Question about Samsung ML-4050N Laser Printer - Monochrome - 40 ppm Mono - 1200 x 1200 dpi - USB, Parallel - Fast Ethernet - PC, SASML4050N
Samsung ml-4050n very high noise
In warming up or copy mode very high noise in generating from deve motor side. if we remove developer assy from the machine, it runs smoothly.
  • 790 Answers
Check the area on and around the developer assy for paper or maybe a staple ( paper clip )
I would power blow out the complete system and re-assemble.
Posted on Apr 29, 2014
Please tell me how to fix SC324 error code on Ricoh Mp4001
Developer assy locked up, its the lower part of the drum assy. Open right door turn gray handle to right and pull assy out.-Carl
Jan 22, 2018 | Ricoh Office Equipment & Supplies
Konica minolta 7255 error code sc 28-02
Below the drum is a assy. which has two/three very fine wires each carries a High Voltage (Only) during the copy process. the paper goes between these wires and the drum. The wires allow the paper to steal the image off the drum. Well these wire can become dirty, so they have a motor that runs a small cleaning pad across them, your code deals with that open the center section should see the assy. might be the one of the cleaning pads is stuck, the pads work go from one side (Rear to front/front to rear) to the other and back job done. Is the pad in the middle or stuck.
Remove the assy. and bring the pad to the front. Also can allow the motor not to do anything. In service mode 25.
Mar 17, 2015 | Konica Minolta Office Equipment & Supplies
Blank print is comming
REPLACE LSU OR HIGH VOLTAGE POWER SUPPLY
Mar 01, 2014 | Samsung ML-4050N Laser Printer
How can fix this code C-2105 in konica minolta bizhup 600
C - 2105 Transfer/separation corona cleaning motor home sensor error code.
Remove the transfer/separator corona located in ADU assy,use the vacuum cleaner and clean the corona support and the 2 sensors(located under corona assy rear and front area).After cleaning urn ON the copier and is working.
Mar 16, 2013 | Konica Minolta Developer 02xk Dv710 for...
Only system initializing but not warming. and cannot print the page. even click on the menu button also no respond. hang.
It is most likely the power supply. Check for bad capacitors or get a replacement power supply board.
Jun 29, 2011 | Samsung ML-4050N Laser Printer
Open heat error cycle
http://downloadcenter.samsung.com/content/UM/201001/20100125112123500/Guide_EN.pdf
On page 50 of the user manual it says this is a fuser error and how to fix it. Hope this helps.
Feb 27, 2011 | Samsung ML-4050N Laser Printer
How to replace fuser on samsung ML-4050ND
Call a printer technician to replace the fuser drum for this laser jet. Most of these part are replaceable and can be purchased anywhere.
Nov 11, 2010 | Samsung ML-4050N Laser Printer
Samsung clx-3175fn "deve home positon error"
The developer home error is due to developer home unit itself and has to be replaced. can be done by Authorised service person.
May 29, 2009 | Samsung CLX-3175FN Color Laser All-in-One...
Samsung ML-4050N Laser Printer - Monochrome - 40 ppm Mono - 1200 x 1200 dpi - USB, Parallel - Fast Ethernet - PC, SASML4050N Logo
44 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
