Question about Samsung RF265AA Bottom Freezer French Door Refrigerator
How do I attach the internal water dispenser button
Samsung RF261BEAEBC refrigerator with internal water dispenser... the water dispenser started sticking (water would remain on after glass was removed) and sometimes not working. We took the little rubber thing off the front and the button fell out. It was not attached anymore. How do I put it back on so we can dispense water once again? The water works if we hold the little switch in the wall with our finger, but it is very awkward.
SOURCE: Power Cool button works on freezer , but not fridge
He Alisonki! I was having the same problem. On mine the water coil inside the refrigerator keeps freezing which keeps the water from circulating and my refridge won't stay cold. I was told by one repairman that it was a computer problem and you have to order parts from the Samsung Manufactuer which takes about 2 - 3 weeks to get. I am tossing mine and buying a more reliable brand. One repairman came yesterday and left without fixing anything or charging me. Larry
Posted on Aug 14, 2007
  • 441 Answers
SOURCE: Samsung Refrigerator side by side water is
Change your water filter, you should change your filter at least every year or it will start to grow bactria. If you still have the bypass (little plastic cap) you can us that in the mean time to get better water flow, it goes where the filter goes
Posted on Jul 07, 2009
Sea Breeze
  • 4655 Answers
SOURCE: water dispenser
Can you pull you refrigerator away from the wall and carefully remove the cover over the area where the water feeds the refrigerator. There should be a set of plugs one for dispenser and other for the ice maker. Make sure both sides are plugged into the dual water control valve. I did try to pull your model number up so I could help you better, but the model number above your post goes to an oven. Maytag and Samsung sometimes places parts in places that are hard to point out. Tis could also be a dispenser lockout. If you find the problem this would be something that commonly happens an assembly line. If you find the correct model number I will send you a service manual. Either way I am here to help, Thanks,Sea Breeze
Posted on Jan 17, 2010
beamerguy740
  • 65 Answers
SOURCE: My new (2 months) Samsung refrigerator barely
The only thing between the inlet line and the spout?
Water Inlet solenoid, a valve that lets water in. Follow the inlet line to the back of frige. Unplug and turn off water before service. repace valve. EZ FIX...
Posted on Mar 29, 2010
SOURCE: Front ice/water dispenser stopped working.
I had the same problem. Turned out to be a microswitch under the lever used to activate it. The microswitch fell from the original position so it wasn't turning on anything. I tried gluing into position but the fumes from the crazy glue messed up the switch and I had to replace the whole rig.
The part is under the control display. You can pry it open from the left side.
Posted on Jun 04, 2010
The alert ding goes constantly and no doors are ajar
How do I use the digital control panel on my Samsung fridge ...
www.samsung.com/uk/support/skp/faq/1023129
Samsung ElectronicsFeb 17, 2015 - Energy Saver Button. For better energy efficiency press the Energy Saver button. If condensation occurs on the doors turn the Energy Saver ...
Support - 4-Door Flex Refrigerator ... - Samsung
www.samsung.com > ... > French Door
Samsung Electronics4-Door French Door Chef Collection Refrigerator. 4-Door ... Will the Water Dispenser on the French Door Refrigerator Work Without a Water Filter Installed?
My New Samsung Fridge Won't Quit Beeping - eHow
www.ehow.com > Home
Remove bulky food items that might keep the door ajar. ... Samsung refrigeratorsfeature an internal door alarm system to alert you when a door ... The alarm turns off and the beeping stops no matter how long the doors remain ... Therefore you hear thedoor alarm go off in intervals, even though the door is actually closed.
Jan 19, 2016 | Samsung RF4287HARS French Door...
Samsung Refrigerator water dispenser does not work? Ice maker works
The electrically operated valve that opens when you attempt to get water is probably bad. This unit may have one unit with two valves. One each for the ice maker and water dispenser. This valve unit will be in the back of the refrigerator and have a copper or plastic supply line from your house. This line will be "live" so be sure and find and close the valve attached to your house's water supply.
Mar 02, 2015 | Samsung Refrigerators
How to access service Menu on Samsung Refrigerator 26Cf French model RF261 BEAE
look on the internet for a service manual from samsung and goo from there maybe it wants a new memory card fitted
Oct 31, 2014 | Samsung RF261BEAEBC 25.6 Cu. Ft French...
Internal water dispenser rf266ab rubber cover came off and it appears there is a piece missing that holds the plastic piece down to dispence water
Had same problem. Ordered a part that appears to just snap in and replace the broken water dispenser face at this website. http://www.repairclinic.com/PartDetail/Dispenser-Actuator/DA9704952B/2049390
Apr 19, 2012 | Samsung Refrigerators
Replaced DA29-00003B water filter in Samsung Refrigerator (RS2530BBP), with DA29-00003G filter. Water comes out extremely slowly....any suggestions? Tried holding ice type button for 3 seconds and...
Recheck you steps and see the warnings:
1) Turn on the main water supply & shut-off valve of the water
supply line.
2) Run water through the dispenser until the water runs clear
(6~7 minutes). This will clean the water supply system and
clear air from the lines.
3) Additional flushing may be required in some households.
4) Open the refrigerator door and check if water leaks around
the water filter.
Remove any residual matter inside the water supply line after installing filter.
NOTE :A newly-installed water filter cartridge may cause water to briefly
spurt from the dispenser.
Jun 04, 2011 | Samsung AquaPure DA2900003A Refrigerator...
Water dispenser and icemaker stopped working. Does this model have a filter that needs to be changed?
usually the filter is of an in-line type behind the unit or just follow the water supply pipe attached at the rear..1st check the water supply is actuallt getting to the appliance as the system splits internally to supply each function so for both to be not working suggests a water intake fault.. Thanks
Jun 22, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Bad smelling water
The water lines are contaminated with bacteria and/or mold. This is a problem with many refrigerators. You need to turn off water and disconnect the feed line and filter. Mix 4 ounces of Clorox(R) in 1 gallon of water and pump it through with a NEW garden sprayer. You can remove the wand and clamp it onto the water inlet. Activate the dispenser while you pump the bleach through the system. Once bleach starts coming out the dispenser, vent the garden sprayer (de-pressurize), Let the bleach sit for 15-20 minutes. Re-attached water using a brand new filter (do not use the old filter and do not put bleach through filter). Run water until no chlorine odor (it can be a while). This process needs to be done at least once a year.
Jul 29, 2009 | Maytag MFC2061HES Stainless Steel French...
Internal water dispenser stopped working
I lowered the temp on the freezer to 4 overnight, by morning water dispenser is working fine. I think that when we changed the temp to 7 (in order to make more ice ) it froze the water pipe going to the dispenser. I am going to keep both fridge and freezer at 5 ,and hope this will not happen again.
Dec 31, 2008 | Amana AFD2535FES Stainless Steel Bottom...
Samsung RF265AA Bottom Freezer French Door Refrigerator Logo
43 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
