Samsung wa80v3 WHAT IS ERROR CODE 1E I HOW CAN FIXIT
HI PLEASE HELP ME
5 Suggested Answers
SOURCE: Error message 1E is displayed at start up samsung model SW75C3S
1E error mean there is malfuntion on your sensor pressure. Maybe because the sensor is damage or rusted. You must replaced, it's cost me about $15
Posted on Jun 10, 2009
richroth
  • 9472 Answers
SOURCE: HOW CAN I SOLVE MY
WATER PRESSURE SWITCH ERROR - Display shows 1 E.
* Generated Frequency Signal of WATER LEVEL (WIL) SIW (KHz)
Normal Level = Abnormal W/L Frequency
Low Level = 30.00 Khz
High Level = 15.00 Khz
If the same signal is detected for more than 5 seconds, it is a PRESSURE SWITCH Error. When this error occurs the drain pump will operate for 3 min. and the display will show 1 E indicating a pressure switch error.
Posted on Dec 20, 2010
  • 3 Answers
SOURCE: how can I fix the
Error 1E is no pulse to weighing sensor to open and closed valve.
Step to solve:
1. Open top cover (behind door cover)
2. Check connecting cable of pressure switch, pull out and clean up connector (usually dirty with rust)
3. Open back cover, pull out pressure switch.
4. Clean up hose of pressure switch, blow the hose slowly.
5. install again pressure switch to the position.
6. Install cable to connector, check the current & resistant by tester.
7. Push "on" selector and fill drying position, wait until digital no blink. Running test.
8. If machine is running well closed the cover.
If still error condition (1E Error still come out), change part of "Pressure Switch" by the new one.
Regards,
Priyo
Posted on Jan 26, 2011
  • 118 Answers
SOURCE: Hi i have a samsung
It is probably not 1e but IE meaning input error. There is no water entering the machine. Could be the water valve. just in case check the inlet filter at the inlet valve to see it isn't blocked. then you will need to call for service www.thewashingmachineman.webs.com
Posted on Feb 23, 2011
Daewoo DWD-F1011 1E error code I have a daewoo washing machine model DWD-F1011 and it start working the wash before no working spin and gives error code 1E. Any idea what that might be?
I do not believe that is a 1E I think it's an IE error code which would be water inlet wiring or something like that. Here is the code list, scroll down until you find IE, Daewoo errors start at E2, hope this helps.
http://removeandreplace.com/2015/11/02/daewoo-washing-machine-error-fault-codes/
Aug 30, 2016 | Daewoo Washing Machines
Samsung model wa 7584C1. has 1E error code have changed pressure switch and tub hose still shows the same error please help
IE - Water level sensor fault This fault code is fairly self-explanatory and tells you that the washing machine has detected an error with the pressure sensor or pressure switch
  • Check water level sensor
  • Check wiring to water pressure sensor
  • Check connections to water level sensor
  • Check main electronic controller
  • Apr 06, 2015 | Samsung Washing Machines
    1E error code
    The Flex zone Temp sensor is the most common issue. check your model number suffix to make sure the part is correct:
    http://www.appliancepartspros.com/samsung-temperature-sensor-da47-00095e-ap4136048.html
    Best,
    Joe
    Jan 31, 2014 | Samsung RS2534 Side by Side Refrigerator
    Hi i have a samsung a fuzzy toploader as soon as i turn it on it gives me a 1E error HELP!!
    Feb 23, 2011 | Washing Machines
    May 19, 2009 | Samsung SW62ASP Top Load Washer
    Washing Machines Logo
    23 people viewed this question
    Top Washing Machines Experts
