Question about Danby DDW1805W Designer Series Free-Standing Dishwasher
Wire diagram harbor breeze remote reciever
Received went out and want to use universal one need wire diagram for eight wires,red,black,white,I know, light grey,light Burgundy,baby blue,dark blue,and yellow two grey
  • james silva
    james silva Mar 26, 2014
    not danby washer, harbor breeze ceiling fan
2 Suggested Answers
jyackle5
  • 8197 Answers
SOURCE: how do you hook the four wire electric cable to
To connect power cord:
• Remove the screws from the cover of the
junction box located at the top rear of the dryer.
• Loosen/remove the two screws on the strain
relief clamp and remove from 4-wire supply
cord.
• The strain relief splits into two indentical parts.
• Insert the large flange of both sections into the
hole located on the left side of the junction box
housing. The short flange of both sections and
screws must remain positioned on the external
side of the junction box housing.
• Insert the 4- wire supply cord through both
sections of the strain relief and re-install strain
relief screws, do not fully tighten until electrical
connections are complete.
• Attach the power cord ground conductor (green
wire) to the ground terminal marked with the
ground symbol. Tighten screw until ground
conductor is secure. (See Fig. 7)
• Attach the power cord neutral conductor (white
wire) to the neutral terminal. (marked N)
Tighten screw until neutral conductor is secure.
(See Fig. 7)
• Attach the power cord phase conductor (black
wire) to the phase terminal (marked L3).
Tighten screw until power conductor is secure.
(See Fig. 7)
• Attach the power cord phase conductor (red
wire) to the phase terminal (marked L1).
secure.(See Fig. 7)
• Tighten the screws on the strain relief so that
the power cord cannot be moved.
• Re-install the cover of the junction box and
secure with four screws removed earlier.
• The dryer is now ready to be connected to the
power supply receptacle.
This is from the manual for the Danby DCD5505W. You did not give the model # so I went off of what you listed it under.
Good Luck and please rate 4 thumbs for the free answer.
Posted on Apr 29, 2010
Trying to replace a remote controller in a Hunter ceiling fan with a Harbor Breeze univer. need help with wire color code.
Did you try reading the directions that came with it? I can tell you that the black wire with white stripe coming from fan is the light wire.
Apr 01, 2016 | Hunter 52" Ceiling Fan With Light And...
I have a harbor breeze ceiling fan on a dimmer
You have 3 options. You can connect the fan blue and the fan black to the red ceiling wire. Then you will need to control the fan and light with the strings. The wall switch will turn off everything. Option 2 is make sure that there is a switch wired to the black ceiling wire. If there is a switch I would check to make sure the switch is working. Option 3 is to purchase a remote control unit for both and leave the wall switch to shutoff the whole unit. Hope this helps.
Oct 11, 2013 | Speed Ceiling Fan 3-speed Switch By...
Wiring instructions for harbor breeze ceiling fan model wsc52wb5c
Since that is a low-end store brand(Lowes) I can only guess the usual. Black to black,white to white,green to green or copper wire,blue to red.If no red wire in ceiling then put blue & black from fan to black in ceiling.
Mar 27, 2013 | Dryers
Hampton Bay 5745a ceiling fan, no blue wire.
The blue wire is running into the built in receiver inside the fan housing. You will not be able to install another receiver to the fan and have control of the lights. You will be able to control the fan though.
Aug 02, 2012 | Dryers
Wiring diagram for harbor breeze celing fan
The colors of the wires in the Harbor Breeze ceiling fan kits tell you what their functions are. The black wire is hot for the fan, the white is a common wire for both the fan and the light kit, green is ground and blue is hot for the light kit. locate the black and blue wires from the ceiling fan and connect them to the black wire inside the electrical junction box by twisting an orange wire connector onto all three wires. Locate the white wire from the ceiling fan and the white wire from the junction box and attach the two wires together with a wire connector. Connect the bare copper wire onto the green wire from the ceiling fan mounting bracket by twisting an orange wire connector onto the two wires. Push all wiring inside the electrical box. good-day !
Nov 26, 2011 | Hunter 52" Ceiling Fan With Light And...
I purchased a hunter universal remote and have a hunter fan with canopy I am trying to get it hooked up to. I have all wiring configured the way it shows on diagram and still nothing. From the box in...
If everything is wired correctly, disconnect power at the source, then reconnect power and experiment with every possible combination of wall switches and the remote until the fan works correctly. At that point, do not use the wall switches again, ever.
Apr 17, 2017 | Hunter 27187 Remote Control
Harbor Breeze ceiling fan, lights are flashing. It appears I am having the same problem as others with Hunter fans. In the electrical box I found the watt governor. I see others with this problem are just...
Make sure you are using the correct wattage for the bulbs. If you're taking the limiter out, it's white to white & black to red(or whatever colors are left)
Jun 01, 2011 | Dryers
Installation of wall remote for harbor breeze ceiling fans
One black wire on the switch hooked to the black sources wire. The other black wire on the switch hooked black up to the fan. The green on the switch wire goes to the bare wire. If there is bare wire you can use the white wire.
Nov 17, 2007 | Dryers
Danby DDW1805W Designer Series Free-Standing Dishwasher Logo
104 people viewed this question
Top Danby Dishwashers Experts
Kevin Getz
Kevin Getz
Andrew Taylor
Andrew Taylor
Are you a Danby Dishwasher Expert? Answer questions, earn points and help others
