Question about Electrolux Washing Machines
Ewf 8556 Is there any solution to reset this machine. When its turn on, the light blink at END button. I cannot start my laundry work, cause the START/PAUSE button wont appear.
  • Official Brand Answer
  • 4,342 Answers
Good Morning Mass manana,
I see that you are looking to reset your Electrolux washer due to the fact that the "Start/Pause" button does not appear, and you can't start your laundry. You can reset this appliance. What you will need to do is either unplug it or you can shut the power off at the circuit breaker. When you do this you will need to leave it off for at least 2-3 minutes. Cut the power back on, start any cycle. If you are still having trouble not being able to start the washer, I suggest either contact the manufacturer or your local authorized technician. I hope this is helpful.
-Best Regards-
WP
Posted on Mar 27, 2014
fanny
  • 146 Answers
SOURCE: Pause mode stuck
Is the door firmly closed? Open the door and close it firmly. If the pause button is really stuck, you will need to repair/replace the board.
Posted on Nov 06, 2007
  • 66 Answers
SOURCE: wont start
if it is duet hold the end of the cyle button and it will re set
Posted on Dec 23, 2007
  • 96 Answers
SOURCE: Zanussi ZWF1437W washing machine - wont start
The error message "Err" usually indicates that the wash program and option are not compatible. 40 degrees and 900 rpm Spin should be o.k.. I would try another wash program with no special options and see if the problem goes away.
Posted on Mar 07, 2008
dutchman05
  • 487 Answers
SOURCE: GE Adora front load washer overloaded now won't start
Washers - Resetting Electronic Controls on a Washer
If there is a pause in the washer cycle, the controls will lock up. The pause can occur because of a power failure or it was put in the test mode at the factory.
Also, if the washer was stopped before the cycle was complete or the consumer has pushed the stop/pause button to temporarily stop the cycle and the cycle is not reset. Over a period of 24 hours, the washer will pump out and spin, but will stay in the final spin.
To correct the situation, shut off the circuit breaker for 30 seconds or unplug the washer, then turn the timer knob around and back to any position other than final spin. Verify the water is turned on and restore power. This should resolve the issue.
Posted on Apr 23, 2008
SOURCE: Is there a reset button for my Whirlpool Cabrio
Check the lid switch and its actuator on the lid. The pause you're getting is likely an open lid sensed by the washer control. Also try to push and pull the inner tub up and down a few times - if I remember correctly these washers have a floating basket, which engages the gears when there is enough weight inside. If there is not enough clothes it may not wash correctly (I don't remember exactly, but try it anyway, what do you have to loose? ;) ).
Posted on Nov 02, 2009
How do i reset washing machine AEG 64840
You can choose the right programme for any type of laundry following the descriptions on the washing programme tables (see «Washing Programmes»).
Turn the programme selector dial to the required programme. The programme selector determines the type of washing cycle (e.g. water level, drum movement, number of rinses) and the washing temperature according to the type of laundry.
The pilot light of button 8 starts blinking.
The selector dial can be turned either clockwise or anticlockwise. Position "0" to Reset programme/ Switching OFF of the machine.
At the end of the programme the selector dial must be turned to position "0", to switch the machine off.
If you turn the programme selector dial to another programme when the machine is working, the yellow pilot light of button 8 will blink 3 times and the message Err is displayed on the display to indicate a wrong selection. The machine will not perform the new selected programme.
Dado
Jan 15, 2015 | AEG Washing Machines
My Electrolux EWF 8556 Front Loading washer wont Start
Hi I would check the plug to see if the wires have come loose or the fuse is gone in the plug this can happen at any time and its the last place you always look, the plug looks fine but
Nov 15, 2017 | Washing Machines
Electrolux ewf 1029. What's wrong with it?
Something not working? Problems which you can resolve yourself, before calling the After Sales Service.
During machine operation it is possible that the end light
4 flashes= the door has not been closed
2 flashes= the machine does not empty
1 flash= the machine does not fill.
Once the problem has been eliminated, press the START/PAUSE button. In the case that the blown fuses due to consumption exceeding 10 amps and also have problems with the front cover microswiche which is not activating when you close the door. You should check the condition of the engine and change the microswiche of the door. Remove any objects from the pump impeller by rotating it.
Jul 28, 2011 | Washing Machines
How do you unsnap the lid clothing stuck under agitator
i bought2 month ago new electrolux washing machine model EWF 8556....now this washing machine will give me a problem......problem is start /stop button always blinking.....and other button also not funtion( spin/option/rinse) also for delay button....... so please help me as soon as possible..... tq
Aug 12, 2010 | Washing Machines
How can I reset my electrolux washing machine afer an E20 error?
turn the dial to off. Press and hold the start pause and the nearest option button. While you're holding them down, turn the dial one notch clockwise.
The machine will beep or flash, let go of the buttons. Release the buttons, then turn the dial slowly, stopping at each click until you get to "off". Now, turn to any setting, then turn to off.
Now, try the machine. If it works, I'm very happy. If not, perhaps someone else can help.
Good Luck
Apr 20, 2010 | Electrolux Washing Machines
Lights Blink washer wont start
Check user manual for programme reset , but poss. hold start button on for minute or try same with cancel button.
Nov 02, 2009 | Washing Machines
Machine stops and the Start light is blinking
It might be teh same problem I have. in my case, teh machine works for a few seconds and then stops i.e. nothing else happens. no alarms go off either. In my case it appears that teh door interlocking device is faulty. You can by this spare part for around 22 euro. Replacing it is a bit tricky because you need to take off the locking device(the slot where the door locks into) and redo wiring. DONT mess up teh wiring becasue then you will need an engineer. Before you go looking for a spare part, you can take off teh interlock adn manual try to operate it. do this by turning on a wash and pressing teh two metal parts together on the lock.
May 18, 2009 | Electrolux Washing Machines
Electrolux EWF 1087 - Power on, light goes orange, nothing works.
Hold reset and start buttons down, while turning on. Hold down for about 10 seconds.
If you're getting an E90 error code, which means communications error, it means you have a dodgy connection between the main board and the control panel.
Disconnect the power completely, open up the top of the machine and reseat the plugs on both ends on the blue ribbon cable connecting the front panel display to the main board. (The main board is the big white plastic thing with all the wires running into it).
Do the reset steps when turning on again, should be good to go, otherwise it's a bit more serious and you'll need the tech back.
Feb 28, 2009 | Washing Machines
Washing Machines Logo
275 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
