Question about Kenmore 30172 / 30174 / 30179 Gas Single Oven
Oven doesn't heat up enough
Set the oven to 500, and it's only going up to 350 and then back down to 250 or 200.  kenmore 790-71002100
  • 109 Answers
More than likely the oven requires a new thermostat, but would recommend an Appliance Repairer to confirm this solution.
Posted on Jun 16, 2009
Gas oven doesn't get hot enough
Good Morning Friend,
I understand that your Frigidaire oven will not heat to temperature if you set it to 350 degrees. I see that you have to set it to 450 degrees for it to heat up, and then turn it back down to the desired temperature. Please try resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power, set the clock and try setting the temperature to 350 degrees. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 08, 2014 | Frigidaire Ovens
Tip
I have not checked the heating element with a ohm meter yet but the heating...
If you are having problems with your electric oven heating up too slowly, not being able to maintain temperature set point, or wild variations in temperature, then you probably have a bad baking element in your oven.
The bake element is the bottom element in your oven. The life span of these elements can vary depending on the usage of your oven and the quality of the element. Anything electric has an unpredictable lifespan. Elements made on the same assembly line can vary greatly in how long they last. But when the element burns out it will need to be replaced to have your oven work properly.
The thing the fools many people is that many ovens will use the broil element to preheat the oven and then switch to using the baking element only. When this happens the oven will no longer heat and will cool down. The unit may sense this and activate the broil element again which will cause wild swings in temperature and also can cause food to burn on the top self or not bake properly.
If you can see the elements, watch them and see if they both get red hot when initially warming the oven. If only the top, broil element gets hot then you have a burned out element or a bad contacts where the element plugs into. Usually lifting the element and pulling out on it will release the element. If the contacts are discolored or pitted then they could be causing your problems. By using an ohm meter you can check the resistance of the element. If you get no continuity through the element it is no good. Bad elements will often have blisters, bubbles, or even burn in two.
If the element contacts are bad, make sure the you replace both the element and the receptacle that the element plugs into. Replacing only the element will only temporarily solve your problem.
http://www.fixya.com/support/r4319770-maintenance_range_stove_or_oven
http://www.fixya.com/support/r4388324-oven_fault_codes_ge_xl44_oven
http://www.fixya.com/support/r4391163-range_stove_oven_door_glass_replacement
http://www.fixya.com/support/r4404788-electric_oven_problem_oven_will_not_shut
http://www.fixya.com/support/r4319588-electric_oven_problems_not_use_in
http://www.fixya.com/support/r4154940-fault_codes_admiral_range_stove_oven
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
http://www.fixya.com/support/r4501853-oven_cord_wiring_oven_3_wire_or_4_wire
on Mar 29, 2011 | Ovens
Not sure which model my oven its but it takes a long time to preheat then does get warm enough. I put an oven thermometer in it and if you set it for 400 it beeps that it is up to temperature at 300 then...
I have a kenmore electric range/ultra bake, after using the self-cleaning mode on the oven, I cannot get the oven to heat up when I put it in the preheat mode. What should I do?
Apr 06, 2011 | Kenmore 40494 / 40495 / 40499 Electric...
Oven temperature does not regulate. The temperature is set for 350 but was 500 degrees in oven according to thermometer. Then sometimes you set it for 350 and it will get to almost 350 and then start...
From the symptons you describe, I would say that the oven thermostat is faulty, and in need of replacement.
Make sure your thermometer is o/k by checking it against another one, or boil some water, and check the temp of the boiling water, this should determine if your thermometer is o/k.
Hope this helps.
Dec 20, 2009 | Kenmore Ovens
Kenmore oven doesn't keep heat
im going to assume it is gas.. you may have a bad ignitor.. it is not gettin hot enough all the time to ignite the gas.. eventually it will not lite it at all..
Feb 15, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Oven heats to 200 and indicator dings
Try to set it at 500 degrees and see if it goes off at 350. If it does, then it probably needs calibrating. You can calibrate it by taking the knob off and finding a set screw in the stem where the knob sits. If this is not the problem, you may have to replace the thermostat. By the way, check to see if your temperature probe is not touching the wall of the oven. It will give it a false reading. Let me know if any of these things work and we will go from there.
Jan 29, 2009 | Whirlpool RBS245PDS Electric Single Oven
Maytag gas oven cycles every 20 seconds
yes it is normal . but i know your not the first to think its not , todays ovens are so tight , it only takes 10 seconds of heat to keep them at proper temp . it used to be that ovens where kept at a 3 degree sweep that is set at 350 turn on and up to 353 then off ,cool down to 350 and back on . this was a longer time off and a longer time on topday we keep to 1 degree ! 350 on to 351 off to 350 on and so on ....... so short berst of heat make for a more even oven ........ but i know i hate it too ! good luck
Jan 18, 2009 | Maytag CWG3100A Gas Single Oven
Oven will not heat to temperature setting
Called a Sears Tech to check it out. He found it was the control board/clock/timer. He said it was the first one he had seen go bad, and was happy I had the part number from your site, as it did not yet appear on his computer.
Dec 31, 2008 | Kenmore 33464 / 33465 / 33469 Gas Single...
Older gas range not heating up enough
Pull the knob off of the oven control and see if their is an ajustment. If the ajustment doesn't work then change the thermostat bulb. It goes for the oven to the back of the oven control know
Dec 21, 2008 | Ovens
Oven doesn't heat
I'm not sure what properly means.  If the unit is working, you can get a cheap oven thermometer to check the function of the thermostat.  Let the unit come to 350 and check the thermometer.  If it is off by more than about 20 degrees, there is a calibration change method in most oven handbooks.
If the unit is not working at all, this is another issue and needs a different set of diagnostics.
Nov 12, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore 30172 / 30174 / 30179 Gas Single Oven Logo
1,095 people viewed this question
Top Kenmore Ovens Experts
Marvin
Marvin
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
