Question about Toshiba 32C110U 32 in. LCD TV
No sound output
Conncected to my computer with an hdmi cable
  • Toshiba Master
  • 3,320 Answers
Check that the audio output you have selected on your computer is going out on HDMI cable. If your sound card will not process HDMI output you will never get sound.
Posted on Mar 26, 2014
How do I get hdmi audio to tv to work using chromebook c11 computer?
A HDMI cable carries both "audio" and "video".
Configure the "audio" in the computer to NOT output to the internal sound-card, but to output through the HDMI cable.
Sep 20, 2015 | Computers & Internet
No sound output
Check that the audio output you have selected on your computer is going out on HDMI cable. If your sound card will not process HDMI output you will never get sound. Changing HDMI sound from computer to tv
Mar 26, 2014 | Toshiba 32C110U 32 in. LCD TV
How do get sound surround interface between my HD SET TOP BOX and my Sony DAV-S300. I have seen previous responses and digrams with connection to the Optical in socket on my DAV but my system doesn't have...
http://hd.sky.com/hd-television-equipment/hd-set-top-box/
http://hd.sky.com/hd-television-equipment/input-output-connections/
http://www.ehow.com/how_5890852_convert-hdmi-rca.html
The first two links you've probalbly seen before, they show conncections and connectors. I looked at pictures of your system and it would appear that the only input for video and audio is RCA. I think it has s-video for video only(s-video slightly better). The third link is the only way I can see to get what you are asking. It is an HDMI to RCA adaptor. You would use an HDMI cable out from your set top box to the adaptor then, RCA cables to your DAV-S300. It's the only way I can see. Hope this helps.
Mar 11, 2011 | Sony DAV-S300 System
How do I hook up the DR420 directly from cable input to TV. The coax hookup on back of the unit is slip on, but not a regular one fits. limited instructions came with it. I need the right connector and...
Take the unit in to a place like radio shack and have them find the correct cable you need. Make sure you know what connection you need for the TV. this may require a special plug but I would not expect that, there are a ton of different connection cables for different units.
Connect to the component outputs on the back of the dish receiver. This is the output for TV1. Then conncect the ouput of the dvd dr420 to your TV. I am using the HDMI output on the dr420 to connect to an HDMI port on my tv. This results in a 1080p picture on the TV which is sharper than the 1080i from the dish receiver's HDMI cable. My Sony TV has multipe HDMI ports so I can choose betweeen these 2 inputs and can see the differance since Dish only sends 1080p on it's pay for view channels
Nov 25, 2010 | Toshiba DR420 DVD Recorder
What kind of cable if any can i use to make my wd52526 proj tv my pc comp monitor
Your projection TV has HDMI input so you would need to either run an HDMI-HDMI cable from an HDMI output on your computer or, more likely, a DVI-HDMI cable from the DVI output on teh computer to the HDMI input on the TV. If ycou can'T find a DVI-HDMI cable note that you can also buy DVI/HDMI adapters for one end of an HDMI-HDMI cable.
Note that DVI is HDMI minus the sound so if you do run DMI to HDMI you'll also need to route the sound to your TV or other amplifier.
If you only have a VGA output on your computer then you will not be able to easily run this to your TV as VGA is an anologue signal while DVI and HDMI are digital. To do this you'd need a converter.
Hope this helps. If so then please rate my advice.
Thanks
Sep 03, 2010 | Computers & Internet
How do you connect dvd dr420 to dish hd reciver with dvr to give me the capabilityto record from my dvr to my dvd dr420? do you have a phone number? how much does it cost to join fixya?
Connect to the component outputs on the back of the dish receiver. This is the output for TV1. Then conncect the ouput of the dvd dr420 to your TV. I am using the HDMI output on the dr420 to connect to an HDMI port on my tv. This results in a 1080p picture on the TV which is sharper than the 1080i from the dish receiver's HDMI cable. My Sony TV has multipe HDMI ports so I can choose betweeen these 2 inputs and can see the differance since Dish only sends 1080p on it's pay for view channels.
Jun 14, 2010 | Toshiba DR420 DVD Recorder
Acer ax1700-u3793 doesn't display an hdmi sound output option
try to check if the audio cable(jack) is properly connected to your device or speaker
Aug 30, 2009 | Acer Aspire AX1700-U3793A PC Desktop
NO SOUND WHEN USING HDMI FROM PC TO HDTV (RUNNING VISTA)
When using an HDMI to DVI cable their is no audio that comes through that cable. Even if you use HDMI to HDMI most computers only have video output from HDMI. You will have to use a seperate audio cable for you to be able to get the sound to work. Depending on the output you have on your laptop you may have to resort to hooking up a pair of speakers to the headphone jack.
Hope this helps.
May 27, 2009 | HP Pavilion dv9030us Notebook
No sound on pc connection
HDMI outputs from devices such as DVD players do carry both video and audio, but the HDMI output from your computer video card only carries video. You'll need to connect a cable from the computer sound output to the TV as well.
Feb 25, 2009 | Sony KDL-26U2000 26 in. LCD Television
Connect PS3 for playing/viewing blue-ray thru surround sound
Connect the PS3 to your TV with the hdmi cable and to the surround sound system with a digital optical cable, then set your PS3 to output sound through the optical port (through the sound options menu) and you're good to go!
Oct 27, 2007 | Sony DAV-HDX500 System
Toshiba 32C110U 32 in. LCD TV Logo
43 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
