Sir when i power on the ups its horn
When i turn it its shouting
  • 42 Answers
The Horn beeping means the battery is flat, and needs to be re-charged for 12-24 hours before plugging a load into the inverter. Check Battery for how flat it is, disconnect power to UPS. Remove battery . check voltage on battery tabs. typically 12.5 to 14 volts. Check UPS without BAttery in circuit (insulate leads with tape so they don't short or touch together. ) IF Horn stops after battery out of circuit that means system can stay powered up, but there is a problem with the charging circuit (Battery dead, Too Much Current to charge , etc). good luck
Posted on Feb 16, 2015
  • 3,320 Answers
Hat product? Connected to? how is it connected?
Posted on Mar 29, 2014
98 jeep Cherokee had completely dead battery jumped it with another vehicle alarm went off and horn blared till I turned on the ignition jeep started now when I turn my jeep off five minutes later the...
Sounds like a relay stuck on that killed the battery. I keep my parking lights on so I can see when the unit starts (no other feedback). Problem comes in when it starts and I don't know it, Parking lights come on and won't shut off till door is opened.
I think this is what killed my battery. I need to return to the installer and and have a relay installed so lights shout off when engine is off.
Hope this helps!!
Feb 03, 2015 | Jeep Cars & Trucks
My iphone shout down
First plug it in to a power source to charge it. It might have shut down due to a lack of battery power. Once you have done that, hold the home and sleep button at the same time for 8 seconds or until you see the apple sign. If this fails to get it up and running you may need to connect it to iTunes and have iTunes recognize it.Then you will have to try restoring as a NEW iPhone and see if the problem persists. If you can get it to turn on then you're fine, if not, I would recommend visiting an Apple store soon.
May 01, 2011 | Apple iPhone 3GS Black (16 GB)
Horns not working
dear sir
first take a D.C supply tester and try to push horn button and now come near of horn and check the D.C. supply is coming till the horn if yes then its mean horn have problem if not coming then check other device check fuse ,realay and other connecting point.
hope answer the question
thank you
please vote!
Oct 04, 2010 | 1984 Chevrolet Corvette
My 99 oldsmobile alero started honking on its own from time to time. sometimes when i turned the wheel and sometimes not. then one day it started honking nonstop for 20 min. i pulled the relay fuse from...
ok its one of 2 things
1- behind the steering wheel between the column,there is a part called the sir coil,it allows the steering to turn with out getting the wires inside tangled,,this SIR COIL could be bad and making contact when it should not and causing the horn to sound,,,,you would have to remove the steering wheel to remove this part and its easy to mess this up,i would rec a repair shop to fix this,
2-inside the steering wheel is the air bad,which also contains the horn buttons inside,sometimes the air bag swells up and gets hard and applies pressure on the horn buttons inside and cause it to soulnd the horn,,if thats the case you will need a new air bag,,,i would also rc a repair shop for this as messing with the air bag system you can set the air bags off just with static electricity,,,,
but one of those should be your issue i think,,,there is really not way to test those parts unless your a dealer,so i cant tell you horn to test it,you need the special load tools and stuff,,,
Take care
Oct 29, 2009 | 1999 Oldsmobile Alero
I have a lincoln ls and my horn dont work but all the fuses are fine, I bought this car from an individual but I need to get it inspected
Could be bad horn or relay or the horn'button'.Start at the horn with a test light.Have someone push horn button and check for power at the horn.If no power then trace wires to relay,check for power cominginto relay.If power is going in but not out to horn relay is problem.etc. Some horns have a lttle knob you can turn to adjust them and get them working
Oct 20, 2009 | Lincoln LS Cars & Trucks
Sir Tom, my fzr250 power just turned-off while im
Try to find your fuses and check if they are blown or not.
That would be the first thing I would do, then repost here for more support.
Jun 18, 2009 | 1988 Yamaha FZR 250
Replaced horn relay and horn still doesn't work
pull airbag fuse! also known as sir fuse!
Apr 14, 2009 | 1995 Chevrolet Blazer
My computer shutdown and im using a emachine e17t6w tft lcd flat
Hi
Dear sir,
Moniter Modale No E700,
E700 modeleprablem, Power splay prablem, but transister, Divaid all componets ok
Becouse power on that puse shout way to andstrading the prablem, please solve prablem
Mar 19, 2009 | Computers & Internet
Sound and modem driver
conect to the internet and go to computer up dates this will solve your problem
Aug 15, 2008 | Computers & Internet
Computers & Internet Logo
1,011 people viewed this question
David Payne
David Payne
