Question about Casio Privia PX-350 88-key Digital Piano
Casio privia key too loud
Key too loud
5 Suggested Answers
  • 5603 Answers
SOURCE: I have a Casio Privia PX-320. The left side keys
Check that the front of the keys is not hitting the lower plastic case front. If they hit it, then you need to disassemble the case partly and see what has shifted. It is ALSO possible that something has caaaused the aftertouch sensor to move out of position and it is hitting the keys early. ANY of these conditions needs to be addressed before damage is done.
Posted on Dec 01, 2009
  • 5603 Answers
SOURCE: My Casio Privia PX-110 is playing two notes at
IF every key sounds like it is doing that, you may have two voices selected with one of them being transposed.
You may have an "effect" turned on that generates a chorus, layered or multiple voice sounds.
Posted on Dec 10, 2009
  • 5603 Answers
SOURCE: casio privia key issue
The only way to analyze this is to open the case. You may find contaminating material has gotten in, or broken part, or key slightly out of position on pivots or pivot plastic broken.
When opening, be VERY careful of the tender ribbon cables. Have a large work surface that you can unfold the top onto. Be careful to use correct screw lengths and thread in each place you removed.
Posted on Apr 27, 2010
  • 5603 Answers
SOURCE: Casio Privia PX-130, 8 months old: fluttering sound
If I were to venture an educated guess I would vote for failing filter caps in the power supply.
The power is likely collapsing under load of the speakers but headphones take much less drive.
If this has an external wall-wart power supply, you might try a new one IF the output is found to be under the rated voltage.
Internal power supply components are beyond those individuals that are not adept at electronics.
Posted on Jul 14, 2010
How do you connect a casio privia px 330 usb to ipad 2
Casio don't supply PX330 drivers for IPAD.
Get a Windows 8.1 tablet or connect PX330 to a desktop PC and use IPAD to Remote control that PC.
Apr 27, 2014 | Casio Privia Px330 Px-330 88 Key Digital...
One key sounds louder than the others
Hi, This is very likely to be a dirty key contact.
If the loud key is not touch sensitive or by turning the touch off, if all the keys are the same volume then this points to a dirty key contact.
All the best, Chris the Fader.
Mar 08, 2014 | Casio Privia Keyboard Case
Casio privia px-750 how to do a factory reset?
HIS WORKS ON MOST. Turn the keyboard off.Hold the C note down at the far right of the keys.The very last C note.Keep holding it down and turn the keyboard on.
Jan 19, 2014 | Casio Privia PX-750BK - 88-Key Digital...
Is it possible to disable the speakers on my Casio Privia?
YES. Either plug in headphones into the headphone socket. There should be a switch on the back which disables the speakers as well. A simple ON/OFF switch for speakers
Aug 10, 2013 | Casio Privia Px-130 Px130 88 Key Digital...
How to fix loud key on Privia PX-830
I just fixed mine, it was making the loud sounds and had seemed to have lost the sensitivity. Take out all the screws on the outside, then the sides can come off. That gives access to the inside where you can take out a few more screws (easily seen) and open it all up. The keys themselves just snap in, so two small screwdrivers or strong fingernails can pop them back out. Clean the rubber contacts (they look like little sockets) with Q-tips and rubbing alcohol, then replace the keys. If you take out the white keys of an octave first, then the black keys (keeping them in order) it is a lot easier.
Jun 18, 2012 | Casio PX-830 BK Privia
I have a Casio Privia PX-130 and I tried to turn it on and it wouldn't turn on. I have noticed lately that when I would be playing a song that when I pressed a certain key that it would make this...
Test the adapter with a meter... Most probable cause is a bad power connector. Often the solder at the input power connector breaks loose is only problem. If you are not electronically adept, best to take it to a shop.
Jun 27, 2011 | Casio Privia Px-130 Px130 88 Key Digital...
How to adjust the metronome on casio privia
You hold down the function key/button and then use the PIANO keys with the "tempo" shown above them.
In that section of the keyboard, the C# key raises the tempo and the C key lowers it. You can also use the numbered keys in that section to dial up a particular value. Hold function down and strike the numbers you want then release the function key/button
I don't believe there is an adjustment for loudness of the metronome other than the overall loudness of the piano..
Mar 26, 2010 | Casio Privia Keyboard Case
Nov 30, 2009 | Casio Music
Casio Privia PX-350 88-key Digital Piano Logo
138 people viewed this question
Top Casio Televison & Video Experts
Lawrence Oravetz
Brandon Murphy
Are you a Casio Televison and Video Expert? Answer questions, earn points and help others
