Question about Vw Mk1 Rabbit Caddy Jetta Pickup Golf 1.6 Turbo Diesel Snorkel Air Intake Hose
How to replace gasskets on a vw golf 1
Oil mixing with water
  • 44 Answers
Head Gasket failure. Go online to mm, Amazon and search for a used Bentley Manual for your car. I have three VW's so trust me on this one.
Posted on Apr 13, 2014
How to replace gasskets of vw golf 1
Clean engine around oil leaking down, recheck after warmed up. You should see exactly where the leak is coming form and save yourself un-neccesary cash spent. Find the leak then resubmit for procedure.
Mar 26, 2014 | Vw Mk1 Rabbit Caddy Jetta Pickup Golf 1.6...
Oil and Water mixing in the reservior
Bad radiator, blown head gasket.
Apr 06, 2012 | Cars & Trucks
Vw golf losing coolant through the overflow (expantion tank) when cooling down. thermestat changed. not overheating even at high speed. no water in the oil or oil in the water. the oil is normal colour ....
If there is definately no air in the system and everything is working properly have you changed the pressure cap on the expansion bottle? Very unusual but if everything else is ok then it might be worth a shot. Caps have a pressure release mechanism biult into them.
Oct 16, 2011 | 2001 Volkswagen Golf
I have a 90 civic ex 1.6 and it was mixing water in oil and blowing antifreeze out the exhaust when i got it. pulled head and the gassket was blown. replaced it and the problem remained the same. replaced...
To check the block, you can magna flux it or have the machine shop do this for you. Also, was the head a new or used head or reconditioned? Is it warped and in need of shaving?
Perhaps, the new head gasket is leaking, even though it has been replaced.
I know it's a lot of work to get the Honda head gaskets to work right.
Jan 31, 2011 | 1990 Honda Civic
Water and oil mixing in my car engine vw golf mk3 cl 1.4l
Sounds like you have a blown head gasket or a cracked block, pull the plugs and see witch one is wet that will be the cylinder that is leaking.
Jun 03, 2010 | Volkswagen Golf Cars & Trucks
Oil in expansion (coolant) reservoir Golf 1.4 98
replace the oil cooler first before you change the head gasket ,but normally a 10 year old vehicle often has gasket fatigue ,not made like a good old fashioned copper head gasket ,they rarely went wrong
May 11, 2010 | Volkswagen Golf Cars & Trucks
Thermostat for VW golf 1996 The temp gauge raised to almost 220 but water temp light did not flush at all. Is it possible that the car has no thermostat?
Usually if a vehicle has NO thermostat the engine runs too cold for to long. So I suspect your VW has a thermostat. Suggest you check to make sure you have ample antifreeze, and that the fan is working properly. If those two things are O.K. then a blocked radiator or water pump issue will need to be checked out. With a 50/50 mix of antifreeze 220 degrees will not harm your engine. Good Luck.
Apr 26, 2010 | 1996 Volkswagen Golf
LOSS OF POWER
My car has now been sorted.
Turns out it was a problem with the feul pump. cost another £200 to get everything done but its been running fine for a few weeks now.
May 21, 2008 | 2004 Volkswagen Golf
Vw Mk1 Rabbit Caddy Jetta Pickup Golf 1.6 Turbo Diesel Snorkel Air Intake Hose Logo
204 people viewed this question
Top MK1 Originals Vehicle Parts & Accessories Experts
mekanik84
Mark Cunningham
Mark Cunningham
Rigger
Are you a MK1 Originals Vehicle Part and Accessory Expert? Answer questions, earn points and help others
