Question about Baudville Computer Prod Award Maker 2001 30-user pack (13241) for PC
Prints Blank Documents
When I print my Award Maker documents they come out blank. Looks fine on the screen, prints nothing but goes through all the motions.
Printer not printing document, prints out blank page
You may have a bad print head. Go through the troubleshooting in the Home Center>Resources first. It may have you run the clean print head function. If that doesn't do the trick you can order a print head at: http://www.kodak.com/ek/US/en/Home_Main/Inkjet_Products/Printing_Supplies.htm
Nov 19, 2013 | Kodak ESP Office Equipment & Supplies
Word 2010 doc will not print. Will print with Wordpad.
Microsoft support describes several things to try. After checking to see if any new blank document you create could print or not, the next possibility is to rename the normal.dotm file that may be necessary to resolve this problem.
Procedure to check:
"Microsoft Windows 7
  1. Quit Word.
  2. Click the Start button.
  3. In the Search Programs and Files box, type Normal.dot or Normal.dotm depending on your version of Word.
  4. For each occurrence of the Normal.dot or Normal.dotm template that you find, rename it Normal.old. To do this, follow these steps:
    1. Click Normal.
    2. On the File menu, click Rename.
    3. Type Normal.old, and then press ENTER.
You can now print new documents that are created from the new global (blank document) template (Normal.dot). However, existing documents that were created by means of your old Normal.dot file may not print. If this is the case, go to the "Print the problem document" section to resolve problems with these documents.
If you cannot print this new document, there may be a problem that prevents Word from printing. If this is the case, go to the "Print the problem document" section.
Determine if the problem documents were created from the same custom template You may still not be able to print particular Word documents. Examine the problem documents to determine if they were created from the same custom template. To determine which template created the problem document, follow these steps:
Word 2010
  1. Open a document that you cannot print.
  2. On the Developer tab, click Document Template in the Templates section.
  3. On the Templates tab, look in the Document template box."
Jan 12, 2018 | HP Office Equipment & Supplies
My epson sx200 prints photos fine but i cant print documents ? paper just comes out blank ?
Check Setup utility and set you documents Setting ...Look in your manual or go on line on Epson.com Enter the model off our Printer and check how to set our printer properly... Good Luck
Sep 29, 2010 | Office Equipment & Supplies
Prints blank pages
hi jcruisedirec
Test print shows that there is no problem with he printer.
Do this:
Type just one or two words in a new document and try to print. Before printing, look at the print setup and make sure you have the correct printer name selected.
Also when you go to print, there are few options like:
  • Print All
  • Current page
  • Pages
  • Selection
If you attempt to print "selection" without actually selecting a certain portion of the document, you get blank page.
So first check that the correct name of the printer is selected.
Then test printing one page
Hope this will help you. Good luck.
If you find this helpful, please give a rating
luciana44
Oct 04, 2009 | Canon MX300 Office All-In-One Printer
Photosmart 7960 prints blank documents; prints from internet ok
If it can print from the internet, it is working properly. I would disconnect the printer from the computer, uninstall the drivers and reboot twice. Reinstall the drivers and hook up the printer when instructed. Make sure that you select this as the default printer. (unless, of course, you have another as default)
Jul 24, 2009 | HP PhotoSmart 7960 InkJet Printer
Won't print on regular paper
My quess would be that printhead is becoming clogged, photos don't use as much ink as plain paper printouts that is why they look faded! You need to call Kodak tech support!
Jan 10, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Not printing microsoft office documents, VIsta Software
Try to press the photo and copy at the same time it will print a diagnostic page
look how is the quality of the text.
if it prints very light or if it doesnt print open the access door and try to remove the ink cartridges and put it back again and make sure you hear a click sound after you put the cartridges back in and close the printer access door
try to print again a demo page press photo and copy and check if there is improvement
if no improvement open the kodak aio home center software click on the question mark(?) on the upper right corner and click on maintenance..then select printhead cleaning.After the printhead cleaning print again demo page (press photo and copy at the same time) if still no improvement on the quality of the text call the kodak hotline 1 800 421 6699..you might need a printhead replacement..
Nov 16, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Printer cuts off top 1 inch of PDF document
Go to the printer properties and try setting it up with border less printing.
Cheers
May 23, 2008 | Lexmark X4270 All-In-One InkJet Printer
HP IIIp prints extra blank pages
HI there make sure that the paper tray guides are fully against the paper also try sending the job through the manual feed to see if you get the same problem. If you do not then it maybe that the paper cassette separation pad is worn and will need replacing. If your model has no rubber pad at the front of the cassette then you will have a metal hold over one corner of the paper make sure that when the paper lifts that the paper sits under the silver (Dog Ear) as this acts as a separator.
Hope this helps
Thanks J
Jan 28, 2008 | HP LaserJet IIIp Printer
Baudville Computer Prod Award Maker 2001 30-user pack (13241) for PC Logo
16 people viewed this question
Top Baudville Computer Prod Computers & Internet Experts
David Payne
David Payne
Are you a Baudville Computer Prod Computer and Internet Expert? Answer questions, earn points and help others
