Question about Logitech Cordless Desktop MX 3000 Keyboard/Mouse
Split keyboard & capslock shift function
Hi.  My MX3000 Logitech keyboard suddenly started preferring the left shift key to do capslock on most of the left keys and the right shift for the right side keys.  Some keys you have to use the caplock key to get caps.  Go figure? I figure I must have hit a special program key, but  can't figure out how to undo it.  Help?
I had a similar problem and noticed I hit the F Lock button. On mine it was a one way plunger stuck down. This caused the problems you mentioned on mine. Prying it up with a paper clip had my unit working immediately. Good luck!
Posted on Feb 15, 2008
I have a Logitech cordless ex110 keyboard that I would like to find an online manual for....I have no idea what the 'F' keys do and every once in a while I hit something (?) that converts my /,...
Did you install the Logitech Set Point software? If you did, you can edit the Function key assignments by opening that program. There are other ways to change your keyboard settings, pressing Left Alt and Shift can do this with Windows 7 by default. To check this in Windows 7, click Start > Control Panel. Under Clock, Language, and Region select Change Keyboard or other Input method. Once that window opens, click on the Keyboards and Languages tab and click Change Keyboards. Then select the Advanced Key Settings tab. There is a section marked Hot Keys for Input Language.
The manual and other documentation for the Logitech ex110 is available here: http://www.logitech.com/en-us/433/154?selectedcrid=433&selectedcid=154&WT.z_sp=Product&osid=&bit= .
I hope this helps.
May 20, 2011 | Logitech Computers & Internet
Hi, How I shall get to know whether Keyboard's capslock numlock or scrolllock hey is on or off on Logitech Cordless MK250??? I am getting big trouble in entering different capital or small character's...
if the corresponding Numlock, Capslock, Scroll lock light are ON, then it says that the corresponding functions are activated...
For example if the Numlock light is ON, then you will be able to use your number pad...
if caps lock light is ON, then you will be able to use the Capital letters...
Dec 10, 2010 | Logitech Wireless Access Duo Optical...
Shift key isn't working properly it is backspace how do i fix this problem
this has been a problem with my "internet navigator logitech keyboard" and when i run the "#keyhistory" script i get these results after hitting
the following keys :
L L RightShift L L CapsLock L L
VK SC Type Up/Dn Elapsed Key Window
4C 026 d 0.47 L
4C 026 u 0.16 L
4C 026 d 2.89 L
4C 026 u 0.17 L
A1 136 d 2.19 RShift
A6 16A a d 0.02 Browser_Back
A1 136 u 0.16 RShift
A6 16A a u 0.00 Browser_Back
4C 026 d 0.80 L
4C 026 u 0.13 L
4C 026 d 2.52 L
4C 026 u 0.14 L
14 03A d 6.05 Caps Lock
AA 165 a d 0.02 Browser_Search
14 03A u 0.19 Caps Lock
AA 165 a u 0.00 Browser_Search
4C 026 d 4.80 L
4C 026 u 0.14 L
4C 026 d 0.11 L
4C 026 u 0.14 L
and as you can see I have two problems with this. One problem is that when i am in an internet browser and i hit shift it acts as Backspace/Back and when i am renaming a folder and i hit shift to use caps it also acts as Back. The other problem is similar with the Caps Lock key, whenever i am in an internet browser and i hit Capslock, the Search window appears and the Capslock function gets activated as well.
I was trying to Remap these two keys but i wasn't successful in doing so,
for the shift key i tried remaping 00_6A and E0_6A to another key and i also tried remapping 00_36 to another key and neither of these two helped.
and for Caps lock i tried remapping E0_65 to another key and it didn't work. I also tried turning off both the shif key and the CapsLook key and their that only turned off their original function but it didn't turn off the backspace or the search functions.
Aug 16, 2010 | Computers & Internet
Instead of getting the @ symbol when I press shift +2 i get "
you need to hold down ctrl and function on the left side of your keyboard, and then hit the shift key on the right side of your keyboard. Then let go of right shift while still holding down the control and function keys, and then hit right shift again.
these blue keys are french keys. if you change your keyboard settings to english US or UK, it will get rid of the blue functions, but for some reason, they tend to turn themslves back on again after time. Most likely due to automatic updates followed by an auto restart. Also, I find that the issue only arises if I am in my hotmail account.....no issue in Word docs.
Jan 13, 2010 | HP D8597A Keyboard
Logitech Internet Navigator keyboard assembly help.
i hope this will help you.
left side of your keyboard, u can use for close and back of the page.----------------Web Novigator
top left-----digital music playback (for backward, forward, play, pause and stop)
in the center---Enhanced Function keys (light will come when you use capslock, F mode and Num lock)
volume control
right side on the corner---you can use for mail, home and calculater respectively.
thanks
Jun 22, 2009 | Logitech Internet Navigator Keyboard
F keys suddenly not working
The "F mode" button toggles on and off the F keys. If you press it (accidentally) as I did, the keys will no longer function.
Simply press the "F mode" key again (it is directly above the "End->" key between F12 and Insert on this model keyboard) and functionality will be restored.
Apr 08, 2009 | Logitech Computers & Internet
Keyboard
Try typing randomly all over the keyboard for a minute to discharge the capacitors. Then press the connect button on the underside of the keyboard and see if that works. Let me know how it goes..
Sep 04, 2008 | Logitech MX3000 USB PS/2 Wireless...
ASUS A8J notebook keyboard input error
Check tomake sure the Function button is not activated -this could be the problem.
Feb 21, 2008 | Logitech Cordless Desktop MX3200 Laser...
Logitech mx3000 keyboard
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
Feb 13, 2008 | Logitech MX3000 USB PS/2 Wireless...
Logitech Cordless Desktop MX 3000 Keyboard/Mouse Logo
298 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
