Question about Kyocera Fs-3920dn Laser Printer
Kyocera FS-3920DN call service 2000:0011742
My printers is kyocera FS-3920DN and it displays error code call service 2000:0011742 what should be the solutions?
    New Friend:
  • 56 Answers
The call service 2000 is about the main motor. Pull the Developer Unit and then the drum unit out of the printer and check if the gears on both units are moving freely. Then turn the printer on without the 2 units and see if the motor is functioning. If your the motor moving then the message displays on printer will be 7410 (because you have the drum unit outside). There is a possibility that the transfer roller is damaged.
Posted on Sep 23, 2014
  • 46 Answers
SOURCE: Error occurred. Call servoce person. C7980
Waste toner reservoir overflow problem (when the total number of copies is less than 100 thousand sheets) You need a new pcu
Posted on Jun 12, 2009
FixinFax
  • 3085 Answers
SOURCE: Kyocera FS-2000D CALL SERVICE 0150:0171913
Your machine has a FIRMWARE problem. You must call a Copystar or Kyocera Technician to resolve .
Posted on Aug 06, 2009
Evildice
  • 217 Answers
SOURCE: Error code 6000:0106504
Fuser problem, you shall change fures termistor or lamp or both..Good Luck
Posted on Aug 14, 2009
  • 241 Answers
SOURCE: I have a kyocera FS-2000D with error code: Call fo...
Error code 0150 is an engine EEPROM communication error. The engine board might need to be replaced. I have heard that sometimes a defective developer unit could cause this same error code. I would try swaping a develper from a working FS-2000D first.
Posted on Jun 09, 2010
  • 525 Answers
SOURCE: kyocera FS-1016MFP "printer error service
Code: 6000
Contents: Broken heater lamp error
The temperature won't rise by 1°C/33.8
°F during warming up and the heater is
turned on for 5 seconds.
°F during printing and the heater is
turned on for 5 seconds with the duty
cycle more than 60%.
Causes:
- Defective fuser thermistor.
- Broken thermal cutout or heater lamp.
- Defective engine/high voltage PWB.
Posted on Feb 21, 2011
Service error 5100
Straight from the Kyocera service manual.
Main charger high voltage error. Five pages have been printed with the main charger output short-circuited.
Causes: Drum unit installed incorrectly. Engine PWB installed incorrectly. Defective engine PWB.
Solution from service manual:
Verify harness is not pinched in the drum unit.
Verify harness is not pinched in the engine PWB.
Replace the engine PWB.
If you have tried to repair the printer yourself, just go over the reassembly procedure, you might have pinched a wire or one of the connectors might be bent or not in properly.
Regards
Jul 22, 2014 | Kyocera Fs-3920dn Laser Printer
How to reset kyocer 3920 service 7410 01?
Open left door(waste toner bottle)
push drum unit inside.
Jul 02, 2014 | Kyocera Fs-3920dn Laser Printer
Call service Code 4600 KYOCERA FS 8520 MFP
LSU cleaning motor error
When the LSU cleaning motor
is driven, an error signal is
detected continuously for 1 s.
Defective connector
cable or poor
contact in the connector.
Reinsert the connector. Also check for continuity
of the connector cable. If none, replace
the cable.
May 17, 2014 | Kyocera FS-C5030N Led Printer
How do I reset my fs-3920DN printer back to factory default?
go into service mode and print out the maintenance sheet and look for the ucode for factory reset
Apr 24, 2014 | Kyocera FS Office Equipment & Supplies
How can i changethe ip adrees from my kyocera fs 2000d
Here's the manual: http://usa.kyoceramita.com/americas/jsp/upload/resource/19873/0/FS2020D-3920DN-4020DNENOG-ADV.pdf
Go to page 65 for Network configurations directions.
Mar 22, 2011 | Kyocera FS-2000D Laser Printer
I have a kyocera FS-2000D with error code: Call for service 0150:0000049. Help...thanks in advance
May 20, 2010 | Kyocera FS-2000D Laser Printer
Call service 7410:0100539 on a Kyocera fs2000d
I have heard that 7410 is a standard code meaning the drum is out of position. Seat the drum correctly and away you go.
David
www.copycare.net
Jan 21, 2009 | Kyocera FS-2000D Laser Printer
Kyocera FS-1920 error message: "call service 6400:0295998"
Your drum unit is not seated correctly. Look inside for a bent drum ground clip.
Oct 19, 2008 | Kyocera Mita FS-1920 Laser Printer
Kyocera Fs-3920dn Laser Printer Logo
168 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
