Question about Radio Communications
How do i switch on H385
I mean the device button to press once it is fully charged
  • 3,320 Answers
Unable to turn it on ,only lighted screen and connection ca be seen
First of all, make sure the battery is fully charged. If you're not sure your car charger is working, try charging it with a USB-cable on your PC/Mac.
Once the battery is charged, RESET your TomTom.
Old TomTom's have a RESET button on the bottom. One model has it's reset button hidden under a cover.
Newer devices don't have a reset button. You reset them by "KEEP PRESSING THE POWER BUTTON A LONG TIME"
Try pressing even more then a minute. Eventually you should hear the TomTom "Drumm Roll" (the starup sound), and your GPS would start normally.
If this doesn't work, Try updating the device firmware using a USB-cable and the right software depending your device. Older devices use TomTom HOME, never ones use TomTom MyDrive.
I wish you a lot of succes!
May 14, 2015 | Tomtom GPS
Tip
Sony ebook Reader is Frozen, Not charging
The Sony Reader used a special type of display; the LCD can retain an image without having power. It takes power while changing the pages. In most of the cases, if the power is fully discharged, the LCD will keep the last image that was displayed it makes an impression that the Reader is frozen. However, the Actual thing is, the screen retains the last image on the screen and there is no power to change the pages. These type of situations can be resolved by charging the Reader sufficiently.
Each step in my solution is a possible resolution. Hence I suggest thatyou perform each step and check the operation.
  1. Charge the battery fully by connecting to a computer or by using a compatible AC Adaptor. It may take a few minutes (up to 15 minutes) to displaythe charging symbol if the Reader is fully drained in its last use.
  2. Once the reader is charged fully (at least 45 minutes), slide the power button to turn ON.
  3. Perform a softreset. We can perform a soft reset by pressing the reset button on the Reader.
  4. After the RESET button has been pressed, slide the POWER switch to activate the Reader device again. If the Indicator light nextto the power button on the Reader device is yellow, the unit is attempting to start up. If this is the case, allow it a few moments to complete startup.
  5. If the Reader is still not charging up properly, connect the Reader to computer or AC Adaptorand then press the reset button.
  6. Disconnect the Reader device from the computer (if applicable) and then slide the POWER switch to activate the Readerdevice. Check if the Indicator light next to the powerswitch on the Reader device is yellow (indicating it is turning on) and if the unit is responding.
    If the unit isstill frozen, connect it again to the computer or AC adapter and while connected,check if the Indicator light next to the power switch on the Reader device is red. If this light is red , allow the Reader device tocharge for one hour sothere is sufficient charge for troubleshooting.
    If the issue persists, perform a hard reset to resolve the issue. Please follow the steps to perform a hard reset:
    Under certain circumstances, moisture condensation can occur. Moisture condensation can becaused by moving the Reader device between temperature extremes or if theReader device has come in direct contact with moisture. If you suspect moistureas the cause, allow the Reader device to sit for a few hours before attempting to turn it back on.
Reader is frozen, PRS650 frozen, image stayed in PRS650, Help to reset PRS 650. RESET PRS650. how to reset PRS-650. Hard reset PRS650. How to perform a hard reset for PRS 650. PRS650 freeze, PRS-650 frozen.PRS-650 is not charging, does not turn on PRS 650, PRS650 is not turning ON. PRS-650 does not charge.
on Jan 12, 2011 | Audio Players & Recorders
Nikon s9300 - When I turn it on, the lense fully extends, but the screen stays black. I have to pop the battery out, then put back in for the lense to retract. Battery is fully charged and even tried
When the battery is fully charged, please put it in again. That means, if it is still in, remove it once again.
Switch it on, and even if you don't see a thing try to make a picture.
Then press the display button several times, to see if anything comes on the screen again.
If the camera does not respond after that, you should go back to the dealer, of contact Nikon.
Dec 21, 2013 | Nikon COOLPIX Cameras
My Htc Chacha's lcd light keeps flickering on & off it wont charge what does that mean ?
Sindia, this sound me software problem, when your device has a software problem it wont charge or start at all normally, so try to hard reset but this will delete all data for hard reset follow the instruction :
1. Switch off device;
2. After 3 min, Press and hold volume down button and power on button once it shows 3 android images appear leave the buttons and press volume down to select a clear storage, and then press power and then press volume up to start the factory reset. after this process your device wil reboot and start normally. now your device is ready to use. Best of Luck.for further help post comments.
Source :
http://www.hard-reset.com/htc-chacha-hard-reset.html
Jul 13, 2012 | HTC Chacha Smartphone
My sony ereader prs-650 is stuck on sleep mode and it wont do anything ,, it wont charge when connected to the computer
Each step in my solution is a possible resolution. Hence I suggest that you perform each step and check the operation.
Charge the battery fully by connecting to a computer or by using a compatible AC Adaptor. It may take a few minutes (up to 15 minutes) to display the charging symbol if the Reader is fully drained in its last use.
Perform a soft reset. We can perform a soft reset by pressing the reset button on the Reader.
After the RESET button has been pressed, slide the POWER switch to activate the Reader device again. If the Indicator light next to the power button on the Reader device is yellow, the unit is attempting to start up. If this is the case, allow it a few moments to complete startup.
If the Reader is still not charging up properly, connect the Reader to computer or AC Adaptor and then press the reset button.
Disconnect the Reader device from the computer (if applicable) and then slide the POWER switch to activate the Reader device. Check if the Indicator light next to the power switch on the Reader device is yellow (indicating it is turning on) and if the unit is responding
If the unit is still frozen, connect it again to the computer or AC adapter and while connected, check if the Indicator light next to the power switch on the Reader device is red . If this light is red , allow the Reader device to charge for one hour so there is sufficient charge for troubleshooting.
Under certain circumstances, moisture condensation can occur. Moisture condensation can be caused by moving the Reader device between temperature extremes or if the Reader device has come in direct contact with moisture. If you suspect moisture as the cause, allow the Reader device to sit for a few hours before attempting to turn it back on
Jan 12, 2011 | Sony Reader Touch PRS-600
Just used garmin nuvi it worked fine went into the store and now the unit is locked/frozen on the garmin logo screen
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The reset button on your nuvi 2xx, 3xx or 6xx will not restore your device to factory settings or delete any map updates. The reset button will switch your device off if you are unable to switch the device off by the power button. It will not erase any data on the device.
The reset button on your nuvi will switch the device off. The reset button can be used to switch your device off if the screen is frozen and you are unable to switch the device off by the power button.
To reset a nuvi 2xx:
  1. Look at the bottom of the device
  2. Locate the small circle with a dot inside
  3. Press the circle to reset the device.
To reset a nuvi 3xx or 6xx:
  1. Lift the antenna
  2. Locate a button with the word Reset inside
  3. Press the button to reset the device.
The device will now switch off.
Make sure to charge it fully.
Dec 29, 2009 | Garmin Nuvi 660 GPS Receiver
On a vector jump start system, does the green light have to stay on to indicate that is charged> what if only the 2-3 red light go on when i press the test button?, when the green is flashing while...
2 - 3 red lights indicate not fully charged. Green light = fully charged.
Not fully charged does not mean it will not function. For best results, your device should be fully charged. If you have an emergency and are not fully charged, it will not hurt to try to help with a partial charged device IMHO
Thanks for posting at FixYa.com
Dec 13, 2009 | JUMP START SYSTEM
No power to my ICN 520
Have you tried the reset hole? make sure there is nothing stuck in there that could be pressing on the button. When you press and hold the reset button the screen stays blank.
If you press the reset button does the unit turn on? Mine turns on when I press the reset button even after I turn the battery off then back on.
Hope this suggestion might help you restore functionality.
Jun 08, 2008 | Navman iCN 520 GPS Receiver
GARMIN c550 will not turn on
There is an ISSUE with the DEAD ZUMO, however some of the are solved, and some need to be shipped back.
There are a couple of options.
1) remove the battery, keep power button pressed for a few minutes. install battery, try.
2) fully recharge the battery with the wall charger, try
3) With a fully charged battery, press and hold the + button and press the power button(hard reset).
4) hold thumb firmly on top left of touch screen and hold power button till it switches on(hard reset).
5) Try a different battery (fully charged)
6) Ship it to Garmin
Sep 08, 2007 | Garmin zumo 550 GPS Receiver
Casio E-125
Blinking amber light means the battery is not fully recharged. Once it is charged, press the power button. If the the device still does not turn on take out the main battery and the backup battery. Put the main battery in first, then the backup battery and put the battery switch in the lock position. Press the power button and you should see initializing memory..., then starting..., then it will ask you to set up the device.
Sep 05, 2005 | Casio Cassiopeia E-125 Pocket PC
Radio Communications Logo
24 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
