Question about Vw Mk1 Rabbit Caddy Jetta Pickup Golf 1.6 Turbo Diesel Snorkel Air Intake Hose
How to replace gasskets of vw golf 1
Oil leak
  • 44 Answers
Clean engine around oil leaking down, recheck after warmed up. You should see exactly where the leak is coming form and save yourself un-neccesary cash spent. Find the leak then resubmit for procedure.
Posted on Apr 13, 2014
How to replace gasskets on a vw golf 1
Head Gasket failure. Go online to mm, Amazon and search for a used Bentley Manual for your car. I have three VW's so trust me on this one.
Mar 26, 2014 | Vw Mk1 Rabbit Caddy Jetta Pickup Golf 1.6...
97 vw golf 1.8 there is a squar box where oil filter fastens to. oil is leaking from top of this box. what is this box and how i fix the leak?
The box is the oil cooler. The oil is most likely leaking from the oil cooler seal. The oil cooler is the square aluminum piece that the oil filter screws onto. To replace the seal, remove the filter, remove both coolant hoses that attach to the cooler, remove the nut that secures the cooler to the block and slide the cooler off the tube. Replace the rubber o-ring seal which is available at the VW dealer. It's inexpensive. Replace everything in reverse order. Good luck
Jan 05, 2011 | Volkswagen Golf Cars & Trucks
I need to know where the fuel pump relay (J17) is for a 2004 mk5 vw golf
You very likely are going to replace the fuel pump, well i recomend you check the vw recalls on failing fuel pumps or related fuel lines and fasteners.
I own a 2004 vw golf and began to leak fuel at the fuel delibery nipples right out of the fuel pump. the problem is that either there tension on the nipple and cause to crak thus leak, or the fuel line is short and pulling toward the rear right tire causing it to crak and leak. the
Volkswagen Golf Recall 05V154000 is the solution
this recall is for a vw golf 1999-2000 but all the fuel pumps around vw 's 1999 up to 2006 have the same problem but you need to put acomplain with the NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO HTTP://WWW.SAFERCAR.GOV.if your car is not under these recall. Fuse # 28 will stop the fuel pump so you can remove it
Dec 07, 2010 | 2004 Volkswagen Golf
Vw golf has had diagnostic check found fault code P0023
This trouble code is related to a faulty camshaft sensor or to be more precise the camshaft position actuator circuit is open. There are 2 camshaft sensors on the Golf and the camshaft sensor that this code relates to is behind the timing belt. This code indicates that the solenoid that adjusts the cam timing has an issue - the circuit is open. The actuator itself may be faulty or if you are lucky it may be wiring related or be a bad connection to the actuator.
Jun 21, 2009 | Volkswagen Golf Vw Diecast Model
Gauges say no pressure in engine 1995 vw golf
Get someone to check oil pressure with a mechanical gauge, to verify whether you have oil pressure or not. These engine/vehicles, have 2 warning sensors & a control module in the instrument panel. Once you know you have pressure for sure, then you can proceed from there.
May 09, 2009 | 1992 Volkswagen Golf
There are two pressure switches. One for oil pressure and one for a dirty oil filter. Are you sure you've changed the right switch. If car drives for 30 mls it doesn't sound like you need an engine. The spluttering is likely to be completely unrelated to the oil warning I suspect.
Cheers John
Dec 19, 2008 | 1995 Volkswagen Golf
VW Golf 2001 Oil is emptying out
your cars engine piston rings are worn the engine is burning the oil the engine needs to be rebuilt
Dec 18, 2008 | 1986 Volkswagen Golf
Vw Mk1 Rabbit Caddy Jetta Pickup Golf 1.6 Turbo Diesel Snorkel Air Intake Hose Logo
156 people viewed this question
Top MK1 Originals Vehicle Parts & Accessories Experts
mekanik84
Mark Cunningham
Mark Cunningham
Rigger
Are you a MK1 Originals Vehicle Part and Accessory Expert? Answer questions, earn points and help others
