Question about Waring Blenders
Battery fault the battery is dead its been a while am using it
Weak battery
then the rechargeable battery is dead. take it to Batteries Plus to have them replace it
Jan 15, 2014 | Waring Wwo100bj Pro Wwo100pc Professional...
Plugged 120V appliance into 220V socket
Its dead, and whatever you do, DO NOT plug it into any power again, it could cause a fire so fast that you would be in mortal danger.
Most of the world uses 'real' levels of power, your american appliances cannot handle it.
Dec 19, 2013 | Blenders
Kitchen aid food processor blade , one of the blades came out of the socket.
No you can't glue it you need th replace it call the store or the manufactor and see what they say, thats there fault for that falling out call them.
Jan 09, 2013 | KitchenAid Kitchen Aid KFPW760WH - 12 Cup...
Blender overheated
If it won't run once it has cooled down, you have probably cooked the electric motor, which is not worth trying to fix.
If you have some time to poke around, it is vaguely possible that a switch has burnt out, which can be fixed/cleaned. Another longshot is a burnt out fuse, but I doubt it has one.
Jul 22, 2012 | Oster Fusion 7-Speed Food...
No power. No lights. Dead.
Use a multimeter in continuity mode ( OHMS) to check the power cord to the unit. After disconnecting check the cord on the unit to the switch control and the motor.
The failure can be due to a trip switch- load trip- , failure of the motor brushes, failure in the selector switches, open wires to the unit or the motor .
Checking with the meter can confirm the fault if you find an open line.
Sep 17, 2011 | K-Tec Blenders
The coleman rechargable blender not blending
Subject: Rechargeable Portable Blender Model No. 850-870
I was given one of these blenders for Christmas. I charged it through 3
cycles, used it once and the battery was dead. Charged it through another 5
charge cycles and used it once only to then have another dead battery. I
have put it through at least another 8 charge cycles, and it indicates a
DEAD battery. I have managed to blend two (2) 3/4 full pitchers in total. On
trying to start it now the green light 'flickers' quickly on and shuts down.
This is a totally useless device.
I would like to return it for a full refund, including shipping.
Dec 21, 2009 | Coleman 850-870 Single-Speed Blender
Help me revive my dead Oster blender
Check the motor brushes. They may be worn out. Also, since the 1980s, many electric motors have a thermal fuse in them. This unit "blows" when it gets to a certain temperature.
This fuse looks like a 22-caliber bullet and its pointed end is usually colored. If you have an ohmmeter or continuity checker, see if current will pass through the fuse. If not, you can try to replace it. Most times, the fuse is attached with crimp-on connectors. Replacements can be soldered in, if you put a clip-on heat sink between the fuse body and the soldering iron.
Mar 09, 2008 | Oster 6854 14 Speed Blender
Blender dead
Well all electronics was fine, the problem was the thermal fuse with the field winding was open I replaced it and the problem was solved.
rgds
mloo55
Jan 29, 2008 | Black & Decker BL5900 ProBlend Work Top...
Blenders Logo
Top Waring Blenders Experts
karen renee may
Level 1 Expert
eyecam
Are you a Waring Blender Expert? Answer questions, earn points and help others
