Question about Whirlpool Cooktops
WhirlpooL gjc3634R502 The indicator for the stove hot does not come on and the indicator for on/off stays on all the time. all of these worked before I changed the Infinite switch because 1 burner was out.
  • Whirlpool Master
  • 842 Answers
Recheck the wiring to that switch you replaced, the light circuit was wired wrong, some switch have moved terminals on them so recheck them all.
Good Luck
Posted on Apr 02, 2014
huuum
  • 750 Answers
SOURCE: Three of my Jenn Air burners (electric) only work on High - OLD
Hello
Welcome to Fixya
My name is Huum,
you can find the schematics, diagrams and parts here at this site . just enter the complete model number that is written on the stove sticker and access the info
http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080204x00001a
Please remember to leave a rating before you leave
Posted on Dec 11, 2008
SOURCE: Whirlpool Flat cooktop burner not heating up
Try cleaning the knobs. I did the same thing you did (turning the circuit breaker off but that did not solve the problem.
My wife just tried turning the knobs and that seemed to work. It appears that one of the knobs may have been so sticky that the though it's in the OFF position it thinks it's still ON.
Posted on Mar 05, 2009
  • 3 Answers
SOURCE: 5 burner tappan stove. oven takes a long time to
By this description you gave it sounds as your oven burner has a flash back ,when it is like that does your flame look very yellow and gives off a Funny Smell ( which i Will think it is CARBON MONOXIDE . Remove the Oven burner make sure you watch for any wires attached to the burner (yes even in a Gas Stove) that would be part of your safety device . Make sure there is NO Rubbish in your Burner and your Burner
Well . Clean it out Make sure your Injector is Clear Carefully replace your Burner Making sure it fits over the Injector ,Replace any wirer if you removed any and relight
Posted on Jul 23, 2009
motor1258
  • 6674 Answers
SOURCE: whirlpool stove top- two problems. 1) burner is
If all other burners working as they should, I'd check that bad one for partially plugged orifice. Try poking a small piece of wire through orifice hole to clean it. As far as igniter goes, and they are all connected to one source for spark, and separate wires run to each, make sure there is no breaks in small wire, as well as check that little ceramic igniter has a clean tip, if not clean with nail file or sand paper, and make sure it is same position at burner as others, as in close enough for spark to arc across to burner. if still no spark, try swapping wire with another, if it works, change wire, if not replace little ceramic piece at burner.
Posted on Aug 08, 2009
milten1
  • 1304 Answers
SOURCE: LIGHT STAYS ON FOR HOURS BUT THE TOP HAS COOLED
if its going out, its probably ok
its not a light indicating the burner is on, rather that the glass is abcove 100 degrees and still not safe to put something on
2 hours is a bit long but it depends on how fst the surface can cool of
you can test this by trying to cool it off faster with a fan ans see what happens
Posted on Oct 21, 2009
Testimonial: "THANK YOU FOR GETTING BACK WITH ME QUICKLY YOU GAVE ME SOMETHING TO CHECK FOR AND I WILL LET YOU KNOW HOW IT WORKS"
Cook top indicator lights stay on long after it has cooled off. The largest cook circle sometimes doesn't reduce heat when the dial is changed
Cook top indicator light will stay on as long as the stove is hot I think. Also, the burners don't heat real steady? or evenly or true to their settings even, quite often. they also take a really long time to cool down as well as to adjust temperatures, so it may just be that it is taking an awfully long time for it to cool down in order to adjust.
Apr 04, 2015 | Cooktops
I am having intermitent problems. If hot water spills onto the surface of my ceran surface, all the controls start flashing. The same thing happens every now and then when I just wipe the surface wi
Lift the top of your stove, then look for a connector or plug, wire that has pushed up near or against the stove top. Where the wires connect to the burners one or more may be loose an needs tightening.
Mar 26, 2014 | Whirlpool Cooktops
We have a WLP83800 Whirlpool ceramic-top range. The indicator light for the left front element now stays on even with the control for that element in the off position. As well, the element doesn't...
We are very sorry to hear this Jedpaquette. Unfortunately we are not able to provide technical assistance. If you would like for us to schedule service for you then please email us your name, phone number, address, the model and serial number and the website you were contacted on (Fixya.com) to Whirlpool_Digital@Whirlpool.com.
May 09, 2017 | Whirlpool GJC3634HQ Electric Cooktop
Hot surface indicator stay on.
spring tension issue....adjust the tension :)
Feb 06, 2011 | Whirlpool RCC3024 Electric Cooktop
The surface light on my mothers stove stays on and all burners are off and cold any ideas why
Here is a tip that I wrote about why the hot surface indicator light will not go out...
Oven Hot Surface Indicator Light stays on
heatman101
Jan 18, 2011 | Maytag Cooktops
Oct 21, 2009 | Whirlpool RCC3024 Electric Cooktop
Whirlpool ceramic cooktop
Scott,
On each of the heating elements there is a thermostat that does two things. It is a high limit safety thermostat and then a different set of contacts turn on the hot surface light. Unfortunately, you can't just replace that part. You will need to isolate which element it is with a mutimeter and replace the entire element.When you turn one of the units on high you will see a dark line under the glass running 1/2 way across the elements. Those are the thermostats... Find the defective one and the rest is pretty simple to replace
Dec 18, 2008 | Whirlpool 30 in. RC8700 Electric Cooktop
Cooktops Logo
91 people viewed this question
Top Whirlpool Cooktops Experts
Timllfixit
Lakeland Appliance...
Are you a Whirlpool Cooktop Expert? Answer questions, earn points and help others
