Question about Canon MR-14EX TTL Ring Light Flash
Replacement part The base or connector for my ringflash has cracked so I need a new one to be able to connect it to the body. It seems it's just a matter of unscrewing 4 small screws to do this. Thanks for help.
  • 3 Answers
The bases are sold on EBay, I replaced 2 of them. There cheap comparably from buying a new one. Like you said 4 screws, but be careful there is also 4 springs inside. http://www.ebay.com/itm/Canon-MR-14EX-Ring-Light-Replacement-Flash-Shoe-Foot-Free-Shipping-/370901814099?pt=Camera_Flash_Accessories&hash=item565b788b53
Good Luck Raf Camera Guy!
Posted on May 26, 2014
How to disconnect a BCM in a chevy colorado 2007
Removal Procedure
Important:
• The ignition switch should be in the OFF position when connecting or disconnecting the connectors to the body control module (BCM).
• Always disconnect the black body wiring harness connector FIRST and the gray instrument panel (I/P) wiring harness connector LAST.
• Always connect the black body wiring harness connector FIRST and the gray I/P wiring harness LAST.
• Do not open the BCM housing. The module does not have any serviceable components. The module may be replaced only as an assembly.
Ensure the ignition switch is in the OFF position.
Remove the right front hinge pillar trim panel. Refer to Body Hinge Pillar Trim Panel Replacement - Right Side .
Disconnect the body wiring harness electrical connector (1) from the BCM.
Release the fastener retaining the body wiring harness electrical connector to the BCM. Remove the 2 fasteners retaining the BCM to the hinge pillar.
Remove the BCM from the hinge pillar by unlocking the integral tab.
Remove the BCM from the vehicle.
If installing a replacement BCM, program the BCM. Refer to Control Module References .
Dec 19, 2016 | Cars & Trucks
The seat is cracked and doesn't heat anymore, is there anything I can try before buying a new one?
if the seat is cracked then the element is probably broken at the crack site
check for circuit continuity of the element or buy a new seat
can't be too hygienic or comfortable sitting on a cracked seat
Jan 20, 2016 | AMDM Intelliseat - The Ultimate Bidet...
Kids dropped tablet. dead. Opened back and found display connector cable/film had cracked. Is there a fix for this? Is the connector integral to the display or an easily replaced cable?
take it to a repair shop but the problem really is when it is dropped , look for a new one as repairs will cost close to a replacement unit
Dec 20, 2015 | Tablets & eReaders
Cracked body, HP Photosmart 945
Greetings,
I have a complete HP 945 camera that needs a CCD . Everything else seems to be ok and the case is newish in good condition.
If you want the camera for parts. I would be willing to sell it for $10 plus shipping and insurance. $20 total to you in the lower 48 States USA. I live in Tampa,Florida 33604 813 238 4830 phone works sometimes get someone else so keep calling there is an answering machine with my voice. If you leave you number I will return you call George
Jun 14, 2012 | HP Photosmart 945 Digital Camera
What do I need for a tune up for my 2003 Lexus GS 300? I want to shop @ Wal-Mart for most of the content (I work there) and have the car running LOVELY lol. Please help me
To do a "Tune-up" you will need 6 spark plugs, a throttle body gasket, an air filter, an air compressor, a blow gun, a magnetic pick-up tool and a socket set with ratchet and extensions.
You must remove the intake air resonator, the #3 timing belt cover, the accelerator cable, the throttle control motor connector, the throttle position sensor connector, the accelerator pedal position sensor connector, the throttle body bracket and the throttle body. Then remove the spark plug cables and the ignition coils. You will then crack the spark plugs loose 1/4 turn and use the air compressor and blow gun to blow the debris out of the spark plug tubes so it does not enter the combustion chamber when the spark plugs are removed. Then remove the spark plugs. You will need the magnetic pick-up tool to fish the plugs out of the tubes once they are completely unscrewed.
Install new spark plugs and torque them to 13 ft.lbs (18 Nm)
Install throttle body with nw gasket. Install all other parts removed and connect all connectors.
Install intake resonator and new air filter.
May 12, 2011 | 2003 Lexus Gs 300
1999 Ford Taurus. One day after brand new battery
Check all other battery connections, battery to motor and body. Also Motor to Body ground strap. Make sure all connections are not corroded. If that does not help check starter soloinoid and starter
Jul 26, 2010 | 1999 Ford Taurus
The hot shoe mount on my EM 140 DG Macro ringflash has broken on one side and I require a new fitting + lock ring
Contact Sigma and ask if you can purchase a dedicated base for your flase to fit your brand camera. The bases on generic flashes generally are interchangeable.
Sep 11, 2009 | Sigma Cameras
Have a couple cracks in right front of bumper cover. Failed Massachusetts inspection. Would prefer to patch the cracks rather than taking to auto body shop for replacement cover. Any suggestions?
I did a bit of quick research and came up with the following: http://www.autobodysupply.net/articles.asp?id=135 I have not tried it but based upon what I read, it seems that they have an idea based upon facts.
Good luck
Aug 09, 2009 | 2004 Jeep Grand Cherokee
Vehicle engine seems to stall at low revs or approaching a stop, been doing that last few days. Now brakes do not seem to have any power assistance. Any thoughts, think this is now not fuel related and...
check for a vacuum leak... the brake booster could be bad and need replacing.
check the vacuum hose that runs from the brake booster to the manifold. Sometimes they crack, leak, or get partially disconnected...the gromet on the booster itself as well.
Good luck...i hope this helps.
Jul 19, 2009 | 1996 Jeep Grand Cherokee
VW Polo Classic 1997 IDLE Problems
Hello, VW polos 1.0, 1.4. 1.6, suffer from carbon bulid up in the throttle bodys causing bad idling, esp the Bosch Mono-Motronic (Throttle Body Injection systems), a good clean with carb cleaner should repair the problem, also engine temp sensor replacement and idle speed control valve replacement can help idle problems.
Sep 02, 2008 | 1987 Volkswagen Jetta
Canon MR-14EX TTL Ring Light Flash Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
