Question about Tefal ActiFry Deep Fryer
Paddle keeps stopping
When cooking the paddle keeps stopping
  • 3 Answers
If this is a older model , then the internal cone that fits into the paddle is broken or not fitted correctly, or remove paddle to check that motor is still turning, if either of this is at fault its difficult to get spares E Bay best bet, also not easy to take apart,
Posted on Apr 10, 2014
Kneading paddle bakes into the bread
Kneading paddle on EVERY breadmaker usually bakes into bread. Let the loaf cool and then gently remove it. Or use the dough setting and cook bread in the oven. (i do this) delicious!
Jul 05, 2017 | The Kitchen Appliances - Others
Bread not rising as it used to, not sure if problem with paddle or...?
just as a hint - there is few thousand breadmaker manufacturers... each of them is making several models... we do not live with you...
how we can help if we do not know what manufacturer and model?!? telepathy is overrated...
now, paddle have nothing to do with rise of the bread, yeast and temperature do! if paddle is mixing the dough - there is no problem with paddle!
buy pack of new yeasts (dry if you use dry, i prefer live ones), then try bake again, if bake is ok, you solved your problem, yeasts were old and enzymes stop working, if there is no change in results with new yeasts, try use same yeasts in different machine, if result is ok in different machine, you heating element is at fault... time for new machine...
you do not need to be super accurate with your baking, allow little play...
my favourite bread:
3.75 cup flour (non-bleached!)
1.75 cup milk (tepid, body temperature)
2 table spoon olive oil or butter
1 teaspoon sugar
1 teaspoon salt
3 sachets dry yeast (21g - 0.7oz) if live yeast - about golfball size
enjoy!
and do not forget to vote...
Feb 11, 2015 | Kitchen Appliances - Others
Bits left in pan and paddle when cooking chips
If you use fresh potatoes, try a different variety as some are a lot firmer than others.
For frozen chips, start cooking as soon as they are removed from the freezer and don't let them sit.
Jun 13, 2013 | Tefal ActiFry Deep Fryer
The paddle sticks to the shaft when removing finihed bread
Clean the shaft AND the inside of the paddle hole until it is 101 percent clean. Give BOTH a shot of non-stick spray when you use the machine.
Dec 15, 2012 | Black & Decker B2300 Bread Machine
Mixing paddles come off during mixing, am using teflon tape on shaft to hold paddles on, what is a better fix?
Sound like you need new shafts or paddles and I know the paddles can cost $30 each. so think about a new model or buy one at a thrift store and try those paddle or use the machine. I got a great one for $10 . :)
Jul 30, 2017 | Black & Decker B2300 Bread Machine
I bought a model 1183X yesterday at the goodwill and the paddle won't turn. control panel lights up and counts down but nothing is happening in the actual cooking area. Any suggestions?
Hi...It could be a few things. 1) take the bread pan out of the machine and go to a kneading cycle. Look at the motor shaft through the lid and see if it's spinning. If not then the belt is loose or has fallen off. 2) Keep the bread pan out of the machine and see if you can spin the paddle freely by hand. It should spin smoothly. If it sticks or does not move then it could be the sealed bearing that the paddle shaft fits into has failed and a new bread pan is needed. 3) Make sure the pan is inserted in the machine correctly. Good luck..Hank
Jan 23, 2011 | Toastmaster Kitchen Appliances - Others
Kneading paddle is baked into bottom of bread loaf. Is this normal?
Yes, this is a common occurrence.
Nothing to worry about unless you chow down and forget to remove the paddle(s). :)
Since the paddle(s) stays in the pan after the kneading and through the baking process. The bread can trap the paddle(s) as the batter cooks.
We have gone through 3 different bread machines and over time all eventually did this. A little wear on the spindle will loosen the paddle(s).
Hope this helps!
Dec 26, 2009 | Sunbeam 5833 ExpressBake Bread Maker
Paddle stuck inside bread
I have the B2300 bread machine as well and I have encountered the same problem as you. So, I came up with the idea of removing the paddles right after the machine has stopped mixing the dough. Whenever I bake bread at home, I tend to follow the above mentioned solution and it made my life much easier.
Nov 15, 2008 | Black & Decker B2300 Bread Machine
Replacement paddle for my cook's essential ice cream maker
try contacting the manufacturer they may be able to help.
Nov 11, 2017 | Cook's Essentials Ice Cream Makers
Tefal ActiFry Deep Fryer Logo
625 people viewed this question
Top Tefal Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
paul
paul
Oscar Netto
Oscar Netto
Are you a Tefal Kitchen Appliances - Other Expert? Answer questions, earn points and help others
