Question about Siemens Microwave Ovens
Temperature indicator HFT7320
Circulator fan is not working
call a service technician to fix
Dec 12, 2015 | Microwave Ovens
Temperature at 10 power level
It does not work that way. The microwave OVEN generates (electromagnetic) microwaves that are absorbed by the molecules of the food in the oven, the container and the air.
The absorption rate depends on the molecular composition. After enough microwave energy is absorbed the overall temperature increases and the food is warmed, heated or cooked. If your mixture is inhomogeneous some parts absorb more energy while other absorb less and you can have hot spots.
The power level by itself won't give you an indication of the temperature because you need to know the time that the power has been applied. In simple terms Energy =time*power. The temperature reached is somewhat proportional to the energy, that makes it dependent on the time and the power.
Dec 22, 2013 | Haier MWM0925T 0.9 cu. ft. Microwave With...
Temperature in degree centigrade at 10 power level
Error message of "F3" appears
F3 or F4
Open or shorted oven temperature sensor (RTD)
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Keep us updated.
Jul 10, 2011 | Hotpoint RVM1325WW Microwave Oven
My Frigidaire electric range has the f-3 message error what does that mean
This indicates a failure in the temperature probe. This is easy to check and replace. Here is a link that will walk you thru checking an oven Temperature Sensor .
Fault Code F1 F3 F9 Dr
Dec 04, 2010 | Frigidaire Microwave Ovens
My kitchenaide convection oven is displaying the E1 F4 error.
KitchenAid ovens are popular for their classic design and simple user interface. When a problem occurs in the function of a KitchenAid oven, an error code will display on the clock as soon as the malfunction registers in the oven's memory. Each code corresponds to a particular type of malfunction. Most can be corrected by disconnecting the power supply for one minute and then restarting. If the code persists, either replace the indicated part or contact a service center. F0/F1
  • The F0 and F1 codes refer to electrical issues. If the code appears as only two digits, the problem is a transistor failure, so you must replace the electronic range control (ERC). If the code displays four digits, it will read F0-E0, which indicates a failure switching from analog to digital, or F1-E1, which refers to a safety flip-flop. Both problems require the replacement of the ERC.
  • F2/F3/F4
  • The F2, F3 and F4 codes refer to problems with the oven temperature sensor or the keypad. If you see the two-digit F2 code, it means your keypad has shorted and the ERC must be replaced. The four-digit F2-E0 code means that the oven temperature is too high. Test the door lock and the relay operation, and correct as necessary. A two-digit F3 code means an open temperature sensor or thermal fuse, so those parts must be replaced. A four-digit F3-E0, F3-E1, F3-E2 or F3-E3 code or a two-digit F4 code means that either the oven is registering as too hot or the temperature sensor has shorted. Either way, the oven temperature sensor must be replaced.
  • Nov 22, 2010 | Microwave Ovens
    WHY DOES MY GE STOVE KEEPS FLASHING F2?
    Hello mrctate. The F2 fault code indicates that there is high resistance or interference in the oven temperature sensor. The fix is to replace the oven temperature sensor. You can look at this part by going to Searspartsdirect.com and entering your model number. Once you do so you will see excellent diagrams of each of the parts of your GE stove. Joe
    Thanks for choosing Fixya!
    Nov 18, 2010 | Microwave Ovens
    GE Profile jvm1090ww 01 SN ZR958136 s Convection temperature does not get above 360F when set at 450F. Could never brown meat or bake.
    The convection heater is control according to the temperature of the part n 3014 Thermister
    Part Number: AP2025611 made by GE
    So this is acting like a temperature sensor and it seem that is giving wrong indication to the control panel and switch off the heater at wrong temperature.
    So you should replace the thermister.
    You can find this and all a other parts of your oven in this link.
    http://www.appliancepartspros.com/partsearch/model.aspx?model_id=216738&diagram_id=20027025#d20027025
    Nov 04, 2010 | GE JVM1090WW Microwave Oven
    Kenmore Gas Range model # 362.75491990 F3 error Oven will not hold temp - error message displays and beeps I Replaced the oven temp sensor same issue Is the control panel bad?
    Many models of the GE microwave have sensors that can detect humidity from the foods you are cooking. This allows the microwave to make adjustments to the power levels used to cook your food. If "Sensor Error" appears, you should either press "Clear" to cancel the mode or leave the food in the appliance longer to give the microwave more time to detect the food.
    Press "Time Cook" to manually enter the time if you receive an error message when trying to use the "Sensor Reheat" mode of your GE microwave. The error message may be caused by the food item being too large or too small to detect.
    these are some other code error that will help you in case of next time.
    1. Step 1 Press "Off/Cancel" (or "Cancel/Off" depending on your model) to clear the error code. Note the code if it reappears.
    2. Step 2 Replace the touchpad if the code displayed is "F0," "F7" or "F10." A function key is stuck or shorted.
    3. Step 3 Replace the touchpad or the clock (ERC) if the code "F1" is displayed. Disconnect the ribbon connector to the touchpad. If no code is displayed after an hour, replace the touchpad. If the code displays again, replace the clock.
    4. Step 4 Replace the oven temperature sensor if "F2," "F3" or "F4" is displayed. "F2" indicates the oven temperature is too hot and the oven temperature sensor is suspect. "F3" or "F4" indicates the oven temperature sensor or shorted or open.
    5. Step 5 Replace the ERC if "F5," F6" or "F8" is displayed. The ERC is the main control unit. "F5," F6" and "F8 are codes that indicate problems in the ERC functions.
    6. Step 6 Inspect the door-lock assembly and circuit if "F9" is displayed. The door must lock when the oven is in use. If the lock mechanism is not functioning or if the detection circuit is malfunctioning, the stove will display "F9."
    jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); NOTE:
    "F3" codes mean your oven temperature sensor has failed or shorted out. The only thing you can do is to replace the sensor.
    Take care.
    May 11, 2010 | Microwave Ovens
    Half way (circa 1hr) through the baking cycle "error 01" appears on the progress window. Any suggestions as to what's causing the malfunction ?
    This is what i have been told i called and also looked up online to find that the error 1 code means
    Magnetron (1) Failure:
    Test magnetron (1) and Blower fan motor
    Magnetron (1), (2) Failure: Test magnetron (1), (2).
    Check blower fan motor and ventilation opening.
    This is what the man told me to do to check the problems
    (He also wanted to make certain i was a repair specialist which i am not) but this is what i got out of him
    1. Disconnect the power supply cord, and then remove outer case.
    2. Open the door and block it open.
    3. Discharge two high voltage capacitors.
    4. A continuity check across the temperature fuse terminals should indicate a closed circuit unless the
    temperature of the temperature fuse reaches specfied temperature as shown below.
    5. Reconnect all leads removed from components during testing.
    6. Reinstall the outer case (cabinet).
    7. Reconnect the power supply cord after the outer case is installed.
    8. Run the oven and check all functions.
    Hope this help you out.
    Apr 26, 2010 | Microwave Ovens
    Microwave Ovens Logo
    87 people viewed this question
    Top Siemens Microwave Ovens Experts
    William Miller
    William Miller
    Steve
    Gerry Harvey
    Gerry Harvey
    Are you a Siemens Microwave Oven Expert? Answer questions, earn points and help others
