Sony dav-dz370 s-master push power protecter - Audio Players & Recorders
    Genius:
  • Audio Player... Master
  • 1,054 Answers
There is a problem with the amp. You would have to get the main board replaced. Hopefully it is under warranty, otherwise it is probably not worth fixing
Posted on Mar 26, 2014
3 Suggested Answers
bobhifi
  • 635 Answers
SOURCE: Have a SONY DAV DZ370
Push power protect is an indication of an output failure ( Amplifier ). The Home theater system is asking you to switch off the power to prevent further damage. This mode is called protection mode and you will need professional help sort it out.
Posted on Aug 11, 2011
dunnbiker
  • 8546 Answers
SOURCE: what is the problem when
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on; or it may turn on but produce no audio to the speakers.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'nekkid'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as another possible root cause for intermittent shutdown.
Posted on Sep 12, 2011
DAV-DZ290K SHOWS PUSH POWER PROTECTOR
I solved sony push protect power , please wait and difficult fault , contact 09883596400 only kolkata.
Oct 06, 2014 | Sony DAV-S300 System
How to fix push power protector Sony DAV-DZ870W
try disconnecting all speaker wires from the main unit, then turn it on. If it still goes into protect - then the amp is blown and you need to replace the main board.
Jul 13, 2014 | Sony DAV-DZ870W Wireless Home Theater...
MY SONY HBD-DZ810 HOME THEATER IS CONSTANTLY SHOWING PUSH POWER PROTECTOR
The "PROTECT" and "PUSH POWER" messages will flash alternately when the protective device of the amplifier has been activated because a strong signal was input, or if there is a short-circuit detected. Press the POWER button on the unit to turn off the system, and check the following items after "STANDBY" disappears.
1) Are the + and - speaker cords short-circuited?
2) Are you using only the specified speakers?.
3) Is anything blocking the ventilation holes of the system?
You may also refer to the following link for additional troubleshooting steps.
PROTECT and PUSH POWER flash alternately on the amplifier screen
Dec 20, 2012 | Sony DAV-HDX500 System
Have a SONY DAV DZ370 Home theater system. Displays 'Push Power Protect'. Tried 'cold reset' and all the manual stuff to no avail. Should I reset the M16C micro-controller or is there...
Aug 11, 2011 | Audio Players & Recorders
DAV-DZ270 POWER PROTECTION
On the display it flashes 'PUSH POWER PROTECTOR'
Feb 16, 2011 | Sony DAV-DZ720 Theater System
My Sony DAV DZ860W shows Push Power Protection fault message
http://www.avsforum.com/t/944637/sony-dav-hdx466-push-power-protector-flashing-on-display
Feb 09, 2011 | Sony Audio Players & Recorders
I have Home Theater Sony DAV- DZ151Kb. Display Push Power and then PROTECTOR. I need Help
Push power protect message appears when home theater got problem in amplifier output section and any output amplifier chip becomes bad, receiver set protection mode and refuse to power up to avoid further damage in circuit board.
It is very hard for novice to troubleshoot what output chip is defective out of six amplifier output ICs in unit, check by professional is needed to solve this issue.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
Jan 14, 2011 | Sony Audio Players & Recorders
I have a sony DAV DZ230 home theatre system
on my home theater display it shows protector push power
Nov 24, 2008 | Audio Players & Recorders
74 people viewed this question
 Grubhead
Grubhead
