Question about American Standard Contemporary Kitchen Sink Liquid Soap Dispenser - 4305.20...
I have 2 of these pumps.. one doesn't pump anymore... it is not clogged it just doesn't siphon up. Is there a replacement part? This is installed with a long neck for extra thick granite undermount sink... thanks for the response
  • 297 Answers
No there is not a part you can buy,you must replace the whole unit.
Posted on Jul 22, 2009
Water did not drain
see the causes and fix it. God bless you
If your washer won't drain, check these: It spins, but doesn't pump It doesn't spin or pump It pumps, but the water returns It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out. To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port. Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job. If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump. It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems: If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Sep 22, 2012 | Kenmore HE2 Plus Front Load Washer
Washing machine does not empty
see the causes and use the common sense, God bless you.
Sep 19, 2012 | Ariston Technologies Washing Machines
I have a Whirlpool Ultimate Care II washing machine (model LSN1000JQ0). The washer will fill with water and begin to agitate. Shortly after it will stop and will not drain. I've cleaned all hoses
see the next steps and use the common sense: God bless you
Aug 01, 2012 | Whirlpool Ultimate Care II LSQ9564J Top...
GE washer WCVH6800J1WW - fabric softener doesn't empty
see the causes and remedies:
drain lines clogged, repair+sock in outer tub port, if the lines is not clogge the problem is pump replace
frozen pulley pump, replace
It pumps, but the water returns improve the draininin laundry, if have reaches 4 inches cut off the excess. if is lower install air/gap siphon break assembly.
God bless you
Jul 18, 2012 | Washing Machines
Kenmore washer not draining
drain line is clogged+some sock inside remove+pump defective, if lines is not clogged.
frozen pulley pump, replace,try to rotate manually, if donot replace
improve the drain line, if exceed 4 inches cut off the excess
God bless you
I can hear the hot watre dripping into the washing machine when it is turned off
see this cause:
drain line clogged, +remove some sock with pliers maybe you can remove the agitator+pumps propeller defective.
frozen pulley pump, replace the pump
improve the drain line+if the drain line reach more 4 inches, cut of the excess. if is lower,install air/gap siphon break assembly.
God bless you
Jul 03, 2012 | Fisher and Paykel GWL11 Top Load Washer
I have a maytag pav2300 pump will not pump
see this causes:
drain line is clogged, remove some sock with pliers+test the pump for defective propeller, and replace DO NOT REPAIR
frozen pump puller +and replace the pump
if the drain hose reach more about 4 inches, cut of the excess
if the hose is lower, install air/gap siphon break assembly
see the diagram.
God bless you
Jun 29, 2012 | Maytag PAV2300 Top Load Washer
I have the whirlpool model WTW495OXWD and it wont spin or drain,
see this causes:
drain line is clogged fix it,some sock is inside, take pliers and remove, if you can you need to remove the agitator, the propeel of pump can be defective replace.
frozen pulley pump replace
improve the drain line. if mayor that 4 inch cut of the diference, is a lower install air/gap siphon break assembly
Jun 21, 2012 | Whirlpool Washing Machines
The washer will not go into spin mode or drain the water
see this cause:
drain line is clogged,remove the large hose that connect to pump to bottom of outer tub remove the cloth with pliers, propeller pump damaged replace
frozen pump pulley replace pump,check manual, if doesnot replace it
drain hose if reache more 4inches, cut ot the remain.if lower install air/gap siphon break assembly.
God bless you
Jun 19, 2012 | Washing Machines
Water does not drain
see this causes:
drain line clogged, ome sock in the outer tub, use pliers for large hose and pull out,test the pump can be faulty.
frozen pulley pump, replace, move manually see the diagram, if not replace
improve the drain line, if the drain hose reach the 4 inch cut of the excess, if is lower, install air/gap siphon break assembly.
God bless you
Jun 19, 2012 | Kenmore Elite 45986 Front Load Washer
American Standard Contemporary Kitchen Sink Liquid Soap Dispenser - 4305.20... Logo
442 people viewed this question
Top American Standard Home Experts
Mike
john h
allphase tech
Level 1 Expert
Are you an American Standard Home Expert? Answer questions, earn points and help others
