Question about ASUS Computers & Internet
If we close the screen a little bit it goes bright white. Have to switch off and restart. Also, after doing a power point presentation the display is only opening about 80% of full screen with a black strip down the right hand side and 1/2 inch grey at the bottom. How do we display the screen to be 100%? Thanks
  • Bratman Jun 15, 2009
    Went through the steps you suggested twice but nothing happened - still only using about 80% of screen. No yellow ! or any ? in the device manager.
    Any other suggestions?
    Thanks
    Thanks for for help it still didnt work We still have only 80% screen with black screen to the right
    Anyone else encounter this problem after a powerpoint Presentation and conecting to a projector?
    President:
  • 1,197 Answers
Installing the correct drivers for the GFX card and setting the correct NATIVE RESOLUTION should fix that issue...
Try playing around with other resolutions (right-click empty area of Desktop->Properties->Settings->Screen Resolutions).
You might need to install the graphics driver from the maker's site (not asus, but Intel, Nvidia or ATI) for the machine to recognize the display and its native resolution. Find out your graphics card (or chip) by running Belarc Advisor on the system.
Just in case connect an external monitor and restart the laptop. If you see the same strip on the external video, then that is the motherboard or the video card (if it’s a separate module) problem.
downloaded all the drivers again, reinstall
have you looked at the settings for flat panel scaling in the nvidia control panel? Perhaps you can restore to default (it is on the top right hand corner of this screen). The "use nvidia scaling" doesn't have any black borders.
incase ur using nvidia..... Uninstall the nvidia drivers from control panel -> Programs and features
Restart 5920 after uninstall - press f8 during reboot to enter Windows in safe mode
once in safe mode, start Driver Sweeper. Select option for "Nvidia - display" and click on the "Sweep" icon. It removes the left over nvidia files pretty quickly. When it's finished, restart the pc.
Once back in windows, go to control panel->device manager
expand "display adapters" - the tree should display "standard vga driver". Right mouse click and click on "update driver software"
select "browse my computer for driver software"
select "let me pick from a list of device drivers on my computer"
click on "have disk" and in the browse window open the folder with the extracted driver that u have installed new....
double click on "the nvac.inf" file and select ok, then the "next" button until it starts to install.
let ur OS install the driver (click on Yes to any windows that pop up). Restart
if all the above doesnt work.... ur screen is the problem.... u might need replacements..... if u need to replace any item.... get the part number and search at ebay... its very cheap...
if u found my solution helpful.... kindly rate my solution good luck....
Posted on Jun 16, 2009
    President:
  • 1,383 Answers
First check that your graphic drivers are properly installed.
You can check it in device ,manager.
Press WINDOWS KEY + PAUSE BREAK KEY
Then go to hardware tab
then clik on device manaager.
Then check thee is not any ? or yellow ! for vidio controller.
if all thing are ok then when u power up the computer press F8 key then enter in "ENABLE VGA MODE" then go t odispaly property and change screen resolutin to 1024*768.
Then apply & ok.
Posted on Jun 15, 2009
On start up screen just bright white,,,restart and again screen just white
Try holding down alt+f4 (upon launch) and launching in safe mode. If that fails turn your computer off again and hold down alt+f4 on launch again but this time do a system restore to an older restore point. If you keep getting the white screen then I would take it in to get looked at.
Mar 11, 2015 | ASUS 21.5 " All-In-One Black Desktop...
I have a lenova 3000 100 when I turn it on it goes directly to a white screen?
Dear Ashley,
If you pass the point of your index finger around the border of the screen, pressing the screen just a little bit, do you see a small risk with dark borders at any position on the screen?
If you do find any dark spots when you move your finger around the screen, your LCD screen is broken and needs to be replaced.
Regards,
Miguel L. Martins
Oct 04, 2013 | Computers & Internet
Vostro 1520 screen goes blank if cover is opened more than 1/4 of the way
There's a sensor (LCD Lid Close Control Switch) that has gone bad. The sensor controls when the display is shown or not shown based on the position of the lcd lid.
May 18, 2012 | Dell Computers & Internet
Switches on shows screen and then goes off
My monitor is doing the same thing. I think it does that when its cold. I turned the monitor off, shook the screen and turned it back on and it was working.
Dec 10, 2009 | Hannspree HW191D LCD Monitor
My LG Viewty screen goes bright white when i turn it on?
Have you solved this problem because i have the same problem with my viewty and would be grateful to know how you have solved it.
Jul 06, 2009 | LG KU990 Viewty
If we close the screen a little bit it goes bright white. Have to switch off and restart. Also, after doing a power point presentation the display is only opening about 80% of full screen with a black...
In LCD screens is a common problem that after setting a lower resolution than recommended you'll see a black stripe sometimes up and right, right click on any empty spot on your desktop and select properties then go to display options and move the resolution bar to a higher point and click apply also click yes in the warning display and accept.
Regards.
Jun 15, 2009 | ASUS A6Ne Notebook
Screen is on, but does not appear to be on
The monitor was broken. I returned it to the vendor for replacement. Your tech did not seem to feel it was a monitor problem and only focused on the video card - although I asked him directly regarding his confidence of it being a videio card problem versus being a monitor problem.
I will not use your service again.
Mar 21, 2009 | LG 22" FLATRON LCD Monitor
SANSA E200 NOT SHOWING THE MENU SCREEN
Try to format the SANSA E200.
You can do this by simply holding down the Power/Menu button for about 15 seconds. After the reset, any changes you have made to the e200 during its last use will be lost.
PLEASE RESET USING THE RESET PIN PRESENT IN THE SIDE.
AND FORMAT THE PLAYER . if this dosen't work your player is faulty
Nov 21, 2008 | Computers & Internet
Bright White Screen
just turn of the player pressing the power button for 15 seconds, then turn the hold button on and off; turn it on and it's ready to continue watching
Jan 19, 2008 | SanDisk Sansa e250 MP3 Player
Computers & Internet Logo
83 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
