Question about Logitech Z623
Logitech z623 110v burned to 220v what parts need change i need help
I change varistor and fuse when i plug 110v still burn one fuse...why?
  • Logitech Master
  • 3,320 Answers
You have a direct short in the power board. Replace the speakers.
Posted on Mar 29, 2014
What part of a dehumidifier burns out plugged in 220v
BOOM. Shot. The board could be bad, the motor, anything.
Apr 04, 2014 | GE Dehumidifiers
How would you know if power supply surged in my 110v toshiba e-studio283 because it might plugged into 220v by the operator?
Check the fuse. Normally, it would represent a dead set when accidentally plugged to a higher voltage. If you are lucky, the fuses will go off. On the power supply board, there is usually a filter stage and a voltage suppressor stage. The metal oxide varistor will pop or burn out when the appliance is plugged into a higher voltage.
Feb 02, 2014 | Toshiba 2830c,estudio,color...
I accidentally plugged my PC on a 220v while it was set on 110V
open the Power supply Unit and find the components that blown, usually varistors and of course fuse
Jun 03, 2012 | Gateway 507GR PC Desktop
Does anyone know what is the varistor datasheet of dyson fan AM01?
We have no way to look this information up. I suggest you contact the factory parts help line, they can id the part by the location in the appliance.
Please rate my help for Fixya, it helps to improve my standing on the site. Thanks
Jan 18, 2012 | Vacuums
There is no power to the subwoofer when its pluged in
hi; try to check the power cord and AC plug if still good condition, if ok.
open the back cover of you wooper using screw driver,search the fuse where AC cord was connected,
if you find the fuse check if it's blown. some wooper has varistor and thermistor for protection,
try to check if it has burn parts, you cen remove it and replace it by soldering iron, you can buy these parts at your local electronic store.
if you cannot do this soldering things, call a repair technician
thanks hope this help you,,,
Sep 05, 2011 | Sony SA-WM250 Subwoofer
My charger is accidentaly connect into 220v and this is burn. im here in philippine. its this to repair and i use again...
Is this a 110Volt version that you plugged into 220v?
There is a ceramic Fuse inside the unit that might be blown. It is the first thing on the circuit board near the power cord connection.
Open the unit up and post a photo of any burned components ?
Jul 10, 2011 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
My Sony Bravia LCD TV Got 220v Wile It Should Get 110v,And Went Off
hi...if you have plug the TV in 22oV instead of 11V..it automatically blown the fuse..the power supply has this Varistor it will shorted and blown the fuse if detected high voltage....I suggest you replace the fuse and check for any other defective parts in the power supply section....check for bloated capacitors.. shorted power switching transistor... if none TEST RUN..let see if your TV will switch ON...please rate and vote...
Feb 17, 2011 | Televison & Video
I plugged it into 220V outlet and Brother HL 2140 only accepted 110-120V. Is there a fuse somewhere I can access and replace? THank you.
hi. I had the same problem and to fix it you need to take printers right-side cover off. Underneath you'll find a Power Supply Board - hidden under metal cover. Take it out and disconnect two cables from it. Now, I had to replace an fuse 125V 4A and varistor E241AD 83P on the Power Supply Board in mine HL-2140. It works fine now.
Note: I could not find the exact replacements in electronic store so I used:
- fuse: 250V 4A
- varistor: FNR 10K241 (241 is the important number)
Hope it helps.
Oct 28, 2010 | Brother HL 2140 Laser Printer
I have a Brother HL2140. It was plugged into a 220v outlet, is there a fuse that can be replaced?
- fuse: 250V 4A
Hope it helps.
Oct 15, 2010 | Office Equipment & Supplies
Samsung TV plugged into the wrong power outlet
maayong buntag dong,,you can do it by your self i teach you how,Open the back cover of your TV.Along with the AC power cord there is a component called varistor this varistor serves a protection for over voltage.Its color is green round shape with two terminal pins just remove it from the board replace the fuse with same rating and your tv will work again..anyway im from bicol albay.
hope i helped you..
please rate my help tnx dong!
Jun 06, 2010 | Televison & Video
Logitech Z623 Logo
298 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
