Question about Mitsubishi XD520U DLP Proj XGA 2000:1 3000 Lumens 7.0LBS 240V Projector
Just replaced the lamp in an XD520U and am having the same problem, but not hearing any high pitch noise. The Lamp has been reset correctly, and checking the info screen verifies it, but still after a
Just like this previous writer, I have a Mitsubishi XD520U and replaced the bulb. I reset the projector using the arrow and power buttons. The projector fires up normally, the fan is running, but after about 1 minute the dispay flickers and the screen goes nearly white before the unit shuts down. No status light is given. I am able to check the info on the menu and it does appear that the lamp reset has taken, as no hours are on the lamp time. Thanks
    Novelist:
  • 85 Answers
Have you used a genuine replacement lamp? There are some clones coming from oriental sources that do not accurately match the specifications of the original, and it's possible this may be the cause of the problem...
Was the old lamp still working when replaced? If so, reinstall it teporarily and see if the problem has gone. If so, it's the new lamp that's the cause of it
Posted on Apr 09, 2014
Marrie
  • 563 Answers
SOURCE: RESET LAMP HOURS
Hi Greg147
The resetting is not done in the menu.
Plug in your power cable - Machine is now in standby mode.
Then Hold down the left and right arrow keys on the Projector and press the power button. You'll see a indicator light on top of the Projector flashing twice - Lamp hours is now reset.
Hope this is of help.
Posted on Apr 01, 2008
  • 50 Answers
SOURCE: After replacing the lamp in
To reset the lamp operation time on a Mitsbishi XD480U:
Plug in the power cord, turn on the lamp, and press the Left Arrow button, Right Arrow button, and POWER buttons on the control panel ALL AT THE SAME TIME, holding them all down for about three seconds.
Notes:
•Unless these three buttons are pressed at the same time, the lamp operation time isn't reset.
• Make sure that the STATUS indicator is lit twice and the lamp operation time is reset successfully.
• The projector doesn't turn on if the lamp cover isn't attached securely.
• Be sure to reset the lamp operation time whenever you replace the lamp.
• Do not reset the lamp operation time unless you replace the lamp.
Posted on Dec 17, 2008
  • 50 Answers
SOURCE: What 2 buttons other than the Power button
Notes:
SOURCE: automatic power shut off
Hold right left and power all at the same time and it will reset...
Posted on Feb 28, 2009
projdoc
  • 2237 Answers
SOURCE: Projector suddenly shut down
you need to reset the lamp timer. turn it on, and press and hold the left arrow, right arrow, and power button until it resets.
Posted on Aug 04, 2009
My toshiba mod. 52hm95 lamp cooling fan is making noise and i am having trouble locating a replacement
Fan like noise may be a fan or the color wheel---color wheel spins at high speed(lamp faces it) and when failing you will have a high pitched or fan like sound---hard failure and you will hear a grinding sound.
May 16, 2012 | Televison & Video
When turning on samsung hln467w, lamp light blinks, screen stays dark, can hear audio from tv show, but then a high pitched sound begins for a few seconds. The tv turns on and off for a few cycles with the...
The tv have a colors wheel,have a whinning high pitch sound,mean colors wheel is warping not spinning right any more.The colors wheel is dead,must be replaced.The tv have high pitch sound,shutdown the projection lamp.The projection lamp might be dead or not?Not yet determine dead or just shutdown by the nonfunction of the colors wheel.
Aug 05, 2010 | Samsung HLN467W 46" Rear Projection HDTV
Sharp XG-3790E projector switches off soon after it is switched on
if you replaced the lamp recently, you'll need to reset the lamp timer. if it's a dlp projector, could be the colorwheel. listen for a high-pitched whir when the lamp strikes. if you don't hear it, replace the colorwheel. if you do, check the fans to make sure they work. if all else is fine, replace the ballast/power supply.
Nov 17, 2009 | Sharp Office Equipment & Supplies
When I turn it on I get a buzzing whine, picture is fine, and now noise has a rattle to it. Would this be the color wheel or maybe the cooling fan?
could be either. remove the lamp. you'll see on the lamp door a plastic protrusion. this is to press the door switch. find that switch and hold it in with a screwdriver. now turn the projector on and look inside the lamp housing in the direction that the lamp would be pointing. do you see the colorwheel spin? it should spin with a high-pitched whir. if you hear the bad noise when it starts up, replace the colorwheel. otherwise, locate the bad fan and replace it.
Oct 17, 2009 | Optoma EzPro 732H Multimedia Projector
My bulb went out in my x1a so i replaced it now it
is the led on the top of the projector blinkng at all? if there is no led lit, the fuse on the power supply may be blown or the power supply itself needs replacing. turn the projector on. you should hear the fans and a high-pitched whir. if you don't hear that whir or it sounds like a noisy motor, the colorwheel needs replacing. if it sounds good but no light, make sure you have the correct lamp. the x1a takes the sp-lamp-009 lamp. it should have 2 white wires, each at opposite ends of the plug. if you have a lamp with a red wire and a white wire, you have a lamp for an x2. also make sure the lamp door is closed completely. if the door is closed (hitting the switch), the lamp is correct, the led is green, and the sounds are good and it still does not light, the ballast is bad and needs replacing.
Sep 23, 2009 | InFocus X1a DLP Projector
Optoma ep1690 projector lamp won't come on. Machine starts, fan starts but no lamp. only has about 100hrs used life. Lamp looks perfectly fine but LAMP inicator comes on then goes off. Should I buy a...
reset the lamp timer. if you don't hear a high-pitched whir when you turn it on, the colorwheel is bad. could also be the ballast. worst case, the main board. if it is under warranty, send it in.
Aug 19, 2009 | Office Equipment & Supplies
Sony 60 in projection tv makes weird noise
Did you hear that wierd noise 3 times after you turn the TV on? if so the ballast is working try replacing the lamp XL-2000u
May 27, 2009 | Sony Grand WEGA KF60XBR800 60" Rear...
Samsung Dlp HL-R7178w not turning On.
If all 3 leds blink, it can be the lamp, ballast (lamp driver), color wheel, or dmd board (all are engine parts = engine failur). its usually the lamp, but you can listen to troubleshoot. when it turns on, you will hear the fans come up (humm..airflow noise), then you will hear the colorwheel (high pitched squeel.. it will come up to speed) and then the ballast will fire up the lamp.. if the lamp doesn't fire, you will hear the spark gap fire (a 1 second buzz noise indicating bad lamp).. the gap will fire 3 times, they tv will then retry again and again until it shuts off and kicks out the error. this power up path will help you listen to find your problem. i can assist further.
Jan 08, 2009 | Samsung Televison & Video
Mitsubishi XD520U DLP Proj XGA 2000:1 3000 Lumens 7.0LBS 240V Projector Logo
97 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
