Some send power power to the starter, but no power to the coils, so no spark.
Disconnect the battery and clean the terminals with a wire brush and smear with vaseline which stops oxidisation but is electrically conductive.
Charge the battery with a battery charger.
Leave battery disconnected overnight.
Put the key in the ignition, but not turned on. Connect the battery in one swift movement. Tighten contacts. Leave 15 minutes for the ECU, to reset, and the chip in the key and the chip in the lock to re-pair.
Jul 27, 2017 | 2002 Chevrolet Malibu
My 98 lumina has a constant power draw from somewhere. I just replace the battery and had the alt tested (it was good). I have to jump the dang thing every morning but if I drive it enough during the day...
The alternator may charge fine but could drain the battery through a bad diode,have you checked the alt for a bad diode?Disconnect the battery positive cable.Put a regular 12v test light between the battery positive post and the positive battery cable.If the test light is bright you do have a drain,if dim it is OK.A dim light may mean the drain is internal in the battery.If you do have a bright light remove a fuse ,one at a time from the fuse box until the light goes dim.Once dim you have identified the bad circuit.If removing all fuses do not dim the light,disconnect the alt charging wire at the alt,if that dims the light,then you do have a bad diode.DO NOT create a drain(bright light) when checking for the drain by turning on the key or opening a door/trunk etc.
Also,do an overnight battery check by disconnecting the battery overnight,if things are fine the next morning after the battery was disconnected then it is a drain in the vehicle,if the battery is dead even after being disconnected overnight,,then the battery is bad.
Jun 15, 2017 | Cars & Trucks
98 Ford Explore with new battery and it drains overnight. Had a garage check power streams and they say everything looks normal. But battery continually drains
Have your alternator and voltage regulator checked. I once had a galaxie 500 that did the same thing - turned out the alternator was bad and the regulator drained the battery overnight. I changed out both and problem solved - hope you have the same luck!!!
Nov 22, 2010 | Ford Explorer Cars & Trucks
I have a 87 300e benz. Radio was left on and drained battery overnight. Tried jumping it today but wont start.
charge battery fully do not jump it turn key on for 30 sec than offf ,car should start
Nov 14, 2010 | 1987 Mercedes-Benz 300-Class
Ram W100/W150 1974-1993 Dodge 0-2 inch Lift 4WD Steering Stabilizer Kit Logo
46 people viewed this question
Top Pro Comp Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Pro Comp Vehicle Part and Accessory Expert? Answer questions, earn points and help others
