Question about Nikon D90 Digital Camera with 18-200mm lens
On off mode light blink and battery discharge
    Novelist:
  • Nikon Expert
  • 357 Answers
This is an indication of a short in the DC to DC board in the bottom of the camera, either from a floating screw or impact damage. Unfortunately, Nikon stopped selling parts over a year ago to everyone. You can remove the bottom cover (remove back cover first) by gently prying up the rubber covering screws on the bottom. Pry up just a small section and then put some alcohol at the attached edge and move it back and forth slowly with a removal tool. If you just rip off the rubber it will stretch and will not fit back properly. Check the board very carefully with a magnifier. There is a small surface mount IC with 6 pins that usually blows on this board. You may be able to find the board on EBay but they have been drying up on Nikon parts.
Posted on Jun 03, 2014
Amber flashing light while on home base. New, pulled tab, placed on dock. First time said charge err1, took out battery and replaced. Now just flashes amber. Is this correct?
Your manuals are here. Flashing lights must be covered. A quick look at the site says flashing red is bin full. In fact, I found it. Flashing Amber is CHARGING.
Roomba 600/500 Battery and Charging Overview On some robots, the CLEAN light should pulse red/amber while charging. ... Amber - partially discharged; Red - nearly discharged; Flashing Red - discharged . homesupport.irobot.com homesupport.irobot.com/.../roomba-600%2F500-battery-and-charging- overview LabeledSupport ... clipped from Google - 12/2015 iRobot: Customer Care - Roomba 700 Anatomy homesupport.irobot.com homesupport.irobot.com/app/answers/.../a.../roomba-700-anatomy images?q=tbn:and9gcss8oogw3vmcv_uom0z_pxoi9q5tq9n4aqrcwbsxn0zd1blfvnacictdbyn iRobot: Customer Care - Roomba 700 Anatomy Solid Red = Battery Discharged; Amber Pulse = Charging; Solid Green = Fully Charged; Quick ... The battery indicator blinks when there is a charging issue. homesupport.irobot.com homesupport.irobot.com/app/answers/.../a.../roomba-700-anatomy LabeledSupport ... clipped from Google - 12/2015 iRobot Roomba 500 Series Battery Maintenance homesupport.irobot.com homesupport.irobot.com/ci/documents/.../042809_500MaintBatt_vib iRobot Roomba 500 Series Battery Maintenance Roombas "CLEAN" light should pulse red/amber while charging. ... Green - fully charged; Amber - partially discharged; Red - nearly discharged; Flashing Red - ... homesupport.irobot.com homesupport.irobot.com/ci/documents/.../042809_500MaintBatt_vib LabeledSupport ... clipped from Google - 12/2015 Roomba 400 Series/Discovery Battery and Charging Overview homesupport.irobot.com homesupport.irobot.com/.../roomba-400-series%2Fdiscovery-battery-and- charging-overview Roomba 400 Series/Discovery Battery and Charging Overview Your Roomba's POWER light should pulse red/amber while charging. ... Amber - partially discharged; Red - nearly discharged; Flashing Red - discharged. homesupport.irobot.com homesupport.irobot.com/.../roomba-400-series%2Fdiscovery-battery-and- charging-overview LabeledSupport ...
iRobot Owner Manuals and Quick Start Guides
Dec 31, 2015 | Roomba Vacuums
Why is Battery Light blinking on Hoveround
Generally, the blinking battery light means that the drives are not fully engaged. Pull up hard on the two levers to engage the drive motors.
Jun 06, 2014 | NRS Hoveround MPV 4 - Hovaround Used...
On off mode light blink and battery discharge in d 90 nikon
Nikon is on Wilshire in Los Angeles do not try to fix your D90 by yourself it is a complicated computer they fix it for free if it is under warranty and they send it back to your house when repaired.
PS it cost more when you take it elsewhere small repair shops send it to Nikon too. Good luck.
Mar 26, 2014 | Nikon D90 Digital Camera with 18-200mm...
FULL CHARGE LAST 5MIN. MAX
My guess is the batteries are probably no good. All batteries will only last so long and it also depends how often they are keep charged and discharged. Basically all batteries require some kind of maintenance (recharging / discharging).
Jan 23, 2013 | SPOT SL5W09 Spot Light
My Stanley Ultra Bright Spotlight will only blink when I press the button
My guess is the batteries are probably no good. All batteries will only last so long. And it also depends how often they are keep charged and discharged. Basically all batteries require some kind of maintenance (recharging / discharging).
OR the electronic controller is bad.
Apr 15, 2012 | SPOT SL5W09 Spot Light
Status light is red, why? I have a Roomba Discovery.
Hi.
If the red light is solid, that means that the Roomba is near to full discharge. If the light is flashing red, then the Roomba is completely out of charge.
If the Roomba is fully charged, then there may be a fault.
Here full list of light codes:
Pulsing Amber - Charging
Green - Fully Charged
Amber - Partially Discharged
Red - Almost Fully Discharged
Flashing Red - Fully Discharged"
Here manual
See also
Roomba DISCOVERY MODELS' DIAGNOSTIC TESTS
May 24, 2010 | Vacuums
Bettary problem or adaptor problem?
ac/dc convertor board inside laptop faulty.
May 31, 2009 | Dell Inspiron 1300 Notebook
IBM r51 battery won't charge. How to confirm if battery is good?
once u hold the battery and see it has to be cool,if not it as to be changed it has become old.
thanks
Jan 31, 2009 | IBM ThinkPad R51 Notebook
Compaq presario laptop blinking power button
REMOVED BATTERY AND CHECK ONLY IN AC MODE
IF ITS START PRESS F8 AFTER BOOTING AND OPEN IN SAFE MODE
Jun 21, 2008 | Compaq Presario Notebook
Nikon D90 Digital Camera with 18-200mm lens Logo
109 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
