Sony mdmx4 Hi I have a problem with a Sony mdmx4, I load any minidisc it says toc reading for about 5 sec then it says uploading, the minidisc is ejected and that s it.....please help...thank you xavier.
    Scholar:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 134 Answers
The recorder cannot read the table of contents on the disc.
You may have a bad disc but I think the disc might have been recorded on another MD deck which may have a different extended format recorded on the disc. Sony over time offered a lof of different recording options and some of their decks can read some of them while others cannot.
I'd check your player with another disc to see if this is the one disc you mention or all discs. if it is all discs the recorder has a problem due to a dirty laser or damaged head so it cannot read the table of contents.
Posted on Aug 13, 2014
SOURCE: ONKYO HI-MD DECK md-133 can't edit Sonic Stage formatted minidiscs
Anything downloaded from Sonicstage in Atrac3plus cannot be edited on the deck. Sony put that restriction so you don't change anything. They love DRM on music. Stick to old MD, much better.
Posted on Aug 24, 2008
SOURCE: Technics SJ-HD501 Minidisc Player Will not accept Disc
hello
Posted on Oct 07, 2008
SOURCE: MDS-JE480 MiniDisc Deck
The problem with the TOC reading and then appearing C13 is a problem with bad electrical contacts.
Remove the connection to the mains outlet, remove the top cover (5screws) and the remove the 2 paper flatcables that connect the main PCB and the disk unit on both sides. Plug them back in and possible your problem is solved.
A better solution is, of coarse, to replace both cables by new ones, as the quality is rather bad, and once disconnected, they should be replaced.
Good luck!!!
1000 soluciones
Posted on Jun 22, 2009
TOLhamRadio
  • 509 Answers
SOURCE: sony mdm-x4 when I load a disc it shows me blank
You cannot remove power from a minidisc player after you are done recording as it updates the TOC when you power down. If you had switch set to timer "REC" and power up the unit it should update the TOC, otherwise all is lost.
Posted on Jan 27, 2010
Obertelli
  • 3006 Answers
SOURCE: Hi every time I load a minidisc into my MDS-JE480
The error means that the player is unable to read the table of contents (TOC) on discs any more.If it's an occasional error then you can try switching to TDK blanks as they seem to be easier for flaky players to read, but if it's happening regularly to all discs then your machine is unrepairable due to a total lack of spare parts.
On the plus side, there are millions of MD units now lying unused as folks have moved on from them and as they're mostly worthless people don't generally bother with trying to sell them. Almost every piece of MD gear I own has come free of charge via my local FreeCycle and Freegle groups. Whatever you do, don't buy a used player from anyone: they're all getting on now and the TOC error is an age-related fault which may occur at any time.
If you wish to see exactly what features other machines have then visit the superb equipment browser at minidisc.org. The site is hosted but n longer maintained though so some information is out of date, but it's still the most comprehensive source of free information about MD available.
Sorry here's probably no hope for your MDS-JE480, but I hope that my reply has given you a practical alternative means of solving your problem.
Posted on Oct 07, 2010
SONY MDS JE 530. (C14) Toc error.
Your owners manual (you DID read your owners manual, right?) says the machine cannot read the TOC on the disc.
It might be a disc problem and it might be a deck problem?
Have you tried a different minidisc?
Have you changed any of the SET-UP settings? Take a look at them, too.
Apr 01, 2013 | Audio Players & Recorders
Rom what I understand it is a memory battery My MDM X4 Says Battery Low.In this Mini Disk player easy to repair weak battery.
My mistake. Obviously, there IS an MDM X4.
Your owner's manual makes no mention of a battery. http://www.minidisc.org/manuals/sony/sony_mdm-x4.pdf .
I found it at http://www.minidisc.org/part_Sony_MDM-X4.html .
Oct 25, 2012 | Sony Mdmx4 Minidisc Multitrack Portable...
You threw me because it the X4 is NOT a multi-disc player.
Go to this page to download the owner's manual and the service manual. http://www.minidisc.org/part_Sony_MDM-X4.html
Oct 24, 2012 | Sony Mdmx4 Minidisc Multitrack Portable...
My sony md player wont read HI mini discs
The 480 is not designed to read HI MDs. If I remember right, it can read them as regular discs.
You can always purchase a HI-MD recorder, if that is important to you.
Apr 30, 2012 | Sony 5 Pack Hi-Minidisc 1gb w/Case...
Hi. I have a Sony MZ-N710 Mini-Disc Walkman which wont read discs and also does not charge. If power is connected via the charging station or directly, or via external battery adapter the spinning disc...
Possible that the optical head unit has failed in your walkman and might need a replacement. It will be adviceable to seek the cost factor of a replacement unit of Sony that might turn out expensive ... to the entire cost of the set.
So unless the optical head reads there is no data transfer or processing.
Nov 03, 2010 | Sony MZ-DH710 Personal MiniDisc Player
Sale c13 read error
C13 read error means that the player is unable to read the TOC (Table Of Contents) on the minidisc. it has to read this first so that it knows where everything is stored on the minidisc.
TOC errors can be caused by faulty minidiscs, those which have been incorrectly finalised or by a faulty head assembly on the machine.
If possible, try to see if you get the same problem with different brands of minidisc, and also whether minidiscs recorded on other machines work on your player and whether minidiscs recorded on yours work in other players. Report back with what you find as it helps determine whether the player itself is at fault.
In reality though, it's a 9 year old unit and like all optical disc devices, minidisc heads do not last forever. If the head has failed then your only fix is to replace the player as spare parts are no longer in production and existing stocks are almost as rare as fresh dodo doo-doos.
Mar 16, 2010 | Sony MDS-JE470 Mini Disc Player
Sony mdm-x4 when I load a disc it shows me blank disc, before that TOC reading. how can I get my record back?
Jan 22, 2010 | Audio Players & Recorders
Sony minidisc MDS-JE530 c13 rec error
This could be a solution for your problem, if you get a C13 error it's because of dust on the lens causing TOC read errors. Try blowing out dust using clean compressed air (the kind in the can used for computer maintenance).
Aug 02, 2009 | Sony MDS-JE330 Mini Disc Player
My minidisc deck Sony MDS-JE330 shows error C 13 when I try to insert a monidisc...
Amazing what google can find...
I was ion touch with the Sony tech dept. If you get a C13 error it's because of dust on the lens causing TOC read errors. I didn't have any compressed air in a can so I used a soccer ball hand pump and pumped a ton of air just inside the door of the unit. 2 seconds later it worked fine. No cleaner MD needed.
Jun 09, 2009 | Sony MDS-JE330 Mini Disc Player
SONY Walkman Mini Disc MZ-R70 W/Remote RM-MZR55.. records 3 or 4 songs perfectly then it starts flashing TOC EDIT and locks up?
are you using the computer with it, or using a line input or microphone input? How is the battery? If the battery gets really low it will do a TOC EDIT to save what you've got, or you lose everything.
Apr 22, 2009 | Sony Walkman MZ-R700 Personal MiniDisc...
121 people viewed this question
 Grubhead
Grubhead
