Question about Monoprice 8247
No signal to the satelite speakers
I recently bought a monoprice speaker system, I am trying to connect it without the AV receiver/ Amplifier and it has no signal output to the satelite speaker, can you assist? Must I use an AV receiver.
    Problem Solver:
  • 6 Answers
I don't know what you are trying to get the signal from? But yes you need to power the setup with the outputs from a av receiver.
Posted on Apr 22, 2014
Testimonial: "yes"
How do i hook up bose accustimass speaker to my radio?
Acoustimass speakers need to be driven by a Hi-Fi amp/receiver or AV receiver. So the thing that's driving them needs to be an amplifier.
Unless your radio is also an amplifier then the radio and the Bose speakers are not directly compatible. There's no suitable output on the radio that generates the correct signal in sufficient power.
Sep 07, 2014 | Bose Acoustimass 5 III System
Pioneer vsx 515 overload and shuts down what can i do to fix this problem.
hi,
First of all remove all the speaker connections from the amplifier. After that power the amplifier and check the overload (protect) show or not . if not, then any of the speaker is damaged or you have to check the impedence of your receiver and speakers. It will be written on the rear side of both receiver and speakers in ohms. PIONEER recommend to connect 8 ohms speakers in to this AV receiver. If you are using 6 ohms speakers you have to do some setting in the AV receiver.For that do the following
1. With the receiver in standby, press STANDBY/ON while holding down the SPEAKER IMPEDANCE button.( Each time you do this, you switch between the impedance settings: )
SP 6 OHM - Use this setting if your speakers are rated at 6 Ohms
SP 8 OHM - Use this setting if your speakers are rated at 8 Ohms or more
You are not able to connect speakers with impedence bellow 6 Ohms with this receiver. Becuse the AV receivers impedence range is 6 - 16 Ohms.
If then also it shows protect you have to check the amplifiers hardware.
AV receivers shows protect mode , when there is a hardware fault in side it. Its a warning that some thing is wrong.
Normally AV receivers show this when any of the output amplifier get some problem. there are six amplifiers in this AV receiver. May occur when the output diver transistors of any of the amplifier become shorted. if the output transistor get shorted this will lead to flow of current through the speakers. To prevent this there is a protection circuit for each channels. One combined output of this protection circuit is connected to the system control. when the any of the output amplifier fails, the protection circuit detects it and switch of the speaker and sent data to the system control. when the system control get this data it will give a warning to the customer through display that PROTECT.
You have to check the amplifier.
for that you need digital multimeter,soledring iron screwdrivers etc
open the amplifier , then power it on. connect the negative terminal of the multimeter any where in the chase( metal body of the amplifer). then connect the positive terminal to all the output transistors emitter pin one by one . the voltage should be bellow 0.5V. If any of the emitter of the transistor shows voltage more than 0.5V., then that amplifier stage is faulty. Remove the transistors and check it. if it is shot then replace with a new one.
after replacing the transistors do not power up the amplifier directly from the main. You have to put a bulb of 60 watts in serial.
You can do this easily remove the mains fuse. put the bulb in a holder. now you have to wire from the holder. connect one of it to the one end of the fuse holder and the other wire to the other end of the fuse holder. Why using a bulb is, if there is any further problem in the amplifier stage on which the transistors replaced, there is a possibility of the new transistor get damage. if we use a bulb in serial with its mains supply ,when any overload in the amplifier occur the bulb will drop the current, by lighting itself.
After connecting the bulb in serious power on the amplifier. watch the bulb. It should light for one or two second and go dim . if so check the display, is there is protect mode is on or not . if not and come back to normal operation ,then remove the power , remove the bulb insert fuse and check
connect the power and check.
If the bulb shows bright light then there is some component also faulty in the same amplifier. after removing the power you have to check again the amplifier stage of which the transistor is replaced, for any other faulty components.
ok
Jul 27, 2011 | Pioneer VSX-515 Receiver
After a few seconds it says power off and then shuts off
hi,
remove all the speakers connected ur receiver . and try again. if working properly with out speakers . any of ur speaker have some problem. if problem remains, the amplifier side of ur av receiver is faulty. that's why it protecting and goes off. fist check it without speakers and conform.
ok
Dec 17, 2010 | Pioneer VSX-D509S Receiver
When I hook up the speakers in the back to the left and right side for the in and out, do I connect the front or rear speakers. do the speakers connect to the subwoofer first then to my receiver or the...
I was trying to find an owner's manual or picture of the rear panel of the sub, but had no luck. The subwoofer is a powered type - or "active" speaker. This means it has a built in amplifier. These active subs usually provide for one or both "low level" and "high level" inputs. Low level signals are usually carried by shielded coaxial cables and have RCA type plugs on the end. The low level is also called "line level". This is an un-amplified signal that might be heard on cheap earphones - but that's about it. It is similar to the output of a tape deck, DVD or phonograph. These signals require an amplifier to be heard. If you have a sub woofer output on your receiver or amplifier, you could run a patch cable between the low level input on the subwoofer and the subwoofer output of the amp or receiver. You receiver or amp may call this output "low frequency effects" or similar. The front and rear speakers would then connect directly to the receiver or amp's corresponding connections.
If you lack low level outputs on the amp or subwoofer, you'll need to run speaker wires from the amplifier or receiver's front left and right speaker output terminals to the subwoofer's high level input terminals. High level signals are speaker connections or amplified signals. These are typically connections that accept bare wire connections. The front speakers would then connect to the subwoofer's front left and right speaker output terminals. The rear speakers connect to the amplifier.
I hope this helps - and good luck!
Nov 24, 2010 | Cerwin Vega AVS-632 System
I have bose 901 with a rotel receiver im still not getting the sound i want will a power amp help get that surrond sound im looking for
The use of 901's in any digital AV receiver setup for anything EXCEPT STEREO listening through the 901's alone requires you to have a separate amplifier for them and to avoid having to use a Tape Monitor.
That is because if you activate any Tape Monitor circuit at all, you will kill any digital sources. That is a function of AV receivers in general, nothing to do with 901's. However, you can still draw the Front Left and Right signals out of any Pre-Out (with a Y-cable set, looping the Pre Out directly back to the Main In) or Tape Out jacks (remembering to NEVER activate that monitor on the receiver), go into the Active EQ's Amplifier Connections; then Out of the EQ's Amplifier Connection to a separate amp and attach the 901's to that amp. This way you won't introduce proprietary and potentially damaging Active Equalization back into anything in the AV Receiver with its conventional speakers.
Get yourself a nice separate amp, draw the Front L&R pre-out signals from wherever you can find them. On many, there is a pre-amp out for every channel in case you want to run external amps for any channels. That is how my old Pioneer VSX-36TX is equipped. For others, you may have to borrow the signals from a typical Tape- or Adapter-Out RCA pair. Just remember, AV receivers disable digital inputs as soon as you switch in a Tape Monitor, so choose one you won't have to switch IN. The signal Out is always there regardless of the monitor state.
The AV Receiver can still drive the Center, Surrounds and the Sub(s) as it is designed. This is how mine is wired.
Come to think of it, you could still have conventional Front L&R speakers on the AV Receiver, but why? Maybe one would prefer the 901's for music and some other speakers for surround. Level matching with the 901's to conventional front speakers would only be possible if the separate amp has its own volume, but it would work. Maybe I'll try it someday. None of my current amps has a volume control.
Nov 29, 2009 | Bose 901 VI Main / Stereo Speaker
Which home theater recivers are compatiable with the 901 equalizer and speakers?
Nov 21, 2009 | Bose 901 VI Main / Stereo Speaker
Bose 901 Hook up help !
Oct 22, 2009 | Bose 901 VI Main / Stereo Speaker
How to connect old 901 Bose equilizer to amp/receiver
If you plan to use them with a home theater, you will need a seperate amplifier, as most a/v receivers don't have tape monitors. With an integrated amp hook rec out to the input on eq hook output on eq to playback on tape mon. with seperates hook pre amp out to input on eq, output on eq to power amp input.
Jun 23, 2009 | Bose 901 VI Main / Stereo Speaker
Panasonic av control receiver sa-he200
On any 5.1 system without 2 zone capabilities when you press speaker "B" the receiver uses the rear channel amplifiers to send signal to the remote speakers. As a result the receiver cannot output signal to both the rears and the remotes at the same time.
Feb 26, 2009 | Panasonic Audio Players & Recorders
Problem with pioneer vsx-916 av receiver
Be sure you have proper impedance with both sets connected. Some units have a selector switch in the back of the receiver to set the proper bias. ...accordianman
Jan 21, 2008 | Pioneer VSX-915 Receiver
Monoprice 8247 Logo
56 people viewed this question
Top Monoprice Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Monoprice Audio Player and Recorder Expert? Answer questions, earn points and help others
