Question about LG Televison & Video
42lc46 zc Switch on tv all OK for 5 minutes, then picture goes off ,flashes on and off for 15-20 minutes then rights itself ,perfect picture. Any ideas
    Top Expert:
  • LG Master
  • 74,482 Answers
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Posted on Mar 27, 2014
  • Rich Fitch
    Rich Fitch Mar 27, 2014
    The standby/power led stays on , it's the picture that "flashes"
SOURCE: tv keeps disconnecting from digital tv, returns within 5 seconds but highly annoying! pictue goes blank and sounds goes aswell , almost like the tv has turned off only to restart itself
It sounds like it is loseing signal, check your connections, and make sure you have the correct cable
Posted on Jun 01, 2009
  • 159 Answers
SOURCE: Picture judder on Pioneer plasma TV
i wouldn't be worry if:
If the tv just does this phenomena for some seconds specially when there is a change from video analog to digital.
if the tv does the issue only for some seconds and then gets back to normal and stays there for the rest of the day.
Posted on Apr 09, 2009
SOURCE: black bar
On a non H.Def plasma, there is a PCB that runs along the bottom of the screen that is attached to the screen by a several brown/gold colored flat ribbon cables. I've seen where this ribbon cable is not seated properly in the jack. The ribbon cables are generally responsible for that section of the screen. Next possibility is the PCB itself is defective.
Not to scare you, but the plasma screen itself is a possible suspect.
Posted on Jul 31, 2008
romsky79
  • 822 Answers
SOURCE: I have a RCA L32HD32D, will be on for 1 to 5 min. later goes off
check secondary power supply. check capacitors and apply fresh solder.
pjbaldi
  • 8 Answers
SOURCE: dynex 32" tv picture goes black
If there is still about ? 24. Volts coming from the Power Board when it goes dark, it will be the Inverter board that needs replacing. If not, it is the Power Board that needs replacing. The Voltages should be written next to the sockets & plugs on the Power Board.
Posted on Jun 02, 2010
My FINLUX tv flashes on standby 5 times continuously until it turns itself off...no picture or sound?
if tv is still working ok, do a reset! unplug power from wall and wait 20 minutes! Plug back in and hope all is well, good luck!
Jun 12, 2017 | Finlux Televison & Video
I've been having a few problems with my LG
Good morning to you! When the screen goes black, have you tried to go into setup on the remote. Adjust the brightness of the screen. Or as I am sure you have done to restart the TV when the warning sign comes on the screen that the TV will go off affter 5 min. The classical action is to disconnect both the router and the box that keeps all the stations in it. Disconnect for 2-3 minutes, connect again. I do apologize for not knowing the name in English. ( english is not my mothertounge) Hope this can help you on the way. Then there is always the user manual that can be downloaded free and look in the troubleshooting page. ( I did that the other day, had lost the paper onr) Kolbrun
Sep 18, 2013 | Televison & Video
LG 42LC46 ZC AECVLJG about 6 years old, we r having trouble switching it on. There is no red light on or sometimes it flashes on and off, usually it has been a good set. we r with sky and HD, ca
The most likely cause of this problem is the power board.
Take the cover off, make two-three good high-resolution up-close shots from different angles and send them so we can tell you if there are visible issues with it.
For more detailed troubleshooting you'll need a voltemeter and tons of patience.
http://www.coppelltvrepair.com
Oct 15, 2010 | LG Televison & Video
Panasonic th-42pw6 plasma TV switches itself off intermittently
i think the power ic needs a replacement.
the possition is ic551 and is named strf6668
Apr 06, 2010 | Televison & Video
TV popped and shut off red light flashes 5 times then pauses
this specific type of TVs flash their standby light if the onboard testing system sniffed out a problem
so, as if your TV is trying to tell you "i have a problem and i need to be serviced"
i hope it goes well for you
:D
Aug 30, 2009 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Samsung HLP4674W - changed bulb - still no picture - lights flash
If the lamp has been replaced I would think the Lamp ballast would be most likliest followed by the color wheel and then the Digital board. You can get any part needed for your model at www.tvrepairworld.com just leave them a email they respond quickly.
Aug 28, 2009 | Samsung HLP4674W 46" Rear Projection HDTV
Screen Goes Green TV goes to stand by blinking 8 times
try adjusting your color tuners located inside tv behind speakers.
Nov 25, 2008 | Sony KP-57WS500 57" Rear Projection...
Tv turns off at irregular intervals
MOST PROBABLY DRY SOLDER IN THE POWER SUPPLY SECTION OR REPLACED THE HORIZONTAL DRIVER TRANSFORMER . MUKU
Oct 16, 2007 | Durabrand DWT1905 TV
Televison & Video Logo
61 people viewed this question
Computer Repairing
Computer Repairing
