Question about KitchenAid Kitchen Ranges
Range's cast iron grates cracked under normal use in three locations. Kitchen Aid refuses to admit there is a problem.
Under normal use, my cast iron grate on my range has cracked in three locations. The latest, I had just cooked dinner and then turned on the oven to bake some scones. While it was preheating, I heard a loud POP! Looked at the grates and there was a new crack! This is a defect and because KitchenAid has not had any other complaints or recalls they refuse to do anything about it! I'm not even abusing this appliance! Just normal use!
  • SGcvn69
    SGcvn69 Mar 26, 2014
    P.S. This is a model KGRI801PBS00
Can I use a cast iron pan on glass cooktop range
Yes you can, magnetic induction stoves are working with anything metalic.
Mar 17, 2015 | Kitchen Ranges
Wfg361lvd
If you have a standing pilot (always lit), the adjustment screw is normally located behind the burner control knobs.
Dec 22, 2012 | Whirlpool WFG361LVD - 5.0 Cu Ft,...
Where is pilot light located
under grates and under top of stove normally in the middle or rear
Mar 16, 2012 | Magic Chef CPR1100AD Gas Kitchen Range
Can we use cast iron cookware (e.g., frying pan) without damaging the range grates?
Yes you can definitely use iron cookware on this range without an issue. It is made for all types of cookware. Just make sure you do not drag the pan against the grates, but any cookware would hurt the grates if you did that.
You are definitely safe to use them.
Please make sure you rate my answer 4 thumbs up! Thanks so much for understanding, it would be a huge help to me. I would be forever grateful if you could do this for me. If you still have a question or concern about this problem please just respond / reply to my answer here before rating my answer.
Thanks
Tim
Oct 14, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Which is best porcelain or cast iron grates? I am
Cast Iron by far, ceramic grates chip and are VERY difficult to clean!!!
Nov 14, 2009 | Frigidaire 30" Self-Cleaning Slide-In Gas...
How to clean the cast iron grates and stove top of a gas range
glass cleaner WITH ammonia, and a small toothbrush works well. mop up with an old washcloth, rinsing often. for pieces which have gummy residue, and which can be removed to the sink for soap and water finsing afterwards, try GooGone.
Mar 12, 2009 | Viking VGSC306-4B Gas Kitchen Range
CAN I USE ENAMELED CAST IRON POT ON MY NEW GE GLASS TOP RANGE
yes they can just cant slide them around cause of scratching but as far as performance they are fine
Dec 30, 2008 | GE Spectra JBP78 Electric Kitchen Range
Frigidaire Gas Range with paint blistering around largest burner etc.
go back to where you got it from the paint should not come off after such a short time same as the grates .
Oct 11, 2008 | Frigidaire FGF326AS Gas Kitchen Range
Cleaning the cast iron grates and griddle
Try This....
Place the grates in a sink of hot, soapy water and let soak for 15-20 minutes. For tougher stains, add a cup of sudsy ammonia to the water. Make sure grates are thoroughly dried after each cleaning. After the cleaning process, Lightly coat the bottom of the grates with a cooking spray and then blotting them dry.
Or
If you self clean the oven on occasion, put them in the oven when running the self clean cycle.
Jun 22, 2008 | Frigidaire 30" Self-Cleaning Slide-In Gas...
Cast iron pans
Cast iron cookware is NOT recommended due to the weight and the potential damage it can cause to the glass top surface. There's nothing better than a good old-fashioned cast iron skillet that's been broken in over a number of years of use, but they are better suited for gas ranges rather than electric. I hate it. I have several cast iron skillets that I only use on the outdoor grill, because I currently own a glass top electric range.
Aluminum bottom pans and copper bottom pans heat well, but can leave metal transfer marks on the cook top surface. If the marks are cleaned after use with an approved stove top cleaner, you shouldn't have any problem retaining the condition of the glass surface, however. Stainless Steel seems to offer good resistance to metal transfer, but takes a little longer to heat than aluminum or copper. So...you have somewhat of a trade off. Baked enamel cookware seems to be the best recommendation because it heats wells and causes the least amount of damage to your glass top surface.
IMPORTANT: Make sure the bottom of your cookware is FLAT. If your pans are warped or bowed, this can cause uneven heat transfer on the heating elements and potentially cause the cook top to crack. Most manufacturers will not replace the top if it still under warranty if it is determined that your cookware caused the problem.
A little over kill, but I hope this helps you.
Feb 14, 2008 | Maytag MER5770 Electric Kitchen Range
Open Questions:
Kitchen Ranges Logo
20 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
