Question about Music
Privia px150 One key is very loud compared to all the other keys, even if played softly this key is loud
  • 1138 Answers
SOURCE: The middle E key seems to come on at full volume
The contact under that key in the contact membrane is probably needing to be cleaned or replaced. It can be done by you but requires disassembly of the keyboard and removal of the key and adjacent keys to take the contact out. Rub the contact and the place on the circuit board where it makes contact with a pencil eraser and clean the residue off with isopropyl and a qtip. The membrane comes in strips and is replaceable if you can still get the p[arts. You might be better off to consider having it serviced. Hope this helps.
Posted on Aug 17, 2009
Testimonial: "Thank you for your quick response. I will have a go at this repair very soon and advise you should I have any difficulty. "
  • 5603 Answers
SOURCE: I have a Casio Privia PX-320. The left side keys
Check that the front of the keys is not hitting the lower plastic case front. If they hit it, then you need to disassemble the case partly and see what has shifted. It is ALSO possible that something has caaaused the aftertouch sensor to move out of position and it is hitting the keys early. ANY of these conditions needs to be addressed before damage is done.
Posted on Dec 01, 2009
  • 5603 Answers
SOURCE: My Casio Privia PX-110 is playing two notes at
IF every key sounds like it is doing that, you may have two voices selected with one of them being transposed.
You may have an "effect" turned on that generates a chorus, layered or multiple voice sounds.
Posted on Dec 10, 2009
rajeshpait
  • 542 Answers
SOURCE: 7 of the keys on the upper end of my privia px-100
It may due to faulty circuit board of the keyboard. Check for warranty and ask the vendor to replace the keyboard.
Posted on Dec 15, 2009
  • 5603 Answers
SOURCE: casio privia key issue
The only way to analyze this is to open the case. You may find contaminating material has gotten in, or broken part, or key slightly out of position on pivots or pivot plastic broken.
When opening, be VERY careful of the tender ribbon cables. Have a large work surface that you can unfold the top onto. Be careful to use correct screw lengths and thread in each place you removed.
Posted on Apr 27, 2010
C key is sunken down. The hammer action counterbalance isn't working properly
Check it again. It may have something dragging on the key, maybe something sticky like soda or juice residue. You can also try swapping out the key with another C or F key that is less used. Good luck!
Sep 24, 2016 | Casio Privia PX150 Digital Piano
How do I remove the cover to fix a popped-up key?
Fixing the keys on digital piano. try to watch the video maybe there is a tips to fix your piano. thanks
Dec 26, 2015 | Casio Privia PX150 Digital Piano
What is causing noise in the keys of privia px350?
Try using a can of pressurized air to clean around the keys that are noisy.
Jun 10, 2014 | Casio Privia PX-350 Digital Piano Black...
Casio Privia 410r Piano soft pedal problem
The Casio Privia 410r has two pedal jacks at the back. One is the sustain pedal, the other is the soft/sus jack. Please use the other jack if you want to use sustain pedal. Only 1 of the 2 jacks can be used.
However, if you have the optional sp30a pedal which plugs UNDER the piano instead, then only can you have 3 different piano pedals.
May 18, 2014 | Casio Privia Px330 Px-330 88 Key Digital...
How do I unlayer notes on my casio privia 150 digital piano
I assumed you mean a PX150. Here is a link to a manual for that but I found nothing for a privia 150. It looks here to me on page 19 that you choose track 1 or 2 which seems to be left or right and if you start new recording on one of them, it deletes what was there.
http://www.fixya.com/answer/answerpageslideview.aspx?ctg=249&fml=0&brd=0&p=7&ctrl=mnf&thid=23710754
Mar 03, 2014 | Casio Music
Today I received my new Privia px830 and three keys works as an interruptor: play notes at full intensity. Are sensors cracked?
The sensors are rubber, and don't usually crack. Most of the time they are dirty and can be cleaned with rubbing alcohol and Q-tips VERY carefully. Also be careful of the ribbon wires inside the keyboard. The keys should just snap in and out. I cleaned mine a little while ago, and now it works perfectly.
Jan 06, 2013 | Casio PX-830 BK Privia
How to fix loud key on Privia PX-830
I just fixed mine, it was making the loud sounds and had seemed to have lost the sensitivity. Take out all the screws on the outside, then the sides can come off. That gives access to the inside where you can take out a few more screws (easily seen) and open it all up. The keys themselves just snap in, so two small screwdrivers or strong fingernails can pop them back out. Clean the rubber contacts (they look like little sockets) with Q-tips and rubbing alcohol, then replace the keys. If you take out the white keys of an octave first, then the black keys (keeping them in order) it is a lot easier.
Jun 18, 2012 | Casio PX-830 BK Privia
Casio Privia px 130 One of the keys (e4) sometimes playes at full velocity even when pressed lightly. It happenes vary regularly which means I can no longer rely on the key playing softly. It is...
One of the two contacts for that key is not working. This could be dirty or damaged contact. They use a conductive rubber pills that the key presses against circuit board traces. One contact makes before the other and this is how velocity is sensed. Unless you are adept at this repair, I would recommend you take it in for repair. Chances are any part cost is negligible... mostly labor to open and access the contacts for cleaning. Clean ONLY with 99% isoprophyl alcohol and Q TIps... VERY GENTLY.
Jul 02, 2011 | Casio Privia Px-130 Px130 88 Key Digital...
I have a Casio Privia PX-130 and I tried to turn it on and it wouldn't turn on. I have noticed lately that when I would be playing a song that when I pressed a certain key that it would make this...
Test the adapter with a meter... Most probable cause is a bad power connector. Often the solder at the input power connector breaks loose is only problem. If you are not electronically adept, best to take it to a shop.
Jun 27, 2011 | Casio Privia Px-130 Px130 88 Key Digital...
How to adjust the metronome on casio privia
You hold down the function key/button and then use the PIANO keys with the "tempo" shown above them.
In that section of the keyboard, the C# key raises the tempo and the C key lowers it. You can also use the numbered keys in that section to dial up a particular value. Hold function down and strike the numbers you want then release the function key/button
I don't believe there is an adjustment for loudness of the metronome other than the overall loudness of the piano..
Mar 26, 2010 | Casio Privia Keyboard Case
Music Logo
94 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
