Boiron Quit Snoring Carekit 3 Mdt Logo
n
nilimarose Posted on Mar 26, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Is there any way to stop snoring completely?
I want to stop snoring.And from a lots of days i suffering from snoring.What should i do for that?
Kate Brownell
Level 2:
Novelist:
Habit-Forming:
  • Expert 129 Answers
  • Posted on Oct 23, 2019
Kate Brownell
Expert
Level 2:
Novelist:
Habit-Forming:
Answers
129
Questions
0
Helped
47743
Points
401
Snoring is a common sleep disorder and if you do not concentrate on it, it can be a chronic disorder. The most common medication for snoring is the use of CPAP masks for side sleepers. It maintains continuous air flow through narrow airway and thus prevents snoring. Other medications include maintaining good sleep posture, refraining from smoking and drinking. These can be the physical factors by which one can be free from snoring. But CPAP mask is the most effective way to treat snoring.
Anders Thomsen
Level 2:
Scholar:
New Friend:
  • Expert 33 Answers
  • Posted on Jun 04, 2017
Anders Thomsen
Expert
Level 2:
Scholar:
New Friend:
Answers
33
Questions
0
Helped
15365
Points
116
Snoring is due to the lack of air flow into the person's body. When the narrow air passage in the throat is blocked, it disturbs the air flow which causes the tissues and uvula vibrate against the back of the throat, thereby creating the noise. There are several remedies to help get rid or at least reduce the snoring significantly in a natural manner.
Sometimes sleeping on your side is all that is required to stop snoring, but if you have weight issues then losing weight might be what you actually need. There are several other things one can do, such as propping up your head against several pillows and sleeping to elevate your head height. You can also reduce dust allergens in the room, or use nasal strips to tape back your nostrils. Taking a decongestant is also an option, as is using a neck brace (in rather extreme cases). There are several essential oils and herbal teas that help - and if you are a smoker, then quitting as soon as you can would work wonders.
Remember that snoring not only affects you but also your partner. Therefore the remedy should be considered seriously.
Rene Moller
Level 1:
New Friend:
Problem Solver:
  • Contributor 9 Answers
  • Posted on Sep 10, 2015
Rene Moller
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
9
Questions
Helped
4435
Points
39
There are lot many solutions available nowadays to stop snoring. It's all depends upon which one suits you better. The range of solutions from natural remedies to anti-snoring aids. One who is going with the surgery option, should only go after doctor's advice. So always go with the natural remedies such as normal exercise of loosing weight and changing of the lifestyle a bit. Or you can better prefer to use anti-snoring devices that are easily available in the market. Asonor effective award winning Anti Snoring solution
sunitymohan
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Mar 26, 2014
sunitymohan
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
336
Points
Yes, there is a permanent way to stop snoring. It is a surgical method in which doctor tighten or trims extra tissue. There are other surgical methods as well. It isn't recommended much and it might take more than one session.Many people visit them and find almost permanent solution to their snoring habit. From light to heavy snoring anything can be stopped. How to Stop Snoring Sleep Apnea and Snoring Remedies SnoreWorld
Is snoring can be cured by surgery? If yes then How?
As per my personal opinion surgery should be the last option to cure snoring. And even it is not sure that it will stop snoring completely. I too suffered with this snoring problem since last two years and I have tried for many options other than surgery. I took consultation through many doctors about my snoring problems, but no result. Finally, I came to know about ASONOR through one of my family doctor and really it's work like any thing else. Right now I am leading a good marriage life. Thank Asonor
What are few methods proven to reduce or completely cure snoring?
In case If your job, relationships, health, and life is affected due to excessive snoring? Mainly this snoring occurs due to lack of sleep which affect the human mood like become more irritable, more prone to tress and less energized through the day. Even over-weight is also one of the prime reason of snoring. Even you can reduce your snoring by changing the sleep position, doing exercises as well. And at the same time you can use ASONOR(snoring spray device). I think it is one of the effective solution for the your snoring problems.
2answers
Is there is any to stop snoring completely and naturally?
If you are looking for the ways to stop snoring naturally, then it is possible in the case when you have the snoring problem in initial stage or we can say low level snoring issue which create little problem or create very low pitch of irritating voice after sleeping.
In case of heavy snoring problem you need to take the help of immediate doctor consultation or medication to get relief from snoring. So I would like to recommend you ASONOR. For more info visit at
Asonor Anti Snoring solution
3answers
What cuases snoring?
Snoring may be occasional or habitual problem. There are many factors that cause snoring.
- Overweight
- Nasal problem
- Lot of alcohol consumption before sleeping
- Sleep apnea
It can be stopped by many different methods which include surgery, changing sleeping habit.
You can also use some device.And try this site to get some good information.
2answers
How could I get relief from snoring?
Eating yogurt before sleeping helps reducing snoring but you might catch cold or have sore throat so there are other few ways you can reduce snoring.some online company provides different ways to reduce snoring or stopping it completely. Experts help you and instruct you what to do and what not to do.
Try this linked companies product and I expect that you will get the help.
4answers
Have there any medicine to stop snoring in night?
there is a permanent way to stop snoring. It is a surgical method in which doctor tighten or trims extra tissue. There are other surgical methods as well. It isn't recommended much and it might take more than one session.many people visit online sites and find almost permanent solution to their snoring habit. From light to heavy snoring anything can be stopped.You can try this site
3answers
What makes people snore and what are the remedies to stop it?
What is snoring?
Snoring, like all other sounds, is caused by vibrations that cause particles in the air to form sound waves. For example, when we speak, our vocal cords vibrate to form our voice. When our stomach growls (borborygmus), our stomach and intestines vibrate as air and food move through them.
While we are asleep, turbulent airflow can cause the tissues of the palate (roof of the mouth) and throat to vibrate, giving rise to snoring. Essentially, snoring is a sound resulting from turbulent airflow that causes tissues to vibrate during sleep.
What causes snoring?
While we are breathing, air flows in and out in a steady stream from our nose or mouth to our lungs. There are relatively few sounds when we are sitting and breathing quietly. When weexercise, the air moves more quickly and produces some sounds as we breathe. This happens because air is moving in and out of the nose and mouth more quickly and this results in more turbulence to the airflow and some vibration of the tissues in the nose and mouth.
When we are asleep, the area at the back of the throat sometimes narrows as the muscles relax, and even close off temporarily. The same amount of air passing through this smaller opening can cause the tissues surrounding the opening to vibrate, which in turn can cause the sounds of snoring. Different people who snore have different reasons for the narrowing. The narrowing can be in the nose, mouth, or throat. Palatal snoring is often worse when an individual breathes through his or her mouth or has nasal obstruction.
What are the treatments for snoring?
The goals for the treatment of surgery may be difficult to determine. The problem of snoring usually is a problem for the bed partner or roommate. Therefore, successful treatment should also include the goal of achieving a successful night\'s sleep for the bed partner or roommate. This makes treatment of snoring a difficult challenge. For example, someone may have a successful treatment if his or her snoring decreases from a jackhammer level to that of a passing truck. If their bed partner is happy, then the snoring problem is "cured." However, another person whose snoring decreases from a mild sound to the level of heavy breathing may still have an unhappy bed partner.
Most procedures to treat snoring are focused on reducing the flutter or movement of the soft palate (roof of the mouth). This addresses palatal flutter snoring. If the snoring originates from behind the tongue or from the lateral walls of the throat, palatal procedures will be less effective.
It is wise to look at the "success" reports for various treatments with a critical eye. If the number of nights that a bed partner has to leave the room decreases from seven nights per week to one night per week, is that success? Some would say that it is. However, the bed partner (or snorer) still has to leave the room one night per week. It is important to know what the expectations for a "cure" are before considering any treatments.
How does snoring a lot at night affect you in the daytime?
Some people snore at night but still wake up in the morning feeling like they slept well. But for some people heavy snoring leads to side effects such as;
1. waking up feeling exhausted the next day
2. difficulty concentrating
3. increased risk of high blood pressure, stroke etc
Snoring can also seriously impact on a partner's sleep as the noise can often stop the person sharing the bed from being able to sleep well.
Top Boiron Health & Beauty Experts
Rob Hill
Rob Hill
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Boiron Health and Beauty Expert? Answer questions, earn points and help others
