Question about Air Tools & Compressors
Rockworth air compressor parts
I have a Rockworth model 7060vr i am in dire need of head and cylinder gaskets and a valve assembly can you help me?
  • 1383 Answers
SOURCE: Air compressor head gasket diagram
Campbell hausfeld has all their manuals on line at www.chpower.com / you can enter the model # of the whole unit or just the # of the pump. Also you can enter just a partial number example wl650 for a list of models is that range. Use caution when installing gaskets for chpower oiless pumps. Some of their gaskets are very brittle. After installing parts, turn pump by hand to make sure all parts are in their proper place and that there is suction. Enjoy
Posted on Dec 02, 2008
ollie reece
  • 1167 Answers
SOURCE: I have a ingersoll rand air compressor rand 4000
you dont torque it you can torque it ya self if you wont but wont make a change do it to 40-50nm ahd try this if no good replace the gasket they do wear out at times also when you take the head off thereshouldnt be oil in there only on the cyclinder not the head ??
Posted on Oct 08, 2009
braintrust
  • 62 Answers
SOURCE: i need the assembly instructions for an emglo
there is aweb site called www.mastertoolrepair.com in the search type am77 should get schematic break down for your compressor, then go to internal parts and you should get a brek down and schematic on your compressor hope that helps
Posted on Oct 27, 2009
mickey813
  • 472 Answers
SOURCE: I have a Craftsman model 919167244 compressor. It
were the line hooks up thirs a ck ball thay rust up just spry some w-d 40 on it try that if that dont fix it let me know
Posted on Nov 04, 2009
  • 1274 Answers
SOURCE: i have bought an ex-display Rockworth 24 litre 2.0
Hi, my name is John. Welcome to FixYa. You can get it here. www.mastertoolrepair.com . Thanks for choosing FixYa...John
Posted on Nov 29, 2010
Why doesn't my rockworth compressor fill up when it's running it's brand new
This could be an assembly error at the company. There are three valves in a compressor, one is an intake, one is an exhaust, one is an unloader. The easiest way to check is to put your hand on the intake air filter to check for suction. If there is suction then the valve is ok on the intake, if it flutters then it is bad or missing. Locate the on off switch and there should be a valve that unloads the pressure from the compressor, see if that is leaking.
May 05, 2016 | Rockworth Factory-Reconditioned...
Where can I purchase a replacement petrol tap for my Rockworth 2.4/8 kva generator - approx 5 years old
Try here. Click Enter Parts System, then select Rockworth from the list on the left. They may be able to help.
Generator Guru
Dec 18, 2014 | Electrical Supplies
Need gasket
Great Question, I have a feeling there is more then one gasket in your unit, you might want to give more info so somebody can help you such as what gasket.
Dec 05, 2014 | Rockworth RW1503TP 3-Gallon Factory...
Rockworth model rw 1506 runs but will not build up pressure past 25 lbs
Remove & check out the ---- Tank Check Valve
If that is good-- then the cylinder head comes off
next & you have a valve problem
Jul 15, 2014 | Air Tools & Compressors
Rockworth 1.5 hp 6ltr oil free compressor drive belt replacement
You could try this link.
This is for megadyne tb2 310 belt (nlh6ltCOM)
http://www.solenttools.co.uk/performance-power-drive-belts/performance-power-compressor-drive-belt-nlh6ltcom-2051157-331171-.php
Feb 19, 2013 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
How do you fit a new drive belt to a rockworth compressor because there doesn't seem to be ant adjustment
if this is a small compressor say 2 hp you leave everything alone make sure you have the right size belt and stretch it on like a rubber band.. The belt will be quite tight but thats the way they come. If you are concerned that the new belt is too tight or too loose mark the position of you motor with a felt pen remove the belt and move the motor forwards or backwards a small amount in line with your marks, then refit the belt. The main thing is that the motor shaft stays parrallel or close to it with the drive shaft of your pump.
Jan 16, 2013 | Air Tools & Compressors
I would think that if you are mechanically inclined at all you should be able to do that. You are right must tanks are either generic in configuration or made be the same manufacturer. I would like at worse case you may have to drill a couple of new holes for mounting your compressor.
Apr 21, 2012 | Air Tools & Compressors
Where can I get a manual formy newR W 1820F
I am sorry but we do not have manuals for this type of equipment, I suggest you contact Rockworth.
Feb 10, 2012 | Cars & Trucks
Broken on/ off switch for rockworth ARPD1700 hammer drill
rockworth powertask demo hammer needs new trigger how do i get parts
May 17, 2010 | Hitachi H65XXX 1 - 1/8 " Hex Shank...
I need the parts for rockworth power task 1700w
Hello I need a new trigger switch for my Rockworth PowerTask
serial no uk004984 ARPD1/OOK. On the switch itself inside it has HY15C. Please put me in touch with your on parts division. Thanks.
Jun 13, 2009 | Hitachi H65XXX 1 - 1/8 " Hex Shank...
Air Tools & Compressors Logo
114 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
