Question about Kenmore 400 6943 Dryer
My Kenmore electric dryer is drying, but shuts off after about 5-10 minutes. I cleaned out the lint tray and the exhaust???
Dryer shuts off after a few minutes
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 33 Answers
A lot of times that is a sign that the motor is beginning to go bad.
Posted on May 19, 2014
SOURCE: kenmore dryer
This may not be the solution to your exact problem but for those looking for why there timer will not advance and why it keeps running even when the items are dry: The usual problem is not the timer but the mosture sensor (if your dryer has one).
1: Check the mosture sensor light/indicator. If is still shows some mosture or flashes even when the items are dry, you have a mosture sensor problem, probably not a timer issue - luck you.
2: Check if the timer will advance and the dryer will turn off when you have it in the TIMED mode (i.e. 10mins - NOT the more/less dry modes.) If so, then it is indeed a sensor problem.
2: Check that the wires to the mosture sensor have not fallen off (as in my case - a simple repair). The senor is usually two metal bars somewhere near the front part of the inside of your dryer. You may have to take off the door and the front pannel (be sure to unplug the dryer first) to get at the two wires to clip on to the sensor. Clean any lint and make sure they are conneted. If well connected then replace the sensor ($15-$20 and very easy to do).
Posted on Jul 01, 2008
jyackle5
  • 8197 Answers
SOURCE: I constantly got E1 Error code on my Kenmore Elite H3 GAS dryer
E1 error code indicates an open thermistor or open thermistor circuit. A thermistor is a component that relays the temperature in the dryer to the control board. If the thermistor has failed, Error code E1 will be displayed.
You need to call a repair person to fix it.
Posted on Dec 18, 2008
  • 33 Answers
SOURCE: kenmore electric dryer
If it won't shut off, would suspect the timer motor has failed, such that it cannot turn itself to the off position; I assume it will turn off when twisting the dial manually.
Posted on Aug 09, 2009
jsrock516
  • 5911 Answers
SOURCE: Clean Dryer Lint Vent in Kenmore elite HE4
If you wish to clean the interior cabinet of the dryer follow these steps:
1. UNPLUG the dryer. Dangerous voltages are still present even with the dryer turned off.
2. Open the dryer door and remove the lint screen. IMPORTANT: You must remove the lint screen first in order to remove the blower fan housing.
3. Remove the lower toe panel directly below the dryer door by removing the screws under the bottom front edge of the panel. With the screws removed, the panel will drop down, then come off. NOTE: For better access, you can prop the front feet of the dryer up (a 2x4 works well).
4. Loosen the screws on the blower fan housing directly below the drum and remove. There's usually a small clip holding the cover in at the bottom that you may need to pull out to release. NOTE: You may also have to disconnect the auto dry sensor plug (yellow wires with white plug - use a small screwdriver to release the locking tabs) and/or ground wire to accommodate removal of the cover.
You should now have access to the dryer interior and the blower fan squirrel cage motor. Take the time to clean out the blower fan housing cover as well. A long bristle brush made for dryers works well at removing any lint inside the dryer in the hard to reach places, followed by vacuuming.
NOTE: After cleaning, you may experience a slight burning odor. This is normal as lint gets stirred up in the cleaning process and can settle on the heating components. The odor should dissipate after a short period of use.
If you have any questions, please let me know. I hope this helps you.
Posted on Sep 29, 2009
hunter19_46m
  • 7482 Answers
SOURCE: We have a 10 year old Kenmore elite dryer. We
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
This is a FREE answer, Please rate me
Posted on Dec 11, 2010
My Bosch Nexxt 500 dryer keeps tripping the hi-limit cut out.
Try checking your exhaust vent pipe for excessive bends and kinks, make sure there is good strong airflow coming out the exhaust where it exits the building.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Dec 12, 2013 | Bosch Nexxt 500 Dryer
After starting dryer will run for a minute or so then shut off
there is a problem with your exhaust check the air duct or take off the exhaust hose it will be packed with lint this will keep the dryer from running correctly !!!
Nov 12, 2013 | Hotpoint NVL333EY Electric Dryer
I should like to have a Dutch or English user manual
Obstructed Vent
Your Kenmore dryer must be able to freely circulate air in the dryer in order for it to continuously supply hot air. If air flow is limited from a buildup of lint in the vent and lint tray, the high limit switch temporarily shuts off heat to the dryer. Empty the lint tray on the top of your dryer. Detach the exhaust vent -- the silver tube in the back of your dryer -- and thoroughly clean it out with a lint brush and reattach. Consult your Kenmore dryer manual for instructions on how to inspect and clean your vent hose. Once these components have been freed of lint, the dryer should dry clothes again.
Broken Blower Wheel or Belt
If you have completed a full inspection of your dryer vent system and found no obstructions, your dryer might have a defective blower wheel or belt. A failure of one or both of these components can restrict air flow in your dryer and take your dryer longer to dry clothes. According to Point and Click Appliance Repair, a noise coming from the dryer as the drum spins is usually an indication that the blower wheel is failing and needs to be replaced. Review your Kenmore dryer manual for instructions on how to locate these components on your dryer.
Faulty Thermostat
A broken thermostat can cause your dryer to produce too high or too low heat. Monitor the dryer exhaust temperature with a hand-held thermometer. The temperature should be below 150 degrees Fahrenheit. If the temperature reading is higher, then replace the thermostat. It's no longer able to regulate the temperature inside the dryer, and your dryer is in danger of overheating. If the temperature reading is room temperature and the dryer is running, the thermostat is broken and needs to be replaced.
Damaged Gas Valve Coils
Damaged gas valve coils permit your Kenmore gas dryer to ignite only once before coils must completely cool in order to reignite. This is a common issue among older dryers. If your dryer struggles to turn on or after it shuts off you must wait several minutes before it restarts, then the gas valve coil likely has worn. Confirm the location of the igniter from the manual. It's a cone-shaped tube that is located inside the dryer near the front panel close to the bottom. If the igniter radiates bright orange for 15 seconds without producing a flame, then the gas valve coils have probably failed.
Mar 10, 2011 | Zanussi Dryers
The dryer gets hot but doesn't dry the laundry. gas and exhaust are all connected properly. Lint tray is cleaned after each load.
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Nov 04, 2010 | Kenmore Dryers
Gentlemen, As perventitive maintance on an electric dryer, how would I clean the lint from inside of the lint tray and exhaust without dis assembly of the unit?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Aug 29, 2010 | Kenmore Dryers
My electric dryer is becoming extremely hot during the drying cycle. I replaced a blown thermal fuse several weeks ago and the dryer was extremely hot at that time. The dryer runs but becomes so hot you...
Clothes will get very hot in the dry cycle, especially when the dryer is set to the warmest or hottest setting.
There are controls built into the unit to prevent it from overheating to the point of causing a fire. The thermal fuse you replaced is one of them (and I assume you replaced a perfectly good fuse with a new one as you said it was very hot.).
You might want to check the following if you feel the unit is getting too hot -
1) Make sure the lint screen is clean.
2) Make sure the hose between the back of the dryer and the exhaust duct at the wall wall is not kinked or full of lint.
3) Make sure the exhaust duct leading to outside of the house is clear and not full of lint.
Let me know what you find.
Dec 14, 2009 | Kenmore 62602 Electric Dryer
Gas dryer heats fine but shuts down before the drying cycle is over taking longer to dry clothes. Lint trap and exhaust tube cleaned out.
You are going to most likely need a vent cleaning. The dryer is getting too hot and shutting off because it is not exhausting good.
Apr 29, 2009 | Kenmore 94702 Front Load Stacked Washer /...
Dryer cuts off before clothes are dry.
Might be the thermal protector in the motor that is shutting down the dryer, if motor overheats this is what will happen. Make sure there is no lint build up around the motor, if not the motor is bad. does the dryer start right away after shutting off or do you have to wait? If you have to wait the motor is bad.
Jan 13, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Dryer 90 Series shutting down. overheat?
Your motor is very likely overheating and needs replacement. A simple test is the motor will be so hot you cannot even touch it. Hope this helps!
Jan 05, 2009 | Kenmore 62602 Electric Dryer
Dryer runs & heats but shuts off after 3-10 minutes
the motor overload can caouse that problem in that case new motor is needed if the dryer turn right back on after it turns off the even heat control board in panel bad if it humms are no noise after turn off and you have to let cool down the motor is the problem
Feb 28, 2008 | Kenmore 64952 Electric Dryer
Kenmore 400 6943 Dryer Logo
110 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
