Question about Cameras
Mist fan Water container leaking
2 Suggested Answers
  • 1374 Answers
SOURCE: Heating AC problem
Either you need a heater core or the drain hose for the evaporator is clogged. Take it to a repair shop and have them check it out.
Posted on Jul 19, 2010
Stopped humidifying, water remains in the container. everything else seems to operate fine
If you are using the misting type humidifier rather than the wick-type. there could be a blockage in the misting aperture. These units clog easily, and it is best to use distilled water in them since mineral deposits can clog the aperture.
Feb 15, 2016 | Humidifiers
Is not producing the mist
Most misting humidifiers use an atomizer to generate the mist. It is a small metal disk that vibrates very fast. I have yet to see one of these that ever lasts more than a year or two. If you remove the water container you should be able to see the atomizer. If you can put you finger on it and it isn't vibrating then thats the problem. On most small humidifiers it is cheaper to buy a new one that to try and get it fixed.
Dec 16, 2012 | Honeywell Warm Mist HWM-2030 Humidifier
Heating AC problem
It sounds like the heater core is leaking engine coolant into the passengers side compartment. White mist could be steam from the hot coolant? The Heater fan could be damaged, or it is a short. Fill your radiator and take it to the shop or replace the heater core.
Jul 19, 2010 | 1997 Oldsmobile Cutlass Supreme
I have a Cool Mist V3500 humidifier. The fan
TRY POURING IN SOME WHITE DISTILLED VINEGAR AND RUNNING IT. THE VINEGAR LOOSEN UP ANY SCALE AND JUNK. AFTER RUNNING UNIT FOR AWHILE, DRAIN OUT ANY REMAINING LIQUID AND ADD DISTILLED WATER OR FILTERED WATER. RUN UNIT AGAIN. THEN DRAIN OUT ANY LIQUID. NOW THE UNIT SHOULD WORK AS NORMAL. IN THE FUTURE, TRY USING DISTILLED WATER OR FILTERED WATER.
Dec 13, 2009 | Vicks Cool Mist V3500 Humidifier
Leaking buy the firewall
if it is water or a sweet smelling liquid it is your heater core leaking, pull back the carpet and see just how wet it is, look also for vapor on the windsheild and also with fan on high sometime you can see a mist coming from the defrost vents on the dash... please rate my help, thanks...
Aug 05, 2009 | 1999 Ford Taurus
White powder coming from dehumidifer.
Commercially available cool mist humidifiers sonicate water in order to create a fine mist. In other words, intense vibration liberates millions of tiny droplets of water from the reservoir. This water contains all of the salts of the original tap water. Consequently, over time, you will begin noticing that a fine white powder covers EVERYTHING in the room. This is the same stuff that is trapped in the reservoir of a warm mist humidifier.
its harmful but very annoying !
please rate me
May 29, 2009 | Maytag M7DH65B2A Dehumidifier
Fan works, but no mist and water isn't going away
Turn on furnace and urn up humidistst to call for it. Tube from solenid to the filter should have water running if water is up to the valve and solinoid is opening . It should be warm to your touch., Using an ohm meter you can sheck the coil it shuold have continuity.
Mar 11, 2009 | Honeywell QuietCare HCM-630 Humidifier
Very little water left/ fills up and leaks
**With the unit unplugged**
the float sensor is probably getting sticky with residue and buildup (lime, grime, etc). Try cleaning the little float and that area. It should move easily when clean.
Mar 30, 2008 | Crane Hello Kitty Humidifier
Cameras Logo
32 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
