Question about LG AN-MR300Q Remote Control AKB73597001
Remote doesn't work
We have had this remote for about 2 years. It frequently freezes and we cannot use it at all. Battery changes help initially or taking them out and putting them back in help for a bit. What other information do you need to help? Thank you, Sara McCue mccues5@yahoo.com
    Genius:
  • 1,114 Answers
It may be that the battery terminals in the remote are not making good contact with the batteries. Make sure the terminals do not have corrosion on them. If there is any corrosion, especially on the flat terminals ( where the positive side of the battery goes) , clean the terminal(s) with a little rubbing alcohol on a cotton swab. The terminals should be shinny. If they are not, first scrape them with a small flat screw driver or anything that will fit, a small knife tip, etc. Then clean with cotton swab. Also make sure the terminals are making good contact with the batteries. The batteries should fit tight. Again, with anything that will fit, try to gently pry the flat terminals out a bit. Hope this works for you!!!!!!!!!!
Posted on Mar 26, 2014
  • Dale Bryant
    Dale Bryant Dec 14, 2014
    remote works need put to sur.sound
Vizio remote xrv1tv doesn' t work. it doesn't do nothing. i replaced batteries.what can i do? used to work perfect almost 2 years. do i need to set up the control? how? thanks
Check the remote control for its infrared emission. If found no infrared emission, check its battery compartment, and clean the battery contacts. If battery contacts have been accumulated with dust or dirt, the remote won't work, as there will be no supply to its internal circuit. http://electronicshelponline.blogspot.com/. Check this link. It has one post, that describes how to check and repair a remote control. Pull up older posts there.
May 05, 2013 | Televison & Video
Ceiling fan remote control doesn't work
Sounds like you have an add-on remote. Try changing the frequency in the receiver & transmitter. If that doesn't work you probably need a new receiver.
Feb 03, 2013 | Hampton Bay Dryers
My Vizio HDTV32 remote control is not working, I changed batteries and doesn't work.
Check its battery contacts for any dust or rust. Clean the contacts first and then check.
Oct 25, 2012 | Vizio New Original VO320E Remote Control
My spectra hv101 rotates but the line is not visible even 2 inches from unit
First be sure to check the obvious such as batteries and cleaning the battery connection points. If that doesn't do it, try freezing the instrument by placing it in a deep freeze for at least 45 minutes. I had two non functioning laser diodes on my 5 point Stanley Laser and for some unknown (to me) reason it worked like a charm.
Sep 16, 2011 | Spectra HV101 Multipurpose Construction...
My dvr freezes. i have picture and sound but unable to change the channel or anything dealing with the dvr. i have to manually push the system info button on the box then select done with the remote. ...
Believe it or not, this could be a simple battery problem in your remote. When my battery is low in my remote, some buttons will work and some not. I'd try replacing the batteries in the remote first. If that doesn't work, I would guess that you need a new remote. Sounds like your DVR works fine manually, so chances are that's not the problem.
Hope this helps.
May 14, 2011 | DISH Network DVR-625 DTV Receiver /...
My remote keeps freezing and i have to take the battery out to restart. Now when I put the battery in it says safe mode. What can I do now
Hi. If your remote is freezing all the time, the firmware probably needs to be updated. Doing this will also get the remote out of safe mode.
1- Click on 'Downloads' at the top of the screen in the software.
2- Click 'Firmware' and follow the steps to update the firmware on the remote.
3- Update the remote.
Hope that helps
-D
Jun 03, 2010 | Logitech Harmony 890 LCD Remote Control
My remote is frozen on 'watch tv'' . device button, help button will not work. off button not working, initial screen to turn on devices does not appear. remote is fully charged
Hi, try updating the firmware in safe mode.
1. Remove the battery, press and hold the 'Off' button, and re-insert the battery. The screen will say 'safe mode'.
2. Connect to the software and click 'Downloads' at the top of the screen.
3. Click 'Firmware'.
4. Update the remote
Mar 20, 2010 | Logitech Harmony 890 Universal Remote
Harmony One USB Connection Problem on Vista PC
HI. So there are a couple of things you will have to ensure for the connectivity to be successful.
1. You are not connected to the internet via a router
2. You are not on a wireless network
3. Any firewalls on your computer are disabled
4. Your USB cable and port are good, and the remote is not connected to a USB hub but right into the compter.
Now, please do the following:
1. Uninstall the software
2. Download it again at http://logitech.com/myharmony
3. Install
4. In your computer's add/remove programs, uninstall the Logitech Desktop Messenger
5. Take out the battery, press and hold the "OFF" button, and re-insert it. The remote will display "Safe Mode"
6. Connect your remote and log in to your account
7. Click "Downloads" at the top and select "Firmware". The firmware on the remote will update.
8. Click "Replace Remote" to conduct a connectivity check.
9. Update the remote.
That should get the remote working. :)
Mar 07, 2010 | Logitech Harmony One Advanced Universal...
Remote doesn' turn n tv or chane channels
try changing the batterys. If its a universal remote reprogram it again.
Oct 04, 2009 | Symphonic ST420FF 20" TV
Initial Setup flashing on and off
1) Do a hard reset = leave unplugged for 12-24 hrs , then
try again.......................................
2) What does "until the remote is disabled" mean ??
Nov 09, 2007 | Sony KV-32V16 TV
LG AN-MR300Q Remote Control AKB73597001 Logo
281 people viewed this question
