Question about Seal Office Equipment & Supplies
I need to seal my attic door completely but not my using locks or bolts.Have there any good seals?
I need something strong to seal it.Any idea?
I don't know why you want to seal your attic but www.tydenbrooks.com provides wide range of industrial seal so you might want to go through it to find which suits best for you since you don't want any bolts or locks. People usually use good quality and high strength locks or bolts to seal the attic. But it is your choice whatever you want to use. Security Seals High Quality Tamper Evident Seals Bolt Seals Cable Seals...
Posted on Mar 26, 2014
I need to seal my attic door completely but not my using locks or bolts.I need something strong to seal it.Any idea?
I don't know why you want to seal your attic but some companies provides wide range of industrial seal so you might want to go through it to find which suits best for you since you don't want any bolts or locks. People usually use good quality and high strength locks or bolts to seal the attic. But it is your choice whatever you want to use.
You could try this link to get some good seal for your door.
Security Seals High Quality Tamper Evident Seals Bolt Seals Cable Seals... Security Seals High Quality Tamper Evident Seals Bolt Seals Cable Seals...
Feb 08, 2014 | Sentry Safe Products Sentry Safe H4100...
How could I find best qualities of seal to lock my attic doors?
I don't know why you want to seal your attic doors.Some of companies provides wide range of industrial seal so you might want to go through it to find which suits best for you since you don't want any bolts or locks.People usually use good quality and high strength locks or bolts to seal the attic.But it is your choice whatever you want to use. Security Seals High Quality Tamper Evident Seals Bolt Seals Cable Seals...
Feb 03, 2014 | KitchenAid Architect Series KEMC308KSS...
I completed a wash. I am unable to open the door.
hi best way round that is too get some strong string ..put round door were lock is and pull hard so it will undo the door ..u then need to change door lock ..its behind rubber door seal held in with x2 screws..
Feb 25, 2011 | Bosch Axxis WFL 2060 Front Load Washer
Freezer door pops open when the Refrigerator door is being closed
My new freezer did the same thing. I contacted the company and they went into the whole leveling thing. What it has to do with is the magnetic seal. The magnets are not strong enough to keep the freezer door from popping open when closing the big fridge door. They share the same duct. I level my doors on the fridge and freezer so they swing shut by themselves after opening. Just the force of the big door when it swung closed cracked open the freezer door about a quarter of an inch and if left unnoticed created a puddle and made the fridge run overtime. I solved the problem by placing strong magnets inside the fold of the magnetic seal at the handle end of the door. This is the flap on the outside the door seal. I used six magnets on the top and six on the bottom. The magnets were from discarded Sonicare tooth brush heads. They are very flat and super strong. You can find something on ebay. My freezer door doesn't budge problem solved. I did call the company and told them I solved the problem and they still insisted it was the leveling. Good luck, Art Knapp
Jan 08, 2011 | Refrigerators
When we close the refrigerator door the freezer door pops open. It seems like a vacum problem?
Dec 24, 2010 | LG Refrigerators
Every time the refrigerator door is closed, the freezer door pops open. How can we better secure the seals?
Dec 13, 2010 | Kenmore 64802 Top Freezer Refrigerator
WHY WOULD RAIN LEAK IN NEAR FRONT DOOR? ALL SEALS
Some leaks actually are from the windshield and it is contained by the trim so you can't see where it is leaking from. If it is the door seal look at the striker bolt to see if there is any abnormal wear. Make sure the striker bolt is aligned with the door striker. If you don't know how to check this run by your local body shop and ask them to check it for you. Sometimes if the keys have ever been locked in the vehicle people use door shims to hold the door open as to pick the lock. This is bad because it knocks the door out of alignment with the seals. Hope this helps.
Feb 06, 2010 | 2006 Jeep Liberty
1hp whisperflow pump, seal change. How?
Make sure breaker/power to pump is off. Remove the six bolts holding the wet end to the seal plate. Remove the diffuser to expose the impeller. Remove the screw in the middle of the impeller by turning clockwise (left hand threads). Remove the dust cap at the rear of the motor and use a wrench to hold the shaft while you remove the impeller by turning counterclockwise. Once the impeller is off, remove the four bolts holding the seal plate to the motor. Press the old seal out of the seal plate and clean it thoroughly. Remove the ceramic part of the seal from the impeller and clean it thoroughly as well. Apply a thin coat of lube to the seal plate and impeller where the new seal will go. Remove the new PS1000 shaft seal from the box (being careful not to touch the ceramic or carbon face with your fingers), press the metal part into the seal plate carefully, try not to bend the metal and make sure its completely seated against the seal plate. You can now install the seal plate back onto the motor and secure with four bolts. Press the ceramic part into the impeller, use cardboard or paper between your fingers and the ceramic face. Once you have seated the seal into the impeller, hold the motor shaft and thread the impeller on until snug, then reinstall the stainless screw, remember it is left hand thread so you'll have to turn it counterclockwise. Reinstall the diffuser over the impeller and then install the wet end onto the seal plate using the six bolts, don't overtighten them.
It is a good idea to replace the tank o-ring when taking to pump apart, but if the o-rings are in good condition, just apply a light coat of lube and reuse them.
This is a general guide for replacing a seal, if you have trouble removing the impeller, you may need an impeller wrench and a tool to hold the motor shaft.
I hope this helps, if you have any specific questions, email me at mail@leisurepoolservice.com
Oct 28, 2009 | Pentair Pool & Spa
Change the door seal
Not sure if its the same type but I just changed the door seal on a Zanussi ZWF1221W washing machine. It was a lot easier than I was expecting but this way does take a bit longer. Before starting disconnect the mains and water supply and drain hose. If possible move the washing machine out so you can get around it.
First I used a small flat head screwdriver to open the teeth on the outer door seal clamp that holds the seal in place. The old seal then peels off the front of the machine. You can continue the process without taking the front of the washing machine off but it is much, much easier to take it off if you can.
To remove the front panel unscrew the two bolts at the top corners of the back panel and slide the top cover off towards the back and lift it off. Then remove the two bolts that attach the plastic control panel to the front of the machine (either end of the top, front edge), remove the detergent dispenser drawer (you need to push down on a lever at the back) and take the screw out of the front of the machine (revealed when you take out the detergent drawer). Then carefully remove the control panel and the two bolts that hold the front panel on.
Then (very carefully as washing machines are heavy) lie the machine on its back and remove the three screws from the bottom that hold the front panel on. Then unplug the cables on the inside of the front panel that operate the door lock (its a plug with a plastic cover - just pull it out but don't pull the wires!).
Now you can lift the front panel off which is the key to making this job really easy as you're not trying to fit the new seal through the door which makes it really tight.
With the machine still on its back find the spring that stretches all around the seal to hold it on the drum and remove using a flat head screwdriver to pull it out of its groove. You can now pull the old seal off.
It's a good idea to put some fabric softener or liquid detergent around the edge of the new seal to make it easier to fit on to the drum at this point.
Find the arrow that points to the top and starting here attach the groove of the new seal to the plastic drum all the way around. You have to press quite hard but you can tell when its properly attached to the drum. Once this is done replace the spring so it sits in a groove on the seal holding it to the drum.
Now replace the front of the panel of the machine by doing the reverse of all the earlier steps (remember to reattach the door lock) and stand it back up on its feet (careful it's heavy). You can now replace the top panel of the machine (slide it on and replace the two screws).
With the washing machine back upright you can attach the front of the seal to the door opening of the front panel (the arrow should be pointing upwards). Then you can reattach the clamp that holds the seal around the door opening and then secure the teeth on the clamp so it's tight (I don't know if it matters where around the seal the clamp goes but mine's at about 7 o'clock).
Now all you need to do is reattach the drain hose, water supply and mains and test it doesn't leak. A rinse cycle uses the most water apparently so it might be worth using that.
Hope this was useful.
May 23, 2009 | Zanussi FJS1225W Front Load Washer
How do I replace a drivers side front seatbelt on a ford mondeo
well the seatbelt in the front of a car are very strong and should be bolted in both from the underneath of the car in the middle and on the edge of inner door seal, most upto date cars there will be a cap which removes from angle at top most point of seat belt to undo. all bolts should be lock tighted(chemical metal) to seal and not undo in unlikey event of bad crash.
Feb 25, 2009 | 2008 Ford Fusion
Top Seal Office Equipment & Supplies Experts
Andrew Taylor
Andrew Taylor
Vernon Taylor
 Grubhead
Grubhead
Are you a Seal Office Equipment and Supply Expert? Answer questions, earn points and help others
