Question about Peavey Tour TNT 115 1x15" Combo Bass Amp
Peavey repair I can't get inside my to work on pots
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Peavey Expert
  • 232 Answers
What is going on with the pots?
Posted on Sep 20, 2014
Im trying to find a peavey pot 71191012 1MB SNGL 12MM HOR , that is the part number on the peavey valve king 212 service manual also is that pot audio,liner or log taper
Peavey can supply most all the parts for their gear and sells directly to end users. However, they now charge shipping on parts (they didn't used to) so it's best to grab more than just a single pot when you order. Corners, feet, handles, etc
Jul 06, 2017 | Peavey Music
Peavey KB100 EQ pots what value?
should say on the back of the pot
Mar 02, 2015 | Peavey Music
Slide pots for PV14 mixer
The pot needs to be cleaned. Get a spraty can of DeOxit 5. Spray it into the track and move the slider up and down a number of times. If that doesn't fix it, replace the slide pot.
Jul 30, 2012 | Peavey Electronics Peavey 00512140 PV 14...
Power problems with my Peavey PV-1500
Suspect that the pot is broken, or start cleaning all the back switches, this pv amps suffer from a terrible switch quality.
Mar 15, 2012 | Peavey Electronics Peavey Pv 1500 Power...
I have an older XR 696f. Very similar layout. Want to know how to open case to replace EQ controls and one input channel.
The part number for the level pots is
POT0259 71190259 71190259 50KB - STD - 9MM - W/DTT
Now that says a STD taper which could be standard audio taper...
The EQ pots are going to give you fits to find them, here is info:
18 SPOT0459 71190459 71190459 DUAL 50K 20MM W TAPER W/DTT AND TAP
They are duals with not only a taper, but they have a tap in the middle of the resistance element... these are very special.
FRANKLY if these pots are noisy, treat them with CRC226 which is available in the electrical dept of Home Depot. Try to get the liquid into the resistance element wiper area.
Most of the work accessing pots on a mixer is pulling knobs and taking off the nuts of jacks. There are usually a few screws holding the board to the panel but they are obvious...
Thoise special pots you will likely have to get through Peavey.
Jul 20, 2010 | Peavey Xr 8600 8 Channel Powered Mixer
The volume knob has broken off at the base on chan 1 of my peavey KB100 keyboard amplifier. part needs replacing in NW London?
Was it the know or the pot? The pot is the metal(sometimes plastic) shaft with a nut securing it to the enclosure.
Here is your nearest registered Peavey service center. http://www.peavey-eu.com/support_2_detail.php?flag=GB&lan=UK&var=ser&key=SERVICE
This could also be repaired by someone with electronics knowledge. Just would need to know the pot taper and resistance. This would be on the front of the pot on the same side as the shaft. The enclosure would need to be taken apart.
Jun 21, 2009 | Peavey VTB1 1-Channel Amplifier
Eq on channel a doesn't work on 2 units
It could be an internal ground connection on the EQ that's broken ( maybe inside the connector) ..I repaired numerous peavey products and broken grounds are common.
Feb 11, 2009 | Peavey EQ215FX Home Equalizer
PA Mixer
All mechanical switches such as sliders and pots will get noisy after time. They get mildew and tarnish on contacts. Get a can of WD-40 and spray all switches and pots inside. You can do this by inserting the straw nozzle into slider switch slot or pot space where wires and attach. Spray briefly (short burst), then work control to both extremes of travel.
Apr 21, 2008 | Audio Players & Recorders
Peavey Tour TNT 115 1x15" Combo Bass Amp Logo
70 people viewed this question
Top Peavey Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
Michial Gueffroy
Are you a Peavey Audio Player and Recorder Expert? Answer questions, earn points and help others
