Question about Cooktops
Technika manual I need a manual for a Technika coocktop
Why wont the baumatic electric cooktop turn on
Make sure the isolator supplies power to your coocktop. Check you fuse behind your oven. Check connections.
Feb 16, 2014 | Baumatic B11SS Electric Cooktop
Need a manual
http://www.manualowl.com/p/Frigidaire/FGMV154CLF/Manual/112650
Feb 05, 2013 | Frigidaire FGMV154CLF 1.5 Cu Ft 900w Otr...
I need an owners manual for jp968b0c1bb
First of all, thank you very much David for choosing FIXYA today for your online technical support needs.
Here is a direct link to the ONLINE USER'S MANUAL for that model:
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-80141.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and blue highlighted section of text just above.
This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents, although many computers already have this type of utility pre-installed.
You can download this free at WWW.ADOBE.COM if necessary. Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
I truly hope that was helpful to you.
Good luck and take care.
Joe.
Feb 27, 2012 | GE 36 in. Profile JP968 Electric Cooktop
Use and Care Manual for a 89353 Tri- Convertible Grill Range
You can get parts for you cooktop on the link below. just click on the area that needs the part.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=89353-8&productCategoryId=0121060&brandId=1266&searchedModel=
As for the manual you might beable to get one from your local sears part department.
Good Luck
Jul 01, 2010 | Jenn-Air JED8230 Electric Cooktop
How to clean technika glass top stove
I use a razor blad scraper and soapy water
May 16, 2010 | Cooktops
On our 6 burner gas coocktop, the right two burners don't light
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
May 10, 2010 | Thermador SGS36GS Gas Cooktop
I never got a manual when I purchased the stove...need directions for using the self-cleaning feature
I searched 'manuals' and found the one that I was looking for...downloaded it as a PDF and copied off the pages that I needed for using the self-cleaning mode.
Oct 26, 2009 | Cooktops
How to remove burnt grease, fix lightly scratched black stovetop?
Hi, I assume we are talking about a flat glass top. First the bad news. using any abrasives will permanently scratch the glass hence the dull spot. You can however make it look a little better. Grease spots and the like can be removed with a flat razor blade scraper which needs to be held flat to avoid the corners making scratches. Use any good glass/ceramic cooktop cleaner ( which is the ONLY cleaner you should ever use ) (available in your local grocery diy store and some hardware stores). The cleaner is a thick liquid, put about a dime size drop on each burner area and use a paper towel to buff out the finish like waxing a car. Once it looks clean flip your paper towel over and shine the top to like new. Good Luck!
Jan 28, 2009 | GE 36 in. Monogram ZEU769 Electric Cooktop
Operating manual
Hello
To get a manual for that stove go to this link:
http://www.technika.com.au/
I hope that help...Good luck
Eddie Rentas
Tupper Lake NY
Jul 18, 2008 | Tecnik Cooktops
' Fagor 2h-134 I ' cooker manual needed
Hello
Are you looking for the pressure cooker manual?
Jul 12, 2008 | Fagor Cooktops
Cooktops Logo
Top Cooktops Experts
Dan Webster
Dan Webster
paulcarew
Are you a Cooktop Expert? Answer questions, earn points and help others
