Question about Fisher and Paykel Active Smart E522B Bottom Freezer Refrigerator
Ice forms as large block not in cubes
The water is pouring straight in the ice container without making ice first. We just get a large solid block of ice. It continues to do this even thought we keep tipping out the ice and starting again, we have turned off the fridge and restarted it, no luck
  • 40 Answers
Defrost thermostat is bad. Defrost element is staying on for too long raising up temperature causing ice to melt.
Posted on Apr 03, 2014
IFIXALL
  • 868 Answers
SOURCE: ice maker dumping ice before it's frozen
Please call your Manufacturer for Warranty!!! You pay a great deal in the cost, so you should not hesitate to call.It will cost you ZERO $ PLEASE RATE THIS ! THANK YOU!
Posted on Jun 06, 2008
marka19
  • 1430 Answers
SOURCE: Our E522B Fisher & Paykel fridge no longer making ice?
Try the video on checking the F&P icemaker.
www.appliancehelponline.com/servicemanual.html
Posted on Feb 27, 2010
  • 10865 Answers
SOURCE: The ice maker does not seems to dispense any ice.
The fix to your problem is to remove the ice, warm up the tray with a hair blow dryer and thoroughly dry it. Then spray it with PAM cooking spray which is an edible lubricant. After that dries, turn on the ice maker again and the ice will dispense. Joe
Posted on Mar 08, 2010
SOURCE: Hi, I have a fisher
I had the same problem. my freezer was set too cold so the water inlet was freezing. what I did was blew a hairdryer into the ice making section for a couple minutes, this seemed to melt the block, then tested that it was clear by forcing the ice tray through a cycle. you then need to set your freezer warmer - I find setting it 2 bars from the warmest setting keeps stuff frozen and the ice coming :) hope this helps!!
Posted on Feb 01, 2011
imufo2
  • 3773 Answers
SOURCE: Our FP refrigerator is about
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Posted on Aug 08, 2011
Water collecting in the water compartment
what is question as well as make ,model of unit
Nov 13, 2016 | Refrigerators
Hi have LG fridge, ice maker making ice but freezes into one solid block instead of staying in individual ice cubes making it impossible to dispense do you have any ideas a sto why this is happening and...
Sounds like this is a water level problem. Too much water is being released into ice tray, which raises the water level above the depth of each cube form, causing one big cube. You can adjust the water level.
Check this out:
How to Adjust the Water Level on an Ice Maker eHow
Jul 19, 2014 | LG LSC26905TT Side by Side Refrigerator
Water doesn;t stop
I don't know a lot about this machine but it could be that the water inlet value is not working correctly
Apr 07, 2014 | Franklin Industries Franklin Chef Ice Cube...
We accidentally left the freezer door just barely open overnight. The freezer started to thaw somewhat, but we caught the problem before anything had to be thrown out. In other words, there wasn't a lot...
yes ice formed in the bottom of the ice bin locking the auger from turning to dispense ice. Defrost the ice bin and wipe clear of any left over water from the melt.
Appliance 911 Sea Breeze
Mar 14, 2017 | Whirlpool Refrigerators
Frozen solid cube tray
Unplug the frig. Take a hair dryer and melt the ice tray. Then get a paper towel and soak up the left over water. hope this helped
Mar 30, 2010 | Refrigerators
Arctica won't make ice; ice was frozen solid yesterday. After removing, it won't make any more ice cubes.
As long as the ice trays are filling with water, it's not actually the function of the ice maker to make ice. Ice simply forms because the freezer compartment is cold.
The icemaker's function is to sense when ice is formed in the trays and to dump the ice into its container.
This requires the use of a thermostat to sense the water/ice temperture and 'tell' the icemaker when it's time to dump the ice.
During the dump cycle, a heater briefly comes on as the arm swings through the ice cube compartments to assist in loosening the ice cubes and make them easy to dump.
If the icemaker is filling with water but you get no ice, I suspect that either the control circuit (thermostat, relays, and wiring) is not 'telling' the heater to come on, or the heater is burned out.
Some units also have a timer circuit such that both the timer contacts and the thermostat contacts must be close in order to initiate a dump cycle (i.e., it must be time to dump and the water in the cubicles must be frozen).
A skilled homeowner could make these repairs, but if you don't feel comfortable taking your icemaker apart and testing the components, I advise leaving the job to a qualified repairman.
I hope this helps. Good luck.
Sep 12, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Too much water in amana bottom freezer ice maker
Try closing the valve partially on the incoming water to the icemaker. Close it to a trickle. Water is fed to the icemaker by a short timer. Too much water pressure means too much water. If this helps it but not solve it, get the spec sheet for the icemaker and adjust to make cubes smaller. This shortens the timer. If no joy, you may need to replace icemaker module.
Sep 01, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
GE Ice Maker that leaks water down the freezer wall
Ice makers have limit switches, thermal temp sensors, heating element and if anything gits out of order with these parts they will begin to do strange things like that. Now if you would like to remove it and have a look at the internal parts you may find the problem. They are a little easy to loose parts so be careful if that's your choice. A series of about six different cycles happen when they fill until the time it empties and begins again. They may cost less if you don't see what wrong to purchase a new ice maker. If you would like more help feel free to ask, Thanks, Sea Breeze
Apr 20, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Water leaks into storage bin
open the machine control panel side and cube adjustable thermostat available in side,adjusted in the thermostat screw
Jun 22, 2008 | U-Line Icemaker
Fisher and Paykel Active Smart E522B Bottom Freezer Refrigerator Logo
106 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
Charles T Nevin
Charles T Nevin
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
