Question about Hyundai Televison & Video
Hyundai dvd player not playing menu in dvd
My hyundai dvd player is not playing the menu in any dvd please help..
  • 3 Answers
SOURCE: Play all region dvd's
Found this hope it helps Multi-Region: * With no disc in the machine switch it On * Open the tray * With the remote enter: 2, 4, 0, 5, 9, 1 and 5 * A region menu appears indicating current * Press Enter until the region is set to 9 (Region FREE) * Close tray
Posted on Sep 10, 2007
  • 108 Answers
SOURCE: My Hyundai DVD player plays
On the DVD Player, there maybe somewhere where you can change the output to the television (Scart) from RGB to Component or Composite-mode.
RGB causes some displays which cannot handle the RGB signals to black and white.
I hope this fixes your problem.
Finally, some TVs designed for PAL cannot handle NTSC discs played through them. It causes the display to also go Black and White. If this is the case there is nothing you can do except change the display/TV.
Don forget to rate.
Posted on Mar 17, 2008
SOURCE: DVD will not finalize
I have a Zenith XBR413 that I have a problem with when I copy from VCR tapes to DVD-R discs. After I copy them, I can finalize the disc using the SETUP button on the remote and then choosing the very bottom disc icon at the bottom of the menu screen. It then leads you through the finalization procedure. But the disc will still not play on any DVD player but the XBR413
Posted on Jul 03, 2008
SOURCE: problem with Hyundai DVD 320a
Turned out to be oxidisation on the battery terminal in the remote--scraped it off with point of a penknife to ensure good electrical contact and hey presto!!
Posted on Feb 23, 2010
  • 8457 Answers
SOURCE: need replacement remote for Hyundai 320A dvd
Try website 1-800-remotes Factory original.To buy an exact remote.My opinion univeral remotes very problem's matics even u have ur tv codes in the manual,sometimes none of those codes in the manual will work with ur tv model,even there codes for it.
Posted on Apr 06, 2010
Hyundai 320-A dvd player codes
Hyundai DVD-320A / DVD-360A / DVR-510C
  1. Method 1:
  2. Turn on the player (without a disc inserted)
  3. Press 7, 7, 0
  1. Method 2:
  3. Press 7, 7, PLAY
  4. Select region (0 = multi-region)
  5. Press SETUP
  1. Method 3:
  2. Open the disc tray
  3. Press 3, 8, 0, 0
  4. Select RC (0=codefree)
  5. Press SETUP
  6. Close the disc tray
Apr 20, 2016 | Hyundai Televison & Video
Read cd but not dvd
This is due to condensation on the circuits. Play music is less demanding than dvd. After playing cd for a long while, you may be able to play one dvd, then several in succession later.
Dec 24, 2010 | Hyundai Televison & Video
I have recorded many DVD's with you Centrios EDW8020 it works great however I can not play them back on other DVD players. The disc may not been finalized to finalize them I can not acces Disc Utilities...
Hello Joe,
Most of these DVD recorders are really meant to be recorded and played basically on the same machine... Now if the DVD player (that you wish to play, is an older model that is the problem)
But, as far finalizing place the DVD unto tray... close it...now that menu (using the remote) press it..you should have a menu and top menu (top is settings) the menu is play dvd jump to next scene..in settings an Disc that is not finalized should be able to name it and customize it...note if you have use an DVD+/- R you must format prior to use (finalizing is on this same)
Nov 25, 2010 | Televison & Video
Problem with Hyundai DVD 320a
Feb 22, 2010 | Hyundai ImageQuest DVD 320 A DVD Player
How do you change the audio sounds, every time i play a dvd it sounds like it's being played in a big empty shed, very echoy.
hi if you select menu on tv ? then select sound you will see treble selection /base selection/ and balance you then select one scale and move left or right as you like then select other scales in turn aand adjust to your liking ? when complete press menu to exit then readjust if you wish ?
Dec 21, 2009 | Hyundai Televison & Video
Hyundai HY601G does not play all region DVDs
Then it's set to only play certain region's dvds. Get a region free dvd player or maybe you can check online for a way to unlock the region locks on it.
Oct 06, 2009 | Televison & Video
Home dvd player won't play a burned dvd
Not all burned DVDs are compatible with all home DVD players.
Some things to do to help compatibility:
1. Use only DVD+Rs.
2. Burn at a slower speed (4x or below).
3. Make sure the software you are using to burn the DVD creates a menu. Most DVD players won't be able to play a DVD unless there is a menu; usually you can tell the software to skip the menu if you want but it still must be encoded onto the DVD.
Thanks and please take a moment to rate this solution with a fixya rating. :c)
Jan 25, 2009 | Ahead Software Nero 6 Ultra Edition...
I have a Canon A540 digital camera . we can copy video clips to DVD and this can be played onto my notebook BUT we cannot play these clips through the DVD recorder onto the TV. Can you please...
Hi, DVD players can only play DVD Standard format and some standard codec (divx,...), so if you want to play your clip in a DVD player you must convert them to the standard format... an easy way is useing nero express:  nero express > video > DVD, then add yor clips, make a nice menu and then burn it on DVD. Also you can use Nero vision for better menus or Ulead DVD movie factory for even better Menu if you can spend money. ;) I hope this helps.
Nov 02, 2008 | Canon Cameras
Televison & Video Logo
18 people viewed this question
Top Hyundai Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jay Seifried
Level 1 Expert
Are you a Hyundai Televison and Video Expert? Answer questions, earn points and help others
