Question about Canon IMAGERUNNER 6570 Copier
E00821-0001 Error E00821-0001 on IR6570. could you show me the solution please.
How to fix the Canon Image Class Printer 4750 error code e001-0000
Canon IR2270/IR2870/IR3570/IR4570/IR5070/IR5570/IR6070/IR6570
Enter the service mode (Press "Additional Function" key, Press "2" and "8" simultaneously, press "Additional Function" key again).
Go to COPIER----FUNCTIONS-----CLEAR----ERR. Here you can reset all error codes on by one.
for more details : www.mytechtime.com/2011/10/canon-error-e001e002-e003-e007.html
Jan 04, 2015 | Canon Office Equipment & Supplies
How to remove error code (E000004-0010)from canon iR-6570 photocopier?
gmana ya cara benerin error e000004-0010 pada mesin canon ir6570
Jul 07, 2011 | Canon Office Equipment & Supplies
Hi,i have 1 unit ir6570,error code e000001-010,e000004 always appear few times a day.please guide me to solve the problems,i had reset accordingly.from Rahmat ,Penang ,Malaysia.
Press smart head button and hold 2 and 8 then smart head button do this within 4sec the screen will now indicate service. Then hit copier then function then clear then err then ok.Switch off on ps make sure theres nothing wrapped around fixing assy (hot section) as this error code is a thermistor fault
Mar 06, 2011 | Canon IMAGERUNNER 6570 Copier
I have problem canon ir6570 e025-003?please help me,
This is an error code for the connection of the toner bottle motor at power up is not detected. Did you recently ahve the hopper assembly off? Maybe this connection was forgotten. Check. The motor itself may have to be replaced.
Nov 01, 2010 | Canon imageRUNNER 5570 Copier
Sir ; i have a canon ir6570 machine,it was
this problem due to an over current has been detected in the toner feed motor,you must check the connector or replace the motor
Jul 30, 2010 | Canon IMAGERUNNER 6570 Copier
We have an f105 error what can we do?
Hi...
I Have Canon Ir5570 but i want up speed to Canon Ir6570.
I want Binary file for FRAM COUNTER Board In Chip IC #MB85R256 form Canon Ir6570.
And I want Binary file for Serial Board In Chip IC #BR93LC46F-W form Canon Ir 6570.
Dec 29, 2009 | Toshiba e-Studio 350 Copier
Can somebody help me what this mean? Error Code: E100 0001- E100 0002 it is a canon LBP5000
Symptom
  • E061-0001 (Potential ON)
  • E061-0002 (Potential OFF)
  • E100-0001
  • E227-0004
Cause
  • The pin is broken on the Primary Fan 2 Duct. The Laser Shutter is activated by the pin on the Primary Fan Duct Assembly. The linkage is pinched not allowing the laser shutter to be fully actuated (may also indicate E227-0004). Faulty Laser Scanner Assembly.
  • Defective DC Controller PCB Assembly.
Action
  1. Check the shutter operation and the pin on the Primary Fan Duct Assembly. If the pin is broken replace the Primary Fan 2 Duct (iR6570 : FC6-3540-000 / iR5075 : FL2-5834-000) or the Primary Fan Duct Assembly (iR6570 : FM2-3074-000 / iR5075 : FM2-9694-000). If the Laser Scanner Assembly (iR6570 : FM2-3670-000 / iR5075 : FM2-9832-000) has been replaced and error codes E100-0001/ E227-0004 are intermittently indicated, proceed to the next step.
  2. Remove the Primary Fan Duct Assembly (this assembly has a pin on it that activates the laser shutter).
  3. Remove and reinstall the Laser Scanner Assembly.
  4. Install the Primary Fan Duct Assembly. This should free the linkage allowing the laser shutter to be fully actuated.
  5. Finally a DC Con clear resolved both of the intermittent issues (E100-0001/ E227-0004).
May 28, 2009 | Office Equipment & Supplies
169 people viewed this question
old marine
old marine
