Question about Euro-Pro Kitchen Appliances - Others
Euro pro f1400
Won't come on tried red reset button and made sure it was in the guides there is power to the plug i can here the thermostat click still nothing red reset button seems to be floating around or real loose
  • Bob Belcher Mar 27, 2014
    took it apart and found the wire to one of the element leads was burnt going to fox appliance to get parts hope this does it
3 Suggested Answers
SOURCE: model 1068 fryer - euro-pro
You have to make sure that the control panel slide rails are correctly inserted.
I was very frustrated, and considering I did not have the packaging/receipt, was ready to toss. My Wife slid the control panel/elements out off the pan, then back in, voila!
Posted on Jan 21, 2008
BElectric
  • 1140 Answers
SOURCE: MY EURO PRO FRIER HAS NEVER BEEN USED AND WHEN I
It's likely that you haven't inserted the control panel at the back correctly. Lift it out and slot it back in again. Make sure it is in the rails and insterted fully. This will deactivate the safety switch and you will be able to use the fryer.
Hope this helps. Please let me know if you need further assistance.
Regards,
BElectric
Posted on Mar 15, 2011
Wont start up
Please make sure the tablet is charged for at least 4-6 hours. Also, make sure the correct button is being used, oftentimes we hear the back or home button has been used in error. If the issue persists, you can try performing a power reset. There should a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on.
If your tablet does not have the reset button: With the tablet plugged into the charger, hold the power button for 10 seconds then click the volume up once. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on.
Support Troubleshooting Guide
Mar 23, 2014 | Kocaso M M9100 9-Inch 8 GB Tablet
Power wont come on
Look for a reset button, inspect the cord and if it failed while on make sure whatever it uses for a filter is not blocked with dirt.
Dec 23, 2012 | Shark Euro-Pro Ultra Steam Blaster...
Euro-pro x sews for a little bit than stops
try changing the needle
rethread the machine top and bobbin
try a different bobbin and make sure the bobbin is turned the right
way
also check to make sure the machine is plugged into the outlet
correctly
and also make sure the power cord is plugged into the machine
correctly
and make sure the foot pedal is plugged into the machine correctly
if these suggestions don't help then it's possible that the machine
needs to be serviced
Dec 19, 2012 | Euro-Pro Easy Sewlution 385 Mechanical...
Two red light are blinking and show general error
Hi. My epson T50 printer is flashing together two orange lights showing general error, have reset ink pad with software but still the same problem. Any ideas would be great. Thanks Jim
Mar 13, 2012 | Epson T50 InkJet Printer
Iron doesnot get hot onlyplatform
Try to open the electric iron and locate the thermostat . Secure the electric iron against any metal object that may cause electric shock or short circuit and plug it to a power source. Slowly adjust the temperature and using an electric tester check the power before the thermostat and after the thermostat. If there is a power before the thermostat and has no power after the thermostat then your problem is the thermostat replace it with a new one.
Jul 14, 2011 | Euro-Pro Irons
My whistler pro-73 says "Distortion"
You need to reset the unit to clear that problem. To reset it, press the power and quiet buttons in, while holding in these buttons, plug in the power cord. THe unit will beep twice indicating its reset. the unit will be fine afterwards.
May 14, 2011 | Pro-73 Radar Detector
Wont turn on, plugged in no power
This just happend to ours after my wife changed the oil , appaerntly she did slide the control unit back into the fryer body all the way , there is a switch inside the slot on the control unit, when properly put back together and slid down all the way it will close the circit so the unit will get power (thats what was wrong with mine , after disasembling the whole friggin thing ...lol......also there is a red reset button in the back , acualy looks like a screw would be there , but its a button in one hole make sure its pushed in.
Jan 25, 2011 | Euro-Pro F1066 Deep Fryer
Where is the reset button on shark navigator. vacuumed throw rug, and bar wont move
I'm not sure it has one. Check the owner's manual though.
Try this. Turn off vacuum. Unplug it. Make sure there are no clogs in main hose, power head intake tube, or intake inside tank. Plug it in, turn it on, and let us know what happens.
Aug 23, 2010 | Euro-Pro EuroPro Shark Navigator Vacuum
Fryer will not turn on
There's a red reset button that you need to press, it is hidden deep inside a well in the plastic piece. The well looks just like a screw hole until you know what to look for. Once you press it and your power supply is attched right you are golden.
Apr 19, 2008 | Euro-Pro F1061 Deep Fryer
Model 1068 fryer - euro-pro
Mar 27, 2007 | Euro-Pro F1066 Deep Fryer
Kitchen Appliances - Others Logo
Top Euro-Pro Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Gerry Harvey
Gerry Harvey
Clarice Bornschein
Level 1 Expert
Are you an Euro-Pro Kitchen Appliances - Other Expert? Answer questions, earn points and help others
