Question about Toshiba 32C110U 32 in. LCD TV
No sound output
Connected to computer with hdmi cable
  • Toshiba Master
  • 3,320 Answers
Check that the audio output you have selected on your computer is going out on HDMI cable. If your sound card will not process HDMI output you will never get sound. Changing HDMI sound from computer to tv
Posted on Mar 26, 2014
No sound output
Mar 26, 2014 | Toshiba 32C110U 32 in. LCD TV
How do I connect a laptop to this tv?
It will depend on the laptop's available external video ports. You can connect a VGA cable from some laptops to the VGA port on the TV. Then plug in a 3.5 mm audio cable from the headphone jack to the PC audio in port. (The audio connection is optional. You could continue using the laptop's speakers.)
Make the connections with the TV and the laptop off. You may need to enter the BIOS to enable the external video port. (It can be turned off to save power. The BIOS is accessed on boot by pressing a key (Esc, F1, Del) noted on the splash screen. For Win8 machines, you'll need to do a special restart.) Then turn on the TV before turning on the computer. The TV monitor should be automatically recognized for resolution and refresh rate. Next, if you have a Windows system, right click on the desktop (pick a spot with no icons or running programs). Click on Screen Resolution (or perhaps Graphics Properties, depending on the OS). Set the monitor to duplicate the screens or send data only to the TV screen.
I'm not sure if the HDMI ports will understand a computer signal. (Not all TVs can interpret the computer's HDMI signal; it is different than that of other set top boxes.) You can try the following connections.
If your laptop has a DVI output, use a DVI to HDMI cable (or adapter) to connect to the TV. Then connect the HDMI cable to HDMI 1 and use the PC audio connection as above.
For an HDMI output, use an HDMI cable. (You will still need the audio cable unless you can reset the audio signal to output on the HDMI port. Go to the Control Panel and then the Hardware and Sounds section. Under Sound, select Manage audio devices. Then in the Playback tab, make the HDMI audio the default.) For Display Port or Thunderbolt outputs on the laptop, you will need a DP to HDMI adapter.
If the HDMI port doesn't understand the computer signal, you'll need to use a converter to go from the computer's output to component video or to VGA. Then connect the converter's output to the appropriate port on the TV.
I hope this helps.
(To access the Control Panel in Windows 7 and earlier versions, click Start and then find the Control Panel in the right hand column. For Windows 8, press the Windows key + X (or access the Charms menu on the right-hand side (Win+C) and choose Settings). Then select the Control Panel.)
Oct 13, 2013 | Haier L42B1180 - 42 1080p LCD HDTV
I wanna connect my laptop(lenovo G450) to samsung series 4 lcd through hdmi cable
A HDMI cable can output both audio and video, whilst some computer with Windows XP cannot automatically switch to HD Audio output as Windows 7 can. Thus manual setup can solve the problem.
After connecting the HDMI cable, Go to "Start" > "Control Panel" > "Sounds and Audio Devices", double-click "Sounds and Audio Devices. Select "Audio" tab on "Sounds and Audio Devices Properties" window.
On "Sound playback", change "Default device" from "Conexant HD Audio output" to "NVDIA High Definition Audio".
Your television should have several HDMI ports, select the appropriate HDMI port number and check if TV is not muted.
Hope this helps.
Jul 13, 2012 | Lenovo Computers & Internet
I cant find the hdmi icon in sounds
Hello walchell,
Welcome, and thank you for using FixYa!
To answer your question: HDMI Audio Output is part of your Digital Output package. Try turning up the Digital Output.If you are not hearing sound to your TV from your PC or DVR while connected to the HDMI cable, it is likely that you have purchased a cheaper HDMI cable that only provides video out. A high quality HDMI cable cost close to $35.00 for both outputs.
Have a great day!
Dec 01, 2011 | Computers & Internet
I have a 60" Mitsibishi TV and I am trying to
When your notebook computer is connected to an HDMI device, you may encounter certain display and sound issues. For example, if you have your notebook computer connected to an LCD TV and/or surround sound speakers with a high-definition multimedia interface (HDMI) cable as part of a home theater system, you may encounter some common HDMI display and/or sound issues such as the following: If you are experiencing one of the following issues, click the link to go directly to a section of this document for a resolution. If you are experiencing an HDMI display or sound issue that is not listed above, please contact HP for assistance. Set HDMI sound output c02654744.gif Make sure that HDMI device is enabled and selected. To make it the default sound playback device, select ATI HDMI Output and then select Properties . The HDMI cable must be connected when it is configured. Use correct HDMI cable for your HDMI device There are three types of HDMI: 19-pin (normal head), 19-pin (small head), and 29-pin. If your computer and HDMI device use different cable types, adapters are available. For more information, see HP Notebook PCs - Overview of HDMI and DVI Connections for PCs . Content protected error message If you are playing an HD DVD on your notebook computer while it is connected to an LCD TV with an HDMI cable, you may see an error message that reads, The content is protected. The content is not allowed to be played in current mode. This error sometimes occurs when single mode settings are selected. To resolve the issue, click to accept the message when prompted, and the movie will play. images do not display properly When the notebook computer is in HDMI mode, images sometimes are distorted or do not display at all. To resolve this issue, use the HP Support Assistant to test your computer and install any updated drivers. Alternately, download and install the latest NVIDIA GeForce driver from your model from the HP Software & Driver downloads page . For more information about downloading and installing drivers for your HP notebook computer, please see the Locating HP Software, Drivers, and BIOS Updates in Vista support document. Surround sound option is unavailable First, confirm that your notebook recognizes HDMI audio by right-clicking the Volume icon in the Windows system tray and selecting Playback Devices . If you do not see HDMI Output then you may need to reinstall or update your audio drivers. Also, make sure your notebook's BIOS is up-to-date. When using WinDVD to play a movie after selecting HDMI as the default audio output, the surround sound option may be unavailable. To resolve this issue, please update to WinDVD version 9.0 or later at the HP Software & Driver downloads page . If you are using the MediaSmart program, make sure you are using the latest version. For more information about downloading and installing software updates for your HP notebook computer, please see the Locating HP Software, Drivers, and BIOS Updates in Vista support document.
Oct 04, 2011 | Computers & Internet
Hi, I have bought LG LCD ld310 . Can I connect my computer output to lcd tv through dvi-hdmi cable or vga-hdmi cable Thanks Jatinder Kumar
Hi Jatinder Kumar ,
Yes you can connect your computer output to lcd tv through dvi-hdmi cable or vga-hdmi cable.
1. Connect to HDMI (DVI) : just plug in HDMI (DVI) out of PC or laptop to HDMI or DVI TV. Than select source from HDMI.
2. Connect to PC : Plug D sub to TV, select PC in.
I hope that will help you.
thanks.
Mar 21, 2011 | LG Televison & Video
I have a panasonic Viera and I'd like to play my computer through it. The computer picture works fine through a converter to the HDMI cable input but how do I get sound? I need a separate cable from the...
does your computer graphics card have a hdmi output on it? i had a same problem the coverter input will not let sound though it u would need a hdmi output from the computer or need to connect a separated sound output as the form of speakers from the computer itself, i mite be a problems with drives, try updating the graphics card drives. this mite solve the problem as well. hope this helps
Aug 13, 2010 | Panasonic VIERA TH-65PV500 65 in. Plasma...
How can I connect Panasonic TH-37PX60U Flat panel plasma tv to my computer?
It will depend on your video output options on the computer. If you have HDMI output, just use an HDMI cable and an audio cable (this will need to be a 3.5 mm to RCA audio cable). If you have a DVI output, use a DVI to HDMI cable and the audio cable (or a DVI to HDMI adapter and either a DVI or HDMI cable depending on which side you want to put the adapter). If you only have VGA out from the computer, use a VGA to DVI adapter and the DVI to HDMI connection and the audio connection. (Theoretically this should work but each adapter will have some signal loss issues.)
Some graphics cards have a video output, S-video or Component video, which would also connect to your TV with the audio cable. (Read your cards manual for more information)
I hope this helps.
(For DVI to HDMI cables, you will need to check if you have a single link or dual link DVI output. The wrong cable may not work.)
Feb 20, 2010 | Panasonic TH-42PX60U Television
Acer ax1700-u3793 doesn't display an hdmi sound output option
try to check if the audio cable(jack) is properly connected to your device or speaker
Aug 30, 2009 | Acer Aspire AX1700-U3793A PC Desktop
No sound on pc connection
HDMI outputs from devices such as DVD players do carry both video and audio, but the HDMI output from your computer video card only carries video. You'll need to connect a cable from the computer sound output to the TV as well.
Feb 25, 2009 | Sony KDL-26U2000 26 in. LCD Television
Toshiba 32C110U 32 in. LCD TV Logo
90 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
