Question about Refrigerators
Siemens KS32F00 refrigerator shows wrong temperature in freezer and never turns off compressor
The unit shows wrong temperature in freezer from time to time (every 5-10 days). Indicator shows that temperature in freezer goes to -12, -8... while it is actually ok. Alarm sounds and seems that temperatures in fridge starts to raise. If i turn it off for few minutes and turn it on again it shows -18 (-8 when turned off) and it starts working again normally (except that compressor never turns off regardless of temperatures)
  • 1462 Answers
SOURCE: Refrigerator not cooling.
compressor has failed. not a diy job
Posted on Apr 25, 2007
SOURCE: Whirlpool SD20 Freezer Intermittent Temperature Malfunction with Alarm Alert
Apologies, the above two guest comments are mine, not sure what happend!!
Posted on Nov 26, 2007
SOURCE: Kenmore Elite refrigerator Model 596.76533500 temperature control panel locked?
I have this problem also my control panel is not working. It has an Er If on the panel.
Posted on Oct 13, 2008
  • 1462 Answers
SOURCE: Whirlpool side by side refrigerator not defrosting.
take back panel off inside freezer. check continuity thro heater and thermal fuse in series with heater
Posted on Nov 17, 2008
farfield
  • 462 Answers
SOURCE: fridge condensation - freezer thawing
OK now I'm wondering are theses numbers your getting 4 -9 the actual temps of the refrigerator and the freezer? and do they feel this cold and correct to you? I know the refrigerator side shouldn't be below 34 or so and definitely not below 32. If this is correct and the numbers are not settings but temps. (Now if you have a touch pad its electronic. If it has knobs it has a separate defrost and thermostat and are electro-mechanical)
If electronic Your control board and possibly defrost control are out.
It would more likely be the sensors going to the board(s) It will both sensors have the possibility of causing your problem. 1 will control the run of the compressor (and this one could and probably is connected to the inside coil) and 1 will control the air damper tween the refdg and freezer compartments, and may turn on the inside fan operation too.
(this would be my first suspect if these are degrees numbers). Look at the thermostat control see if it is attached to the indoor coil (usually the tube leavign the indoor section. If its not attached its not sensing the coil temp and when goes into defrost wala its not senmsing temps like its designed to do. Look for a broken clip or possible a plastic wire tie that holds this sensor in place.
Please get back to me with what you see - find on this look up.
Posted on Mar 18, 2009
Hi, my admiral side by side fridge is having problems. The freezer is working fine but the fridge is not cooling. I noticed 2 days ago that the temperature indicator for fridge was bleeping at 4 degrees. I...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 28, 2011 | Admiral 26 cu. ft. Side-By-Side...
Fridge runs all the time,temperature seems fine inside,make's a fluid y gurgle sound all the time.only way to stop it is to lower the temperature but comes back on after a while or turn it off.
heatman101
Aug 27, 2011 | Zanussi Refrigerators
Everything is working on my seimens fridge freezer but despite putting the temperature on - 20 for freezer and +4 for fridge the temperature does not get past cool in either compartment. Doors close well...
heatman101
Jul 06, 2011 | Siemens Refrigerators
The Frigidaire Galaxy Series Model GLHS37EHSB6 is not cold. The temperature shows freezer at a temperature of 65 degrees and refrigerator at 77 degrees. I have lowered the temperature and it would beep and...
heatman101
Jun 02, 2011 | Frigidaire Refrigerators
GE PTS25SHSARSS refrigerator no longer cooling. Only four years old. Lights, fans (freezer circulating and compressor) work ok. Compressor comes on intermittently. Can set (adjust the display)...
heatman101
May 02, 2011 | Refrigerators
The fridge freezer has stopped working. The light is on and the front shows that the fridge and freezer are at the right temperature but neither the fridge / freezer are cold. Is it likely to be the...
heatman101
Apr 24, 2011 | Neff K3965XO Side by Side Refrigerator
Side by side unit. no temperature control in freezer or fridge temperature of fridge is 60 degrees F on top. Freezer temp is 45 degrees. Bottom part of fridge is 28 degrees F.
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
heatman101
Feb 13, 2011 | Frigidaire PLHS267ZA Side by Side...
The temperature of the freezer and refrigerator keep going up to 31 (freezer) and 41 (about-refrigerator). We have turned on the Turbo Cool to get the temperature back down and it takes a day or two to...
Refrigerator
heatman101
Jan 16, 2011 | GE Refrigerators
My French door Maytag shows that my freezer temp is -2 and my fridge compartment is 40, but both are not cooling. it is now room temperature inside.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
heatman101
Oct 25, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
Fridge wook fine. Freezer is room temperature. Freezer dial at top temperature
heatman101
Sep 05, 2010 | Maytag MTB1891AR Top Freezer Refrigerator
Refrigerators Logo
35 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
