Question about Sony HDRSR12E Camcorder
Shutter wont open when i turn video camera on
When I switch my video camera on the lens shutter dose not open, what can I do to try and fix this problem.
  • Arthur Cowgill Mar 30, 2014
    sorry i ment cover not shutter, its the 2 blades that open to view the lens, it opens a bit and its like looking through a door that is a jar. the motor seems to be making a whirling noise as if its trying to open it more, it was yoused last on the beach and it was a bit windy, so i as thinking that it might have got some sand in it, i can take pics with it but they look like they were taken through a slitely open door, any idea what i can do, ive tryed a fully charged battery and turned on and off a lot to try and unstick it, but its still the same, thank you.
  • 53 Answers
Oky there is small spring inside.check that,another thing it could be inter lock with shutter.may it over lapping each other
Posted on Mar 27, 2014
5 Suggested Answers
Arpi
  • 326 Answers
SOURCE: Shutter will not open/close (Disengaged from motor - "flopping" loose)
Well, replacement of the shutter unit (lens barrier)instead of the repair seems more realistic... Please contact your nearest Sony Service for the price estimate. If you need more info please advice. Arpi
Posted on Mar 20, 2007
Arpi
  • 326 Answers
SOURCE: Shutter Won't Open
Well, replacement of the shutter unit (lens barrier)instead of the repair seems more realistic... The part number is: 178739811 Please contact your nearest Sony Service for the price estimate. If you need more info please advice. Arpi
lock123
  • 6831 Answers
SOURCE: my DCR-DVD703E lens shutter wont
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 27, 2010
ftw1952
  • 10319 Answers
SOURCE: when i switch on my
You have a weak capacitor that will not give enough power to keep the lens opened for use. The cost to repair it can cost as much as a new camera like it
Posted on Dec 10, 2010
Shutter is stuck open on the digital camera w1200. When i turn it on the shutter goes in a little than tries to go out and it makes this weird loud clicking noise and i cant see a screen and when it is...
I think what you're referring to is the lens assembly not moving in and out correctly. The shutter is inside the camera out of view. Go to this website for possible solutions:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Oct 16, 2011 | General Electric W1200 Digital Camera
My Canon PowerShot SD 1000 has this problem: when i turn on the camera, the display is black and i can`t see any image through.Same problem on the video mode. it doesn`t appear any error mesage. i tried to...
A stuck shutter is another common failure mode for digital cameras (including my wife's SD1000, which I have to fix every once in a while with the following easy technique).. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help. By the way, for your camera model, I've found it best to just alternate back and forth between opening the battery door while taking a picture, and gently flicking the lens barrel with the tip of my finger. Usually, it only requires a few tries for my wife's camera, then it's good for another couple months.
Jun 02, 2011 | Canon PowerShot SD1000 Digital Camera
My DCR-DVD703E lens shutter wont open.. even when i turn it on and off and on again it wont open.. could someone help me? i bought it at a camera store for over 5231$.. i can't afford to repair it with...
Hello
Regards
Andrea
Sep 27, 2010 | Sony DCR-DVD703E DVD Camcorder
When i switch on lens comes out and opens but
One of three things. First try pressing the DISP or DISPLAY button on the back of your camera. If that didn't correct the problem, read on.
Second potential issue, if your camera's a Canon, and if your camera is in the following list, it's likely a CCD problem. Please see this link.
Applicable cameras include: A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S230, S400, S410, S500, SD100, SD110, IXUS V2/V3/300/400/430/500/II/IIs, IXY Digital 200a/300a/320/400/450/500/30/30a
But if your camera was not listed above, A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
May 03, 2010 | Canon Cameras
The shutters on my Fujifilm E900 wont open or close properly.
Do you mean the lens cover on the end of the lens Is not opening properly, or the shutter inside the lens?
Aug 24, 2009 | Fuji FinePix E900 Zoom Digital Camera
I take out door photos during day time,Iam getting white screen.
First make sure the mode selector dial is set to the red camera without an M next to it (ie you're in Auto mode and NOT in manual mode). If so...
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Now the A410 is not capable of taking 15 second exposures as recommended for the fix. Instead try setting the camera to manual mode, turn off the flash, got to a darkened room, and take a picture. Open the battery door while the red and yellow light are flashing. If after many tries this does not work, then consider trying Fix #5a on the site. But do so with the camera turned off and the lens retracted to lessen the chance of damaging the lens mechanism.
Jul 05, 2009 | Canon PowerShot A410 Digital Camera
Camera wont stay turned on
I had the same problem - found the answer on another forum: remove battery and memory card, press shutter button twice, replace battery and memory card, and switch on.
Nov 12, 2008 | Samsung Digimax i6 PMP Digital Camera
Kodak Easy Share 663 Camera Help
Get onto the Kodak Tech Support site If it is in warranty they will fix/replace it If it is out of warranty there may be a reasonable swap out offer.
Jul 16, 2007 | Kodak EasyShare C663 Digital Camera
Sony HDRSR12E Camcorder Logo
78 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
